02-04-2019, 02:05 AM | #1 |
Rep 470
VRSF 5" FMIC Results
Hey all, I recently had this FMIC installed by my mechanic, would have installed it myself, but he was already doing the full PS2 treatment, so I didn't want to get in the way.
It's (mostly) solid, but he informed me that the pre-made brackets that come with the kit have poorly drilled holes which do not line up. He ended up using a self tapper on one side of one of the brackets, and drilled new holes in the other bracket to make that work. The tabs that fold up to line up with the fan also needed to be completely pushed out of the way. Anyways, wanted to post a log to show how well this thing fares. The important bit is at the end of the log, sorry for the length: http://www.bootmod3.net/log?id=5c57e1a7c090c63e26c94940 Ambient was around 48 degrees F IIRC. I took a trip to Mexico to really test it out. Stock tune for now, but I expect similar results even with more power. Discuss, and let me know if there are questions about this. I'm going to be under the car in the coming weeks and will add pictures of the brackets/fitment.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
02-04-2019, 05:22 AM | #2 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
Definitely interested in pics of poorly fitting brackets.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
02-04-2019, 08:12 AM | #3 |
Rep 540
Drives: 2016 BMW X3 35i M-Sport
The brackets are horrible quality and are very poorly made. After about an hour of persuasion with various hard tools and demerit words I was able to get the holes to align and screw in. Probably cheaper and easier to buy the intercooler for an F30 and build the brackets yourself.
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others Instagram @TheCoolX3 |
02-04-2019, 08:15 AM | #4 | |
Rep 921
02-04-2019, 08:16 AM | #5 |
Rep 468
Did you take any logs from before the installation of the intercooler? 15* rise at those ambient temps is not good.
I don't like the 5" core at all as it has never really worked well. The 7" is better but still not great. Also, what are you using for tuning? Getting a lot of throttle closures. |
02-04-2019, 08:19 AM | #6 | |
Rep 540
From my understading that is stock tune with upgraded turbos. The DME is probably just freaking out.
02-04-2019, 08:24 AM | #7 |
Rep 468
Well, that could explain it. Looking at the log again it is even more apparent how poorly that intercooler is working as it is rising 15* at only 6 -7 PSI. Increase the boost and that IC is going to be worthless.
02-04-2019, 09:08 AM | #8 | |
Rep 470
Will get some shots tomorrow or Wednesday when I replace the lower O2 sensor.
This car will only see backroads or High Plains Raceway, so I don't think I'll experience heatsoak even once I add a tune, but I plan to move through the bootmod3 maps slowly (MPPK, Stage 1, Stage 2, Stage 2H) and provide data to see the difference as power is added. Overall goal is to get somewhere around 420 whp, but it'll be awhile before I'm there.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' Last edited by doodlebro; 02-04-2019 at 09:16 AM.. |
02-04-2019, 09:43 AM | #9 |
Rep 468
I've worked with these intercoolers multiple times on my dyno while custom tuning and will not sell it any longer to my customers as it just doesn't work. My experience. The 7" core is better but still not great.
02-04-2019, 12:57 PM | #10 |
Rep 470
Do you have an example of a better 5" intercooler with logs? The results I'm seeing are consistent with what FSociety saw on his CTSTurbo FMIC a couple years ago. 9* of rise from 71-132 is incredible.
Current mods
02-04-2019, 01:46 PM | #12 | |
Rep 470
EditL Also, my BMS intake is going to have a higher cruising temperature than the stock airbox since it's not sealed and receiving cold air from the RAM. So that also explains the high starting temperature compared to ambient.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' Last edited by doodlebro; 02-06-2019 at 10:06 AM.. |
02-06-2019, 04:30 PM | #13 | |
2093
Rep 43,350
Now lets get down to the facts. The OP just proved this is one of the best performing intercoolers available with these logs. Throughout two of the tallest and longest gears (5th through 6th gear), the intake temps only rose 8 degrees. The intake temps actually drop 6 degrees closer towards ambient through 5th gear. You won't find an intercooler this size (AA, CTS, BMS) that will perform as well as our 5" HD. Here's a different view of the same log the OP posted that proves how well this intercooler performs. The logs speak for themselves. With that said, the brackets are new and we've been recently made aware that the holes need to be slightly enlarged in order to aid fitment. We're having every bracket modified as we speak in order to ensure an easier install. Last edited by Tiago@VRSF; 02-06-2019 at 04:39 PM.. |
02-06-2019, 06:05 PM | #14 | |
Rep 470
Current mods
02-27-2019, 11:15 AM | #15 |
Rep 470
hardparker: Super late, but finally got a thermostat and coolant hose replaced to get these pictures of the bracket weirdness: https://photos.app.goo.gl/dXdF1KuihDi4TGQb8
First video shows how my mechanic thought it was okay to install it... That's a self tapper which backed itself out over the 3 weeks I had been driving the car. I found some slightly larger bolts with lock nuts and a much larger washer, that holds it up nicely now. Tiago@VRSF: Wondering if we can do an exchange on this when you guys get a better fitting intercooler in. I plan to keep this car for a very long time and having a more robust mounting setup is preferred to checking under my car weekly.
Current mods
02-28-2019, 02:22 AM | #16 | |
2093
Rep 43,350
I can ensure the existing bracket will outlast the life of your car and we offer a lifetime guarantee on all properly installed VRSF items so you have nothing to fear |
02-28-2019, 08:00 AM | #17 | |
Rep 3,943
https://www.vr-speed.com/vrsf-interc...i-n20-n55.html The one above? |
02-28-2019, 10:10 AM | #18 | ||
Rep 470
Current mods
02-28-2019, 11:25 AM | #19 |
Rep 470
Here's a log at lower speeds on bootmod3's Stage 1 ACN 91 tune: http://www.bootmod3.net/log?id=5c7766c2c090c65cf850572c
Hilariously, this PS2 is producing more power on this tune than the stock turbo was on Stage 2. Pretty incredible. I'm still impressed by the intercooler as it's keeping temps below 100 degrees no matter what. Should have more power in the coming weeks to really put it to the test and provide some more data.
Current mods
02-28-2019, 12:46 PM | #20 | ||
Rep 253
02-28-2019, 01:04 PM | #21 | |
Rep 470
Current mods
02-28-2019, 09:20 PM | #22 | |
299
Rep 531
Here's my second take on brackets for my F25. Note how there's significant offset from the two factory mounting holes to the mounting posts for the IC. Also, they're not symmetrical because they shouldn't be to get a proper fitment. The offset for the left and right bracket differ. Measure all the stock parts for fitment and you'll see what I mean. I'm pretty happy with them. They're super solid and simple and locate the intercooler perfectly. Plus, they cost $5 in hardware store parts and took less than half an hour to fab up. They may not be pretty, but they're perfectly functional. https://photos.app.goo.gl/m2kMgTVPCTAexVGY9
HDBoss12.50 |
