      08-13-2021, 11:55 AM   #1
3ero
Drives: BMW IX3
Lane change assist not working
I just swapped in my X7 for an IX3 and noticed that the lane change assist function is not working. Has anyone else experienced this?
      08-13-2021, 04:33 PM   #2
DjCoke
Drives: iX3 2021
It is not on the iDrive 7 systems as far as I know. My 520D 2017 iDrive 6 had it. The iX3 doesn’t come with it. That’s for sure.
But to be honest did you used it often? I experienced it as clunky.
      08-13-2021, 05:11 PM   #3
JAV64
Drives: BMW iX3
Hi is this what you mean? I think it has lane change assist
https://www.google.com/search?q=ix3+...J9u8PwKazwAI50
      08-13-2021, 05:34 PM   #4
DjCoke
Drives: iX3 2021
Oh interesting. It is not on my version delivered in the Dutch version. But I will definitely check it out.
      08-14-2021, 01:18 AM   #5
Thanis34
Drives: BMW F10
My iX3 has lane change assist and it actually works quite well. Even the assisted driving mode (simple self drive) works quite good.
It does depend on the version and you might need to ask your dealer.
PS: lane change is part of the assisted driving mode and is configure able in the menu of the car
      08-14-2021, 01:23 AM   #6
DjCoke
Drives: iX3 2021
Well I have this assisted driving mode. But never saw the lane change options in the menu’s but going to drive today and we will see!
Well doing some more investigation it apparently is removed from the options list in the Netherlands and Belgium as far as I can see. Should we have to code it to activate this option, or did they had chip problems and removed this option at all?
      08-14-2021, 02:57 AM   #7
RoosDK
Denmark
22
Drives: BMW iX3, 2021
I fear that is one of those things that are dependent on national rules and regulations. Pretty sure it has also been disabled in Denmark.
Did a VIN-decode of my car and found the “S8TR - Decoding additional functions”
Unfortunately much of the sales material on BMW national Danish website just appears to translated from the German site, as there a few features, e.g. Remote 3D view, that have been disabled, even though it is mentioned throughout the the website. It took a call to Connected Drive Support to find out, that this not legal in DK.
Would be nice with a list of which features are enabled/disabled in different countries. Instead of having to spend time in the menus of the car, trying to find the different options.
lakmus23.50
      08-14-2021, 04:47 AM   #8
JimPastell
JimPastell's Avatar
Sweden
150
Drives: BMW iX3 G01
This is the same in Sweden sadly. The majority of automatic driving options in the IX3 menu is disabled due to country restrictions.
But it seems to be a coding solution for this on the G01 where you can switch country code and unlock the features. Not sure it works the same way on G08.
Read more here:
Lane Change Assist Coding - Working in the US https://x3.xbimmers.com/forums/showthread.php?t=1699204
      09-11-2021, 06:26 PM   #9
the_ape
Drives: 225xe / iX3 Premier Pro
The one I test drive in the UK had it, worked pretty well. I still dislike how Europe blocks cars being able to self steer over a certain %age, bet tesla driver in Europe hate that too, as full self drive will never work until its changed.
      09-11-2021, 08:05 PM   #10
3ero
Drives: BMW IX3
Finally, after going through two dealerships that didn't have a clue, BMW (UK) has confirmed it should be available. Should have lane change settings too but that's not in mine. Now to a third garage to see if they can sort it out.
      11-02-2021, 12:10 PM   #11
GDEvans
Drives: iX3
Did you manage to get this activated?
      11-02-2021, 12:37 PM   #12
the_ape
Both demo cars I drove had it, I know some territories block it though, and know that the g01's had mods to enable the American version so it can steer over the euro specs %age.
I'll have a look when mine arrives hopefully in the next week or so!
      11-02-2021, 01:53 PM   #13
GDEvans
Drives: iX3
Mine should be arriving at a similar time. Hoping that it is enabled as shown in the promo video. Especially as there don’t appear to be any legal reasons for it not to be available in the UK.
      11-02-2021, 02:48 PM   #14
the_ape
Like I say, worked perfectly in both demo cars I had, and they were UK spec. One with the blue bits the second without.
      11-02-2021, 04:28 PM   #15
gray1x
Drives: BMW X3
Definitely works on mine. UK model.
      11-03-2021, 10:20 AM   #16
Zumbug
Drives: iX3 Premier Pro
Lane change assist does not work on my UK car, if you indicate with assisted driving on the car gives up steering control until you get in to the next lane and then it resumes steering.
On the screen/hud the steering wheel changes from green to grey as soon as you indicate.
If yours is truly working, what are the exact steps you are taking to make it change lane on its own? Are you tap indicating, full press etc?
Current Car: iX3 Premier Pro - Sophisto Grey
Past Cars: X3 M40i, 330d MSport, 125d MSport
      11-03-2021, 10:52 AM   #17
gray1x
Drives: BMW X3
OK so I have pretty much all the assistance options switched on. Let's say I am on the motorway I activate both lane assist and speed assist so the car is now steering itself in the left lane at 70mph and if the icons on the dash are green I don't have to do anything.
If i approach a car in front I indicate (full press) and the car moves out on it's own. i usually turn off the indicator when the lane marker is under the car. It then finds the new lane and carries on.
Same to go back to the left, indicate fully and it moves back
I'll have a look at the settings to see if there is anything there
      11-03-2021, 10:58 AM   #18
Zumbug
Yeah mine is definitely not doing that.
On https://www.mdecoder.com/ do you have S8TR - Decoding Additional Functions ?
      11-03-2021, 11:08 AM   #19
the_ape
Hope it works properly on mine when it get's here, as mine is a Sophisto Grey too.
My decode comes back.....
Editions And Packages
S7EZ Impressive
S7M9 Individual Option High-Gloss Shadow-Line
Comfort And Interior Equipment
S413 Luggage Compartment Net
S420 Sun Protection Glazing
S423 Floor Mats Velours
S430 Interior/Outside Mirror With Auto Dip
S431 Interior Mirror With Automatic-Dip
S481 Sports Seat
S488 Lumbar Support, Driver And Passenger
S494 Seat Heating Driver/Passenger
S4K9 Inter.Trim Finishers Aluminum Fine Cut
S4T2 LADEKABEL PROFESSIONAL (MODE 3)
S4U0 Electroplat.Cover/Clip F.Operat.Elements
S4U9 Acoustic Pedestrian Protection
S4UR Ambient Interior Light
S4V1 BMW ICONICSOUNDS ELECTRIC
Multimedia
S610 Head-Up Display
S654 DAB Tuner
S688 Harman/Kardon Surround Sound System
S6AE Teleservices
S6AF Statutory Emergency Call
S6AK Connected Drive Services
S6C4 Connected Package Professional
S6DR BMW Drive Recorder
S6NW Telephony With Wireless Charging
S6U3 BMW Live Operating Area Professional
S6U8 BMW Gesture Control
S6WD WLAN Hotspot
Driver Assistance And Lightning
S534 Automatic Air Conditioning
S552 Adaptive LED Headlight
S5AC High-Beam Assistant
S5AL Active Protection
S5AU Driving Assistant Professional
S5DA Passenger Airbag Deactivation
S5DN Parking Assistance System Plus
Wheels And Drive
S223 Adaptive Suspension
S230 Extra Package, EU-Speciifc
S2PA Locking Wheel Bolt
S2VB Tyre Pressure Display
S2VC Tyre Repair Set
Environment And Safety
S302 Alarm System
S322 Comfort Access
S3DE Omission Of Specific Design Scopes
S3KA Acoustic Comfort Glazing
S3MC Indiv.Roofrailing,Mirror-Fin.Shadow Line
S812 National Version England / Ireland
S853 Language Version, English
S880 On-Board Literature, English
S8R9 Refrigerant R1234yf
S8S2 Coding, Alarm Signal
S8S3 Automatic Locking During Starting
S8SM Car Ident. Number Visible From Outside
S8TF Active Pedestrian Protection
S8TG Thiefproofing Device
S8TR Decoding Additional Functions
Individual Equipment
S760 High Gloss Shadow Line
S775 Headlining Anthracite
Other Equipment
S1V7 BMW Lt-Alloy Wheel Aerodynamic 843 JB/GG
S925 Dummy-SALAPA
SA050 50 Ah AGM Battery
      11-03-2021, 03:16 PM   #20
gray1x
Drives: BMW X3
Yea it does have that. Under Other it also has this
S9QX Preparation Driver Assistance
Which the other poster didn't have 🤔
But it also says my car is Left hand drive so I'm not sure it's wholly reliable 😂
      11-03-2021, 03:25 PM   #21
the_ape
Yeah mine is LHD too 😂
      11-03-2021, 04:17 PM   #22
Zumbug
Yeah mine does not have S9QX.
Mine says LHD too, def not accurate
