08-08-2021, 09:21 PM | #1 |
Rep 63
2wd mode
Ok I’m in the process of figuring out how to activate the 2wd mode in the bimmer code. I will post more when I know it works correctly and does what it should let the rear end do what it do.!! So you won’t have to spend $300-400 for the simple coding.
08-08-2021, 09:51 PM | #4 |
Rep 1,367
Drives: 2020 X3MC
08-08-2021, 10:17 PM | #7 |
Rep 1,367
Drives: 2020 X3MC
I'm using the bimmerpost app so bear that in mind, but you click reply then the picture icon at the bottom and attach a picture.
08-09-2021, 02:32 PM | #8 |
Rep 63
Here is a picture this is for the negative people in the thread
08-09-2021, 05:58 PM | #11 |
Rep 105
08-10-2021, 12:02 AM | #12 |
Rep 146
Some months ago I talked with henwee on IG, the guy who does the 2wd coding...
He told me that coding is not enought. You have to flash an STG. So I'm not sure if its possible to do it with bimmercode. But good luck! I hope you are successful because I also would like to have the 2wd Mode for less money |
08-10-2021, 02:17 AM | #13 |
Rep 3,925
This 2WD mode sure would be nice for big smoky burnouts & fun shenanigans.
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
08-10-2021, 11:17 PM | #14 | |
Rep 63
I pretty sure you will realize I have a issue with going slow 😬😬😬😬 |
08-10-2021, 11:21 PM | #15 | |
Rep 63
08-10-2021, 11:23 PM | #16 |
Rep 63
Oh yes!!!!! My buddy keeps teasing me with his hellcat and how it can do donuts so I want to do one or 6. If you put it in 4wd sport and turn off traction long hold you can bring the rear out pretty far.
Kevin_The_Clean13281.50 |
02-16-2024, 09:34 PM | #17 |
Estoril Tings
67
Rep 431
Drives: 2020 X3M 2018 X3 M40i
Assuming this didnt work?
2018 X3 m40i - MHD Stg 1
2020 X3M - Stock |
02-17-2024, 01:55 AM | #18 |
Rep 3,925
The XHP TCU re-flash can easily address this AWD option. For those that have it.
02-17-2024, 09:10 PM | #19 |
Estoril Tings
67
Rep 431
XHP/XDelete doesn't put the 2WD option on the IDrive.
2020 X3M - Stock |
02-17-2024, 10:13 PM | #20 |
Rep 328
I'm just going to point out that is an X3M in the control screen with the red arrows fully lit behind the rear tires. As a tech entrepreneur and software developer in a previous life, i'm reading in between the lines that... either its a really clever GUI with dynamic graphic rendering that can display any level of front or rear traction based on JSON params, or more likely the 2WD graphic was already prepared (as a video clip) before a board room decided to kill the feature on the F97/F98.
02-18-2024, 04:38 AM | #21 |
Rep 3,925
Hmmm... I thought they clearly stated they could add this feature in if it was wanted.
