05-29-2022, 05:18 PM | #1 | |
Rep 559
Drives: 2022 X3MC
Bimmercode: Ambient Lighting Colors & Combos (LCI)
Disclaimer: I am by no means an expert. Proceed at your own risk.
My primary goal was to achieve Blue/Red Ambient Lighting combination on my 2022 LCI and these instructions are specifically for that end result. Thanks to these posts for pointing me in the right direction: https://g80.bimmerpost.com/forums/sh....php?t=1922092 https://g05.bimmerpost.com/forums/sh....php?t=1738645 From what I can tell, the basic principals are the same between all the newer platforms. There are 2 areas in Expert Mode where changes are made: BDC_BODY3 ECU
1. Library is where you change the stock colors of ambient lighting. The byte locations of the colors vary between the platforms. Basic Mode already has the ability to recode Bronze to one of their pre-set colors and luckily Red is one of them. In Basic Mode, there are 2 settings for ambient lighting color but you can't code combinations. For good measure, I set both of these to Red (oddly, will accept the same values just not different values). Update: X4 instructions thanks to gramboda Quote:
Since my Bronze is already Red via Basic Mode, I modified Byte 3 from 00 (white) to 03 (blue). That's basically my workaround to achieve Blue/Red combo. Looking forward to when someone deciphers the Library portion and creates some crazy combos! i.e. You can change the color of 3 areas:
Step by Step:
I created this quick Excel file to help with changing the values. This is for LCI not sure if its the same values for Non-LCI.
'00 328i // Sold
'04 Z4 3.0i // Sold '22 X3MC LCI Last edited by pyo; 09-28-2022 at 12:53 PM.. |
11
05-30-2022, 01:30 AM | #2 |
Rep 341
Drives: E46 m3
Thank you for the write up. Was this on android or ios?
05-30-2022, 02:10 AM | #3 |
Rep 4,376
Is there a way to achieve this on the pre-LCI... ?
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
f80NJ17218.50 |
05-30-2022, 08:35 AM | #6 |
Rep 559
Drives: 2022 X3MC
Android via Pixel 6
From what I've read on here, pre-LCI has no problem setting color combinations in Basic Mode. Can someone confirm? Can't say for sure but I think if you can access those two areas via Expert Mode the basics should be the same
'00 328i // Sold
'04 Z4 3.0i // Sold '22 X3MC LCI |
05-30-2022, 12:21 PM | #8 | |
Rep 341
Drives: E46 m3
leorod_rn491.50 |
05-31-2022, 01:21 AM | #10 | |
Rep 4,376
Yes, but getting the two tone or top & bottom color differences in the door must be coded I think.
05-31-2022, 07:31 AM | #11 | |
Rep 2,221
I took the screen shot in demo mode so not sure if this is exact when connected but it is close if not. ps: I prefer the red on top and blue on the bottom as the blue is brighter than the red/our eyes pic it up more. |
06-02-2022, 03:17 AM | #12 | |
Rep 4,376
06-02-2022, 07:11 AM | #13 | |
Rep 2,221
To be clear though, the red on the bottom is less light. Interestingly, the human eye is less sensitive to red light (does not cause night blindness). That is why it is used for brake lights on cars and why campers/pilots use red lights at night. Also, that is why BMW dashboards are lit in orange. Red is the best color (to avoid night blindness) but they wanted to reserve that for warnings so orange was the next best option - so I've been told. |
Kevin_The_Clean13860.50 |
06-02-2022, 08:26 AM | #14 |
Rep 559
Drives: 2022 X3MC
Thanks guys! I updated the OP to include step by step with screenshots. I've also jotted down all the Bytes (21 total) and what colors correspond to which value in a quick Excel file.
'00 328i // Sold
///minh764.50 |
06-06-2022, 11:45 PM | #16 |
Rep 1,755
Looks pretty cool, I'll probably also add a headliner LED strip now ha.
06-08-2022, 09:15 AM | #18 |
Rep 19,004
About time Bimmercode able to do this. Been doing this on E-Sys since last year.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEAL!! | Akrapovic 10% Off SALE until Oct 15th 2024 MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
06-08-2022, 09:55 AM | #19 |
Rep 1,755
r33_RGSport13504.50 ///minh764.50 |
06-08-2022, 11:27 AM | #21 |
Rep 1,755
06-18-2022, 01:55 AM | #22 | |
Rep 23
Drives: 2022 X3MC
