07-05-2021, 08:11 AM | #1 |
Rep 165
Has anyone else noticed that their M40i exhaust tips are not the same distance from the above rear bumper? Ours looks very noticeably uneven. Is there a plausible reason for this besides a manufacturing deviation? This was not from any impact damage. Cheers
07-05-2021, 10:34 AM | #3 |
Silver Bullet
260
Rep 259
Drives: 2021 BMW X3 M40i
I have a small difference from left to right also. Very small. Not that large. Driver side is about 1/16-1/8 of an inch lower than passenger side. Left sitting a bit lower than the right... Also a 21 Glacier Silver build from earlier this year...
07-05-2021, 12:49 PM | #4 |
Rep 1,526
Yea, mine are even so I would report it to your dealer.
2021 M40i Phytonic Blue / Black Vernasca
2020 X5 xDrive 40i Tanzanite Blue / Coffee Vernasca 2011 328xi. Space Grey - Sold 188,925 great miles |
07-05-2021, 01:01 PM | #5 |
Rep 2,956
I'm sure you can probably play with the exhaust hangers to get those even. If you have ever installed an axle back muffler it takes a bit of adjusting of the exhaust hangers to line up the tips with the exhaust cut-outs.
07-05-2021, 05:56 PM | #6 |
A family of bimmers
2747
Rep 7,742
I had this issue on my '18 and mentioned to the service advisor. Easily adjusted and back to correct fitment. Just talk to your SA
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
07-06-2021, 10:39 AM | #9 |
Rep 1,044
Wait I thought it was healthy for one ball to be lower than the other? 😂
Yeah I would report it to your SA and they should be able to get it straightened out.
Rob | instagram
2020 F97 X3 ///M Donington Grey 2018 G01 X3 xDrive30i Alpine White Previous: 2016 F82 ///M4 Black Sapphire Metallic | My Build Thread |
07-17-2021, 06:26 PM | #10 |
Rep 165
Not only are the tail pipes at noticeably different gap levels from the rear bumper I noticed today that the rear tailgate has a much bigger gap on the right side between it and the rear body panel. It's seems like the the entire tailgate needs to be adjusted and shifted to the right. Very disappointing and apparent shoddy build quality. I'm sure its a simple adjustment to correct both issues but it's only a few weeks old. So much for the new car excitement… :
07-17-2021, 11:47 PM | #11 |
Rep 1,041
A misaligned rear hatch or bumper cover (causing the illusion of a misaligned hatch) is not common.
Do check to make sure the vehicle was not “repaired” in anyway prior to it arriving at the dealership.
2024 M2, 2024 CGT4RS, 2020 M2 CS, 2021 Macan GTS, 2017 Cayenne S, 2002 M Coupe |
07-18-2021, 07:06 AM | #12 |
Rep 223
Mine are very uneven, but I just bought the car used. Could someone with a new, perfect alignment post the “correct” tip/bumper gap? Aligning exhaust is normally a brute force exercise.
07-18-2021, 07:55 AM | #13 |
Rep 165
07-18-2021, 05:34 PM | #14 |
Rep 223
I was able to raise my right exhaust tip 3/8” by garroting the rubber hanger with a heavy duty black nylon zip tie. Took 5 minutes. The hangers themselves proved remarkably resistant to persuasion.
