03-19-2023, 06:01 PM | #1 |
Rep 38
Leaking OEM EDC shocks??
Hey guys, got my car lowered, and after only about 1000 miles my front passenger shock is pissing oil out of it. Do you think this is a installer error, or does this happen? (has electronic adjustment for firmness)
H&R lowering springs are what was installed, Vehicle itself has 32k miles, and only 1k miles since lowered. Leak was small maybe 3/4 days ago then got very bad in the past 2 days. Any input if this has ever happened, as im hoping to have the shop that installed cover it. Looked at rears and appears they are slightly leaking too. Thanks! |
03-19-2023, 07:28 PM | #2 |
Rep 3,368
It's very unlikely that install error is causing shock to leak, unless errors were present upon completion. Lowering springs tend to accelerate shock wear although plenty run them. Highly doubt any shop would replace the strut as a warranty claim.
03-19-2023, 07:40 PM | #3 |
Rep 328
No it doesn't happen... the EDC (electronic damper control) should never loose fluid, ever. The lowering could have exacerbated pressure on the dampers, leading them to premature failure.
With all due respect, since I see a lot of people lowering SUVs and I just don't get it but to each their own. However, you must realize that BMW engineers designed the geometry and usable range of those units for a specific ride height and weight load, by lowering the chassis, you are compressing the dampers and reducing their operating range.. which by extension increases the physical forces on each unit. Its a little odd to have multiple ones fail concurrently, but if you dropped it to the floor and then decided to do some spirited driving over shitty roads.. at low temperatures, on a 3 year old car.. its very possible that some gaskets could have failed. Can I just why you found that a worthwhile upgrade? Was it for looks? You know they make a M3 wagon. Last edited by spucktacular; 03-19-2023 at 07:45 PM.. |
Scottycs1961.00 |
03-19-2023, 10:37 PM | #4 |
Rep 3,368
03-19-2023, 10:48 PM | #6 |
Rep 3,368
Indeed! My boss has the RS6, sick car, but he's in a loaner more than his car. Been a real lemon. I really want a G81 this side of the pond..lol
03-19-2023, 10:52 PM | #7 |
Rep 328
I'm really upset BMW didn't put 6 pots on our cars... 2080KG curb, while the G81 is like 1850sh, real bummer.. but, don't worry, they'll bring it over for 2025, i'm sure of it.
dmanb2b2124.50 |
03-20-2023, 08:52 AM | #8 |
Rep 4,393
Drives: 2022 F97 X3M Comp LCI
but cost 50% more than the F97.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
gapband240.00 lagunablue1349.50 |
03-20-2023, 05:18 PM | #9 |
Rep 207
OP this seems likely to be some sort of install error. There have been hundreds of members who have posted with their X3Ms lowered on MSS/H&R/Eibach without issue. Yes any lowering spring on stock struts will cause a slightly reduce lifespan of the strut, but it shouldn't blow that quickly at such low mileage unless it was an install error or an existing issue
Where is the leak coming from in the strut? I would guess the shop must have damaged the seal when compressing the springs and torqueing down the tophat.
-2007 Z4M - Interlagos Blue
-2008 E90 M3 - Interlagos Blue, 6MT, slicktop -2020 X3MC - Phytonic Blue |
03-21-2023, 10:10 PM | #10 | |
Rep 38
03-22-2023, 07:50 AM | #11 |
Rep 1,927
i have heard of some garages using mole / vice grips to hold the damper rod to remove the top nut....however, would imagine all would be leaking if they did that?
03-22-2023, 10:18 AM | #12 |
Rep 134
