      05-31-2019, 05:45 PM   #1
crosis
Drives: 2011 BMW X3 (x35i)
Question Code to auto Turn off Acc on STOP ENGINE?
Vehicle: 2011 BMW X3 (35i).
Some months back i began playing around with coding for the car. It was certainly a very messy, daunting experience but i managed to change a couple settings.
Months later i totally forget what settings could be changed. When parked and i press the button to turn off the engine the vehicle then goes into Accessory mode keeping the radio playing. I can exit the car and everything remains on. AFAIK this will continue until the battery discharged to a certain point at which time the vehicle finally cuts the power.
Is there a code setting to change the default behavior of the Stop engine button so that when i press the button it not only Stops the engine but also turns off accessories like every other normal car? What is the code for this so that i can quickly get this done?
Thanks
      06-01-2019, 11:12 AM   #2
sbabcock23
Drives: '17 X3
I haven't tried it myself but I believe you are looking for this coding option:
Electronics off when door opened: 3000 --> TC_LOGIC_KLR_OFF_DOOR set to: aktiv
If you are looking for some coding options this Word document has most of the options available for a F25. I know some didn't work on My '17 however most did.
http://www.bmwesys.com/guides/BMW%20...%20series.docx
      06-03-2019, 10:30 AM   #3
TheCoolX3
Drives: 2016 BMW X3 35i M-Sport
I have it coded where 1 press to turn off engine then when I open the drivers door it shuts off the radio
Also I believe it is factory coded in where if you lock the car with the engine off it should shut everything off.
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others
Instagram @TheCoolX3
