11-04-2020, 08:53 AM | #5 |
Rep 6,589
I always do 105 and call it good.
r33_RGSport12971.00 Kevin_The_Clean13280.00 |
11-05-2020, 09:02 AM | #7 | |
Rep 2,221
And I resent you calling my Harbor Freight Torque Wrench as not a reference tool |
11-05-2020, 01:06 PM | #8 |
Rep 4,703
11-06-2020, 01:20 PM | #9 |
Rep 405
I called my dealership the service guys said 110
2022 M3comp
r33_RGSport12971.00 |
11-06-2020, 11:44 PM | #11 |
Rep 18,716
Did you asked them if they always torque them properly?
Most of my customers came in with over torqued by the dealer. Some trigger happy techs.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
Kevin_The_Clean13280.00 DBU232.50 |
01-22-2021, 12:35 AM | #12 |
Rep 194
Drives: F87 M2
I was switching to my winter setup and was using a torque wrench for the first time. The 105 torque value seemed pretty loose when the wrench clicked. When I removed the factory installed lugs, it took much more force to remove than hitting 105 on tightening. Anyone have any experience they can share as I don't have any reference on how "tight" 105 should feel.
I'm using a harbor freight tool ICON torque wrench. Thx. |
01-22-2021, 06:48 AM | #14 | |
Rep 2,221
One important step is to re-torque the wheels after about 25 miles and when the wheels are cool. Because the steel of the hub/lugs expands and contracts differently than the aluminum wheels they need to be re-torqued. On my second torquing almost all the lugs are not at the spec torque. I do it a third time a week later but have not had any which were not at the right torque. This is on all my vehicles. The reason I am so paranoid is I almost had a wheel fall off on my truck before I knew to re-torque. Luckily I caught it and only had to have three studs replaced but the lesson was learned. |
J-Pizzle125.50 Kevin_The_Clean13280.00 |
02-01-2021, 10:02 AM | #16 |
Rep 194
Drives: F87 M2
I found this in the 2020 X3M manual. I guess I should have read it a little more closely. It appears that 140 nm is the correct value as posted above by sd306 .
Direct from the manual: Screw on the lug bolt. The tightening torque is 140Nm. |
02-01-2021, 03:48 PM | #17 |
Rep 2,602
Which = 103.2587 ft lbs.....
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i |
02-01-2021, 06:18 PM | #18 |
Rep 194
Drives: F87 M2
02-19-2024, 06:17 AM | #19 |
Rep 3,923
Apparently the Harbor Freight unit called the ICON outperformed the super pricey SNAP-ON unit.
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
