      07-12-2020, 01:47 PM   #1
Shadowdemon1
Drives: X3M Competition, X2 20d xdrive
Tyre pressure monitor failure
Anyone experienced a random TPM failure? Seems to clear the fault after a while and display the tyre pressure again , but sporadically fails again and resolved again.
      07-12-2020, 02:08 PM   #2
Wills2
Barge driver
Wills2's Avatar
Ukraine
8647
Drives: 730d
Yes mine failed a few weeks ago came and went as you say but then decided to be broken all the time.
Will book it in when I can, needs another tech enhancement on top as well.
Spartanburg the home of quality...NOT.
730d/Z4C
      07-12-2020, 03:53 PM   #3
cipher5
cipher5's Avatar
Drives: 2020 Donington Grey X3M Comp
The TPMS is actually manufactured in Germany.
      07-12-2020, 03:54 PM   #4
Shadowdemon1
Strange, this has happened on the three out of the last four cars we have owned, across different marques.
      07-12-2020, 04:06 PM   #5
Wills2
Barge driver
Wills2's Avatar
Ukraine
8647
Drives: 730d
But thrown on the car in South Carolina like the rest of the bits that feel like they're going to fall off....
Hopefully they didn't let the local boys near the engine.
730d/Z4C
      07-12-2020, 05:52 PM   #6
spta97
Drives: BMW 2020 X3MC
I've had the same issue. Unplugging the battery (for my sub/amp install) made it go away for a bit but it came back.
I'm wondering if it is a sensor as the first 1000 miles I was on my winters with a different set of sensors and never had the issue.
Then I put my OEM summers back on and it popped up within a few days.
I bought it into the dealer for my break-in service and they noted the fault but did nothing as it was not happening at the time. Now it happens all the time.
I'm not crazy about going back as there were some fine scratches on my kidney grills and rear bumper
      07-14-2020, 05:31 AM   #7
Shadowdemon1
Turns out you need a software update to resolve the issue.
I will pick the car up later to see if it is resolved.
Though I trust my local dealers as much as a bag of poop.
For example, it took them 3 attempts for a 4 wheel alignment. My car came out worse then it went in. Idiots.
      07-14-2020, 08:47 AM   #8
spta97
Is this a new software update? I just had my break-in service (with software update) done in late May.
Can you provide a pic of the work order with details on the update version?
      07-14-2020, 01:21 PM   #9
Shadowdemon1
They didnt give me any paperwork due to coronavirus. I had to get them to make copies for the wheel alignment
      07-14-2020, 01:58 PM   #10
spta97
Thanks. I guess I'll call my dealer to see what they say.
      07-14-2020, 02:18 PM   #11
BMWZ4
BMWZ4's Avatar
1905
Drives: '23 X1/'23 Allroad Progressiv
This is my 4th 'Spartanburg' vehicle. So far, all four have been flawless. I had more issues with German assembled Z than all 4 X's
Sorry, off topic
      07-14-2020, 04:06 PM   #12
Wills2
Barge driver
Wills2's Avatar
Ukraine
8647
Drives: 730d
Sorry, off topic
Luck of the draw I guess, after 12 German BMWs this is my first non German BMW and its had/got the following
1. Recall before delivery.
2. Frayed stitching on the roll top (no biggy but poor QC clearly).
3. Doors skins that aren't aligned/touching at the bottom.
4. Side skirts just tapped at the bottom that pull away from the body.
6. Rear hatch spoiler that creaks and moves when you wash it (just feels cheap).
5. A second recall notice.
6. Paint that is peeling underneath near the exhaust. (just noticed that one)
7. Failed TPMS.
8. Driver mirror indicator that has cracked from the inside.
All in 6 months that's more failures/poor workmanship/build quality issues than the other 12 put together...so my lived experience of a Spartanburg product isn't great, I buy BMW/Audi/Merc/Porsche partly because I respect the German ethic towards engineering and doing a good job, I didn't know it was a US built car when I bought it so my bad.
I like the car it's great to drive just poorly built in some areas.
730d/Z4C
BMWZ41905.00
      07-14-2020, 04:29 PM   #13
BMWZ4
BMWZ4's Avatar
1905
Sorry, off topic
7. Failed TPMS.
That's quite a list. I've had the recalls as well on a few Spartanburg & German vehicles, but nothing like your list (except my Z)
Wills28647.00
      07-14-2020, 05:04 PM   #14
Sebap3
Drives: X4M Competition
7. Failed TPMS.
Wow that’s some bad luck. I’ve had all the recalls Winfrey picket it up. The only issue I had so far was, broken window motor. But it’s not a common thing and it happens. Other than that no issues, no creaks everything is great.
Wills28647.00
      07-15-2020, 03:00 PM   #15
Wills2
Barge driver
Wills2's Avatar
Ukraine
8647
Drives: 730d
It drives very well and I do like it but those niggles.....niggle.
730d/Z4C
BMWZ41905.00
      04-20-2021, 11:15 AM   #16
Shadowdemon1
Reviving this thread for anyone else experiencing a similar problem.
The tyre pressure monitor within one of the wheels had to be physically replaced. The software patch update was bull. Had to go back in to the dealer.
      04-20-2021, 12:05 PM   #17
spta97
Makes sense. Mine has not popped up yet but I just put the summer/OEM wheels/tires back on a couple of weeks ago.
As mentioned, this only happened with my OEM sensors, not the ones I got for my winters (which were OEM HUF brand).
Wonder if there were a bad batch of these sensors?
      05-04-2021, 09:04 PM   #18
CIWS
Moon Parasite
CIWS's Avatar
Drives: F98 X4M Competition
I've had mine for around 10 months and just started experiencing this a couple of weeks ago for the first time. Randomly lost tps readings, then started working again later that day. Nothing done to the vehicle maintenance wise when it first happened. Was good for two weeks and just happened again yesterday.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged
      05-05-2021, 05:20 AM   #19
1Volfan
Drives: 2020 X3M, 2000 M Roadster
Glad this thread was revived since after a week or two of having my summer tires back in, I’m getting this daily now. Time to text my SA.
