09-15-2022, 09:02 AM | #1 |
Rep 51
Harman Kardon vs the standard HiFi sound system.
I have an sDrive 30i on order (with M Sport and Premium Package) that is very close to going status 150, i.e, no changes allowed. My wife and I sat in a 2023 X3 in the showroom yesterday to listen to its std "HiFi" sound system. We were underwhelmed to say the least. It's shockingly bad. So now we're considering the HK option for (gulp) $875.00. To those of you who are familiar with the HK, my question is this. Does the HK system sound a whole lot better than the standard HiFi? And do you consider it worth the extra $875?
09-15-2022, 09:12 AM | #2 |
Rep 100
Our X3M (2021 model year) F97 (G01) has the HK system and we have the exact same experience you had - underwhelming. We're looking to upgrade the sound system with something like the Match Up 7DSP amplifier and a subwoofer set-up for the back space.
09-15-2022, 09:33 AM | #4 | |
Rep 4,266
09-15-2022, 09:35 AM | #5 |
Rep 2,869
HK is an absolute must have. I would not own my car without it.
With that said, the HK is also underwhelming until your play around with the EQ settings. HK is not the best car system, but IMO much better and worth it over the 'base' system
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 |
09-15-2022, 09:39 AM | #6 |
Rep 374
I did read somewhere that the base system is much easier to upgrade with a plug and play amp vs the HK. If you are looking to upgrade go base.
09-15-2022, 10:03 AM | #8 |
Rep 697
Drives: BMW 2018 X3 GO1
I have the base hifi system and find it adequate. I did have an X5 loaner that had the Harmon kardon system. While it sounded better, unless you are an audiophile I'm not sure it's worth it . The base hifi to me is fine .
Present:
Jet Black 2018 X3 30i Previous: Sapphire Black 2013 X3 28i , Jet Black 2007 X3 3.0 Liter |
09-15-2022, 10:26 AM | #10 |
Rep 182
I've had HK sound in my past 4 BMW's. I have heard the standard HiFi, and it just isn't as good as HK.
I just took delivery on my new X3M40 with HK. I'm very impressed with the sound in my car, considering the speakers haven't been broken in yet. HK is well worth $850. |
09-15-2022, 10:28 AM | #11 |
Rep 4,266
09-15-2022, 10:31 AM | #13 | |
Rep 4,266
I’ve been into audio for a while, and the one thing I’ve learned is there is no one size fits all. But here you go… also rolling the pano blind back improves the sense of space Also source quality makes a difference. |
bbb83664.00 |
09-15-2022, 12:49 PM | #14 |
Rep 314
I kept my full Bavsound speakers/subs and AMP.
Since the AMP was no longer compatible with the RAM module I sold it for $650 on ebay minus fees, and decided to go for HiFi Audio and use the $850 towards the Bimmer-Tech Alpha One Amp. I already installed the speakers, the AMP should arrived today, takes around 15 minutes to get it installed, and on the weekend I will install the two subs. |
09-15-2022, 01:16 PM | #17 |
Rep 8,622
Yes I mean the base hifi is laughable but the hk is still not amazing... however it is far better, i would have to get it.
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
09-15-2022, 01:32 PM | #18 |
Rep 593
Hi-Fi sound quality has changed. My 19 Hi-FI sounds phenomenal not leaving needing more. Although I have had 21-2022 LCI x3 and 3 series loaners with standard Hi-Fi which sounds horrendous. Doesn't even compare to my 19. I personally believe it's the result of post covid cost cutting that I noticed in a few other areas as well.
09-15-2022, 01:47 PM | #19 |
Rep 1,757
Drives: 2022 X3 M40i
at the end of the day, if this is a lease and keeping it short term spend for HK, but if you keeping this x3 long term and enjoy listening to music loud get hifi and upgrade as the 850 dollars could be used towards an aftermarket amp which can improve sound quaility significantly alone for few hundred more. For example
https://x3.xbimmers.com/forums/showt...ght=bimmertech this is my install with amp and speakers. |
09-15-2022, 01:54 PM | #20 | |
Rep 64
09-15-2022, 02:01 PM | #21 | |
Rep 314
09-15-2022, 02:13 PM | #22 |
Rep 1,222
Really depends on your music source. If you primarily listen to Sirius, or basic FM/AM radio HK will, at best, be a negligible improvement over the stock system.
Listening to streaming/digital like iPhone or CarPlay will make a noticeable difference and easily worth the investment. You’re driving a nice car, might as well have an upgraded system to listen to. |
