      03-09-2022, 02:31 PM   #1
Paullydesh
Drives: 2013 135i M
Difference Between the Engine oil cooler (Rail Section)
Hello, I have a 2013 135i and need a engine oil cooler. I have looked on Ebay and also called the dealer as-well as comparing a few together and dont understand what the difference is between them.
The 135i EOC is different than the 335i but they both have n55 yet the EOC I was told is different by the dealership.
Also is the N54 EOC different than the N55 EOC??
The 2013 135i EOC Seems to be very specific to just it...
Can someone confirm this?
Thank-You!
      03-13-2022, 06:50 PM   #2
Paullydesh
Drives: 2013 135i M
Update
Upon buying a EOC from a 2008 335i N54 the only difference by comparison was the oil lines going to the oil cooler from the oil filter housing, and the mounting point for the plastic in the front of the radiator. Other than that the mounting section to the rail itself is identical and bolts up. I attached a few pictures showing the differences.
Tags
2013 135 m sport, engine oil cooler
