09-28-2022, 09:13 AM | #1 |
Rep 28
! in instrument cluster
Any ideas what this relates to?
Triangle ! On the right hand lower side of the dash. There is nothing else showing and nothing in the car service status to say anything is wrong. |
09-28-2022, 09:52 AM | #4 |
Rep 965
09-28-2022, 10:13 AM | #5 |
Rep 467
I'm with you. I'm willing to bet it's the gas level.
2011 335is Black/Oyster. 1 of 46 without moonroof (total of all years): JB4 E50 tune, gone
2013 335i M Sport JB4: Estoril Blue gone 2018 M4 ZCP: current 2023 X3M Comp: current |
09-28-2022, 02:44 PM | #6 |
Rep 47
I have seen it when i put on trailer mode because that mode disables the rear proximity warning sensors. Swipe down on the center stack screen to see the message list and maybe it will tell you there.
09-29-2022, 02:24 AM | #8 |
Rep 149
The white triangle with exclamation is just a notification. Your fuel range is at 50 miles, so more than likely that, but I've also had that show up when washer fluid level was low.
Check the iDrive for notification, the top right bit on the screen should show if there's anything. |
09-29-2022, 09:09 AM | #9 |
Found the Search Button
1592
Rep 1,156
Drives: 2022 X3 30i xDrive
Do modern BMWs still do the snowflake warning?
We're reaching that time of year where the E90 forum would get inundated with questions about the ominous snowflake.
2022 X3 xDrive 30i M Sport, Brooklyn Grey / Cognac
Previous BMWs: 2018 330i (F30), 2014 i3 BEV, 2007 328i (E92), 2013 X5 35i (E70), 2014 i3 BEV, 2006 325i (E90) |
09-29-2022, 09:38 AM | #10 |
Rep 467
My 2018 M4 does it so I assume it's still going into this generation.
09-30-2022, 08:46 AM | #12 |
Rep 11,843
Drives: MY24 G01 AW Msport
probably low pressure tire
