04-10-2020, 10:15 PM | #1 |
Rep 95
Jack Stands
Feel like this is a silly question but I can’t figure out the jack point to be able to use jack stands. I know the jack points on each side but that doesn’t help with putting in jack stands. Seems like there should be something in the center front but there isn’t, at least not that I see and against my better judgment I jacked it up from one side and crawled under there to look even. It looks like I might be able to jack from one of the front suspension points maybe.
What am I missing? Thanks!! |
04-10-2020, 11:42 PM | #4 |
Rep 95
That appears to be a product to protect the plastic jack point. I use a piece of wood which should work almost as well. That said thank you for the response but I’m still stuck. I’m trying to figure out where to put the jack stands. For example if I were to put them at the normal jack point how would I jack the car up? If I jack the car up at the jack point, where do I place the jackstand?
04-11-2020, 12:02 AM | #5 | |
Rep 581
2005 Estoril Blue M3 ZCP, OEM CSL bootlid, AC Schnitzer everything else
2020 Phytonic Blue X3M Competition, Remus Race exhaust, AC Schnitzer everything else |
04-11-2020, 02:15 AM | #6 |
Rep 1,912
i used the jack points at the side and then put the stand under suspension points as you mention. That said, i only did one side at a time.
04-11-2020, 07:13 AM | #7 |
Rep 170
The jack stand should be placed under a solid part of the subframe. Do not put it under a suspension piece that is designed to move or articulate.
04-11-2020, 07:35 AM | #8 |
Rep 210
I use Reverse Logic Pivot Top custom jack stand pads with Esco bases. On the X3M you can lift the back up from the center brace then put stands under both rear rocker points (plastic cups). Use a pad on your jack to prevent scratching. For the front I use a rubber puck on the lower control arm subframe mount to lift up each side separately and place the jack stand on the front point. You don't need the rubber puck depends on the shape of your jack cup. If it's deep I would recommend so you don't put pressure on the control arm. If it's shallow then just a jack pad like pictured is fine.
I had mine up last weekend doing spring cleaning. Jack stands: https://jackpad.us/bmw-mini
2020 X3MC, 2019 M2C
'14 F-150 Tremor, '99 Mustang Turbo |
04-11-2020, 09:17 AM | #9 |
USA
129
Rep 217
I believe the manual shows the rear diff and a front brace to lift from the center in able to install jack stands. I read it a few months ago, but Im pretty sure its there.
04-11-2020, 09:32 AM | #10 |
Rep 210
Brace directly behind the diff.
2020 X3MC, 2019 M2C
04-11-2020, 01:02 PM | #11 |
The Hammock Man
493
Rep 593
Drives: X3MC, X3 M40i, E93 M3
On floor jacks when upgrading tires.
- '20 X3MC | Alpine White | Black Alcantara/Midrand Beige | loaded | 295/265 PS4S - '09 E93 M3 | Alpine White | Bamboo Beige Novillo | DCT | loaded | Chrome M220 Wheels - 275/255 PSS |
04-14-2020, 12:15 PM | #14 |
Rep 210
There is no front center on these. There is a center brace behind the cover but it's not beefy. I wouldn't lift with it. You'll have to lift each side at a time from the lower control arm mounting point. I use a rubber pad on my jack to not scratch.
2020 X3MC, 2019 M2C
rkyan66145.50 |
04-14-2020, 12:36 PM | #15 | |
Rep 95
Thanks - this is what I ended up doing! I could not sadly get the f’n boost pressure sensor out though to get my racechip installed. BMW made it ungodly hard to get to that sensor. Or someone played a trick at the factory and glued it! lol |
05-29-2020, 09:51 PM | #16 | |
Rep 2,219
So far I've been doing one wheel at a time and using the jack to support. I'm not happy with this method. Also, does no one make an insert that will go on a regular jack and fit the BMW points? I'm thinking of going this route of cutting existing stands as I already have 3 sets and don't want to buy another. The issue is I believe the jack points are meant to hold the vehicle from the inside and outside at the same time: https://www.e90post.com/forums/showthread.php?t=727131 |
05-29-2020, 10:00 PM | #17 |
Rep 6,585
05-29-2020, 10:47 PM | #18 | |
Rep 2,219
I've got the HF aluminum ones that have worked well for me. I also have a set of old steel craftsman ones that I rarely use as the aluminum ones are much easier to move around. |
forza19763391.00 |
06-05-2020, 11:50 PM | #19 |
Commander ;)
183
Rep 115
I've got HF jack stands (not recalled ) with adapters from ebay.
The adapters are specific to the model of the jack stand and made for BMW jack pad points. The ebay seller also has a universal jack stand adapter. Overall it's a good setup: adapter is snug on the stand, fits the jack pad points well, and inexpensive compared to other options. Pics. |
06-06-2020, 12:31 AM | #20 | |
Rep 2,219
Ive seen many that sit only inside, but the design mount design seems like it should be supporting the mount on the inside and the rim. I’ve got two sets of the older aluminum jacks so would love to have one set dedicated to my X3. |
06-06-2020, 12:47 AM | #21 |
Craig
233
Rep 389
mine doesn't have this brace seem some do and some don't for some reason
f97 x3m competition Donnington/Adelaide.
f80 m3 competition pack white/black gone f15 40d space grey/ ivory/black gone f31 335i mineral grey/coral gone but will be missed. gone 2014 range rover sport dynamic. |
06-06-2020, 06:29 AM | #22 |
Rep 242
