09-27-2022, 10:31 AM | #1 |
Leave the gun. Take the Canoli.
9051
Rep 7,621
Bavsound install
I ordered all the Bavsound speakers and subs for my X3. I took my last Jeep apart and replaced the speakers myself but wasn't really up for doing it on this car so I went to one of the local stereo places. They said about $1,100 and 2 days worth of time. The Bavsound website makes it look like it takes just a few hours. I was hoping for drop it off in the morning and pick it up at night. Maybe I'll try a few other places.
Current: 2023 Santorini Blue ///M8 ||| 2023 X3 M40
Retired: 2021 Enzian Blue ///M4 ||| 2018 ///M4 ||| 2017 ///M4 ||| 2014 435i ||| 2009 335i Coupe ||| 2007 335i Coupe |
09-27-2022, 10:48 AM | #2 | |
Rep 3,368
snareman9050.50 |
09-27-2022, 10:59 AM | #4 | |
Rep 1,762
Drives: 2022 X3 M40i
It shouldn't take 2 days. Heck you can install the subs yourself to save time at installer. |
09-27-2022, 10:52 PM | #5 |
9051
Rep 7,621
With my Jeep it actually wasn't a hateful process. Took a few hours, but in the end I was glad I did it myself. I did break a few of the door tabs along the way when I was trying to pry the door panels off. What are the chances of breaking something doing this? And do you need a glue gun for the subs like the bavsound site says?
09-27-2022, 11:02 PM | #7 | |
Rep 1,762
https://youtu.be/eYIntjXX3VI same procedure for bavsound or whatever |
snareman9050.50 |
09-30-2022, 06:48 PM | #8 |
9051
Rep 7,621
Alright, so I got the dash speakers and all 4 doors done in about 4h today on my own. Definitely wasn't worth $1,000. The second door on each side certainly went smoother than the first. I did definitely break something that looks like a large this plastic cable on the passenger rear door thinking it was something I could unplug, but thankfully everything seems to still work when I put the door back together. Most of the time was just trying to figure out how to do each new thing. The second time through each took probably half the time.
Also, they sent me 3 pairs of tweeters and 3 pairs of mids. I put a pair each in the front and rear doors, but where does the other pair go? It seems that there are speakers in the trunk area, but I don't see videos on how to replace those. Anyone have a clue what this thing is that I broke?
jrsarchy52.50 |
09-30-2022, 07:30 PM | #9 | |
Rep 1,495
Then - E53, E85, E92, E82, F15, F80, G01
Now - F97, Macan S |
bowle5.00 |
09-30-2022, 07:36 PM | #10 |
9051
Rep 7,621
it looks expensive. So what lights shouldn't work now? The colored light on the mid upper door still works. I was initially afraid that I broke the cable that makes the window go up and down and it was going to be stuck in the down position. Thankfully that wasn't the case
09-30-2022, 07:43 PM | #11 | |
Rep 1,495
Based on this part diagram from RealOEM, the front and rear doors use the same conductor, labeled #3. About a $40 part from getbmwparts.com, but to replace you have to remove the decorative trim on the door panel. That process involves drilling out plastic welds which can be a real pain if not drilled out properly (want to ensure you drill the weld out enough to remove the trim piece, but not so much as to be unable to secure it with a washer and screw when reattaching the trim.
snareman9050.50 |
09-30-2022, 07:45 PM | #12 | |
9051
Rep 7,621
09-30-2022, 07:53 PM | #13 | ||
Rep 1,495
snareman9050.50 |
09-30-2022, 11:07 PM | #14 |
9051
Rep 7,621
Got the subs swapped out. It wasn't an enjoyable process, but the 7ish hours I spent today was well worth saving $1100 and not having my car for 2 days.
And for anyone that finds this thread this is the only vid I found that shows the D pillar speakers at 18:30.
madman2365.00 |
10-01-2022, 11:59 AM | #15 | |
Rep 1,208
Just curious, at the end of the day, are you happy with the sound, or still going after a different amp? Sorry I missed this thread, I would have asked if you had the puddle light wiring in the door bottom. Just getting ready to pop my panels and contemplating all the things I can screw up. The list seems endless. |
10-01-2022, 12:25 PM | #16 | |
9051
Rep 7,621
I can't say I looked at the puddle lights as I wasn't considering changing them, but I thought you could get to them from the bottom of the door?
10-01-2022, 12:41 PM | #17 |
9051
Rep 7,621
I did the D pillar speakers. Again, not a fun process. The wires and tweeters were glued in so that took a little undoing. I also lost all 3 clips on the left side panel and broke one of the ones on the right side so I had to order a pack of them off Amazon.
Door Panel Clips Somehow all 3 of the clips on the left side fell off and I assume down into the side of the trunk area somewhere, but no matter how much I searched I couldn't find any of them. Hopefully they don't rattle. And then one of the ones on the right side bent and eventually broke as I was trying to put the panel back on. A few of the pieces through the car didn't go back on quite as snugly as they were originally, but hopefully shouldn't cause a problem. The subs are glued into their housing, but weren't super hateful to get apart after taking a heat gun to it for a bit. It's a darn good thing I'm replacing them because I totally demolished one of them trying to get it out. They are also a challenge to get seated back into the correct place under the seats, but with some jostling around they eventually seat themselves.
10-01-2022, 01:03 PM | #18 | |
Rep 1,762
Here is my full install https://x3.xbimmers.com/forums/showthread.php?t=1951854 As for the underneath seat subs, I later installed sound deadening underneath the plastic sub box and inside and that created more bass. |
snareman9050.50 |
10-01-2022, 01:05 PM | #19 | |
9051
Rep 7,621
10-01-2022, 01:57 PM | #20 |
Rep 1,208
10-03-2022, 01:56 PM | #21 |
9051
Rep 7,621
Mine seems to have the module under the door but my lights come from up in front here
lfdal541034.50 |
10-03-2022, 04:41 PM | #22 |
Rep 1,208
