      09-21-2018, 08:39 PM   #1
Taoster
Drives: F25 n20
20" X5 wheels on X3?
I was curious if I can fit a Set of 20" wheels off a 4.8is X5 on my f25 X3. I currently have 20mm and 30mm DRA spacers on the stock wheels. Tire size for the X5 wheels are 275/40r20 front and 315/35r20 rear. Stock tires are 245/50r18.
      09-22-2018, 08:33 AM   #2
Merlin82
Drives: 2011 BMW X3 Xdrive35i
I tried on a set and they fit in the back without spacers, but if i wanted to run them i would have needed spacers in the front as the fronts rubbed a tiny bit on the strut. Only other big thing is that that much tire is pretty heavy, especially if they are still run flats. I could feel the extra weight of the wheels/tires going over bumps in the road.
      09-22-2018, 12:23 PM   #3
Taoster
Drives: F25 n20
What are the tire sizes on those wheels? Are they 275/45r20 and 315/35r30?
      09-22-2018, 08:15 PM   #4
Merlin82
Yep
      09-23-2018, 01:35 PM   #5
rcsup1
Drives: x3 35i
20x9.5 275F and 20x11 315R
nyalpine907433.00
      09-23-2018, 05:08 PM   #6
335iAP
Drives: AW E92 & F26
They will fit with spacers and maybe a little rubbing in reverse. Really heavy too.
      09-23-2018, 08:35 PM   #7
Taoster
Drives: F25 n20
That is a thing of beauty. What size spacers ? And is that a 4 banger or straight 6?
rcsup1153.50
      09-24-2018, 03:29 PM   #8
rcsup1
Drives: x3 35i
Thanks Taoster. I am not using any spacers. offset are +35F and +40R.
Its a 35i, n55 straight 6 Turbo.
      11-05-2018, 09:04 PM   #9
X32012FL
Drives: 2012 BMW X3 F25
X5 Style 467 wheels on X3 F25?
Will X5 Style 467 wheels fit properly on a 2012 X3 F25? The wheel specs are as follows.
-19"x9"
-37MM offset
-Bore size is 74.1 mm so i would use hub centering rings
-tire size 255 50 19
      11-06-2018, 12:24 AM   #10
Wgosma
Drives: 2012 F25 X3 28i (N52)
Very nice looking setup; bet you get a very taut German ride with those wheels/tires😉.
rcsup1153.50
