08-03-2020, 04:38 PM | #1 |
Rep 42
Running E85 on X3M/X3M Comp.
Has anyone on here ever ran E85 on their s58 motor before?
Also what percentage did you run, did you run a blend or just straight E85? |
08-03-2020, 05:05 PM | #2 |
Rep 1,168
08-03-2020, 06:21 PM | #3 |
Rep 1,219
Stock you can run up to E25
Mission Tuning offers E25, E50, E85 tunes BM3 offers E30 OTS and custom tune for E50 or E85 MHD now does E30 OTS and probably custom E50+
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance 10.84@127.43 / +1912 DA NH Dragway | 10.6@130 Dragy / +820 DA The Streets | NOW: Tesla Model Y Performance |
08-03-2020, 06:37 PM | #4 | |
Rep 1,168
The proof in pudding Best out of 3 runs |
08-03-2020, 07:43 PM | #5 |
Rep 42
I saw it on their website i was just wondering if the stock fuel system can run full E85, i've seen some on youtube running like E20 or E50 but i haven't seen E85 yet
08-03-2020, 08:47 PM | #6 | |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3511
Rep 4,207
08-04-2020, 04:01 PM | #7 |
Rep 1,219
MP lowest E tune (not the 93 with E25) is considerably faster then the BM3 OTS E30 tune. Need to see how MHD stacks up.
boosted116.00 |
08-04-2020, 04:10 PM | #8 | |
Rep 202
08-04-2020, 08:37 PM | #9 | ||
Rep 42
DAC17170.50 |
08-04-2020, 08:57 PM | #10 | |||
3511
Rep 4,207
08-04-2020, 09:04 PM | #11 |
Rep 4,607
08-04-2020, 09:08 PM | #12 |
Rep 608
Ethanol can do some serious damage to your valves and can wreak havoc on fuel systems(clogging/unclogging lines, corrosion etc). It's also horribly corrosive for any aluminum parts. Might be one or two aluminum pieces in there. Also your gas mileage will also drop by about 1/4. We already get such mediocre gas mileage, not sure why you'd want to use ethanol.
Rather make 600whp safely on 93 than whatever y'all claim for e85. |
DKX4///M757.00 |
08-05-2020, 01:16 AM | #13 |
enthusiast
116
Rep 221
Not sure about full E85, but E30 blend works best on B58. IMO same for S58. I wouldn’t risk full E85 either. One more time - very happy with MP tune for both platforms. MHD is also great
2018 340i x-drive 8AT - MP (Mission Performance) stg 3 DME tune, Xhp stg 3 EGS tune, catted AA downpipe, NGK plugs, E30 blend - 11.4@120mph. |
AlexFL7836.00 |
08-06-2020, 08:18 AM | #14 | |
Rep 1,219
E30 wouldn't be a stretch and if it can handle E25 in stock form, it was easily engineered to run E50 blends or so with proper tuning. Also 600 whp on straight 93 is / will never happen unless you have serious supporting modifications.
08-06-2020, 08:30 AM | #15 | ||
Rep 608
And from Mission Performance's post: "2) Stage 1 for premium 93 octane: The lucky states that have access to 93octane at the pump will for sure enjoy a 670bhp(600whp) power output. Just like any stage 1, this is designed on fully stock hardware and being fed a regular pump 93 octane." |
10-12-2020, 12:04 PM | #18 |
Rep 42
i was wondering since it's a custom tune, i forgot whether f80paul uses mhd or bm3 but would you have to buy the bm3/mhd and the custom tune or just the custom tune itself
10-14-2020, 10:51 PM | #20 |
Rep 4,607
10-15-2020, 10:08 AM | #21 |
Rep 1,835
Drives: 2020 X4M CS
The stock fuel system seems to be able to handle (volume wise at least) e85 tunes that are slightly conservative...
However pushed to the max on a custom tune, it seems at e70- e80 in colder denser air, and running peak boost and richer AFRs to allow for the higher boost levels than any OTS, there seems to be some failure midrange of the HPFPs Based on a members car, you all are familiar with who seems to be one of the fastest s58s right now, very aggressive tune... I recommended going e60/40% c16... or, Lowering boost by 2-4 psi (midrange) and keeping peak boost higher where the sam driver hpfps can keep up... or maybe leaning it out a tiny bit and bakcing off tiny bit of timing and a tiny bit of boost... Play with these combos until you're making peak power and tq and making it where its most useful... (BTW Im NOT a BMW tuner, but I've tuned quite a few high performance imports, from Evos, Hondas, Nissans, using all kinds of platforms from Hondata to AEM standalone, to Motec, even HP tuners software on domestics...and general principals are always about the same...) I cant wait til the m3.m4 come out as I would like to upgrade my hpfps anf lpfp to support 900+awhp, then I have a little surpirise I wanna test out
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
