02-09-2019, 04:37 PM | #1 |
Freude am Fahren
108
Rep 278
Installation of aftermarket wireless charger into 2018 X3 G01
Installed a wireless charging pad into my X3 today. Ordered it 3 weeks ago on Aliexpress, if you use a couple of coupons you can get the price down to around $60 or so. ebay US or amazon have these as well, but at a much higher price:
https://www.aliexpress.com/item/DNHF...461045d0rvPQIr It arrived well packed and as pictured in the ad. Little pamphlet inside was in Chinese, so you have to rely on the ad install pics (see below) and any info you can get from newtis.info. Installation is a fairly straightforward, the pics in the ad show you about 90% of what you need to know. The trim panel surround is held in place with clips and pops right up with a trim tool. Once loose there are three cables that must be unplugged before the panel can be totally removed: iDrive, Parking Brake, and Mode/Camera. There is just enough room to lift the panel 2-3 inches and unplug these. Everything else pretty much follows the pics shown, the only other thing that took a bit to figure out was how to unplug the wiring harness from the cupholder and hooking in the splice harness. By looking at the splice harness included with the charger you can see where the plugs clip & slide into place and go from there. Everything done on the install is 100% reversible without damage, so it's good to know in case it needs to be reinstalled later. Once installed and everything put back together it works as promised. Obviously since I just installed it i can't really speak to how long it takes to charge a phone or it's reliability/longevity, but so far so good. As you can see in the pic, looks factory and has a rubber pad on the top to help stop the phone from sliding. With the phone resting on the pad the sliding door closes in the console with no issues. It does shows CE certification, but being from a Chinese source like Aliexpress sometimes quality can be a crapshoot, so only time will tell. Build quality of the charger and the harness looks to be very high and well done, so it looks promising.
Current: 18 X3 xDrive30i Past: 03 530i Sport | 06 330ci ZHP | 14 X1 xDrive35i M-Sport | 11 328i M-Sport | 98 M Roadster Last edited by fw_fw; 02-28-2019 at 03:56 PM.. Reason: Correction for LED operation |
12
MechX3M40i1006.00 kevinkay271.50 chicagofan0019143.00 calintexas150.50 thekronoschef182.50 iManu141.50 Captain_H19.00 IXVXI131.50 Ragnarkov126.50 EBG91325.50 pej744593.00 focker155.00 |
02-09-2019, 04:51 PM | #2 |
Rep 1,066
Nice. I saw this on EBay a few months ago and shared the info. Glad someone finally bit the bullet and did the retrofit. I know it’s lazy of me, but I love my wireless charging.
02-09-2019, 04:56 PM | #4 | |
Freude am Fahren
108
Rep 278
Current: 18 X3 xDrive30i Past: 03 530i Sport | 06 330ci ZHP | 14 X1 xDrive35i M-Sport | 11 328i M-Sport | 98 M Roadster |
02-09-2019, 05:53 PM | #5 | ||
Rep 1,727
02-09-2019, 08:08 PM | #6 |
Rep 18,713
Nice...
Be careful not to get your warranty voided with the mod.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
02-09-2019, 10:07 PM | #7 |
Freude am Fahren
108
Rep 278
It is easily removable in about 20 minutes, and it only ties into the wiring to the rear cigarette lighter. That, and my local dealer is mod-friendly......
r33_RGSport12967.50 |
02-09-2019, 10:21 PM | #8 |
Rep 232
Found this on real oem.
https://www.realoem.com/bmw/enUS/sho...diagId=03_5038 Any ideas on how it works? |
02-09-2019, 10:22 PM | #9 | |
Rep 18,713
Since it is a lot of warranty phobia across the forums.
02-09-2019, 10:24 PM | #10 |
The limit of adhesion is my home.
1702
Rep 3,778
well.....not sure they'd notice....dealers are idiots for one. LOL. Then the wiring isn't intrusive enough to mess with the main electronics or ECU. Should be ok.
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
02-10-2019, 12:52 AM | #12 | |
Rep 1,108
Of course, that's me guessing. lol That connector is a micro-USB so not sure where that would go. |
IXVXI131.50 |
02-10-2019, 04:08 AM | #13 | |
Rep 232
Do you use the cup holder thing to charge the powerbank? Then hand that thing to the passenger? We already have factory wireless charging, however wondering if this could possibly a solution for the passenger's phone. Apologies for the Installation looks great and also great write up. |
02-10-2019, 06:15 AM | #15 |
Rep 967
I guess this after-marked solution gives you a white instead of blue LED, and no warning in KOMBI if leaving your phone (or display key) charging while turning off the ignition... ?
OP, since it was not your car in most of the pics, I assume you don't know what seat cover is in those pictures? Looks like the drivers seat got same mocka, but with other stitching .. |
02-10-2019, 06:31 AM | #16 | |
Rep 1,727
02-10-2019, 09:37 AM | #17 | |
Freude am Fahren
108
Rep 278
No idea, I can say that Aliexpress is fully of stuff for our cars for ALL kinds of tastes......
Current: 18 X3 xDrive30i Past: 03 530i Sport | 06 330ci ZHP | 14 X1 xDrive35i M-Sport | 11 328i M-Sport | 98 M Roadster Last edited by fw_fw; 02-10-2019 at 05:08 PM.. |
02-26-2019, 05:48 AM | #19 | ||
Rep 1,727
02-26-2019, 03:20 PM | #20 |
Rep 232
03-25-2019, 12:06 PM | #21 |
Rep 17
Drives: 2019 X4 M40i
Garage List 2023 KIA EV6 [0.00]
2022 Audi A6 Allroad [0.00] 1993 BMW R1100RSL [0.00] 2005 and 2008 BMW K ... [0.00] |
I just installed the one from China in my 2019 X4. Install and fit went perfect. White light is on. When I put my phone on it with less than a full charge the light is flashing blue. Isn't it supposed to be solid when charging and flashing when fully charged? Should the battery charging indicator show the charging symbol? Not sure it is working.
03-25-2019, 03:10 PM | #22 | |
1702
Rep 3,778
