11-14-2021, 09:45 AM | #1 |
Rep 64
F16 is not as stable on high speeds as e71
I moved from 2014 e71 50i to 2015 f16 35i. I do not feel safe when I drive fast. E71 seemed more sticky on the road. Turning wheel on high speed was more stable on e71. Rim size same. Tire size and brand same. Run flats. Who had both cars, how you feel it?
11-14-2021, 10:28 AM | #3 |
Rep 485
I was shocked when I tried to follow the fast cars on the autobahn. My 14 X1 s28i was all over the road nearing 120 mph. It has staggered 8x18 and 9x18 M sport.
Looking at specs the front track is about 1.1 inch shorter, so I put 12mm spacers on FRONT only. That allowed car to top out. I think the ediff was also involved and when I put less grippy ceramic on rears, all the sway stopped. |
11-14-2021, 01:01 PM | #5 |
Rep 2,362
Drives: G87 M2; E92M3 MT&DCT; M3 euro
Also has to do with hydraulic vs electric power steering I would assume.
Pass me if you can.
Germanauto9708.50 |
11-14-2021, 01:48 PM | #7 | |
Rep 64
Is it shorter than e71's? E71 was 200kg havier. So I thought f16 would be better but I was not right. Now searching reasons, why e71 stands on the road better than f16. |
11-14-2021, 01:52 PM | #8 | |
Rep 2,362
I recall reading an article that stated their customers (probably female drivers) complained that BMW steering was too heavy and direct so they took most of that out in the F generation.
Pass me if you can.
11-14-2021, 02:07 PM | #10 |
Rep 2,754
the key of the e71 and 70 M as a base option against usual E70 was rear differential with torque vectoring
but int f16 this differential is optional
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
11-14-2021, 02:17 PM | #11 |
Rep 64
My f16 is 4x4 too. M packet. E71 was not m packet, was simple 50i. No electric things, no air suspension and so on.
11-15-2021, 12:46 PM | #13 |
Rep 2,754
4x4 is not coming with torque vectoring differential by default in f16
11-15-2021, 12:59 PM | #14 | |
Rep 64
And I think torque vectoring is not problem in my case. It moves right and left on higs speeds more than e71. In e71 this option was optional? Last edited by Bmwlover x; 11-15-2021 at 01:09 PM.. |
11-15-2021, 01:00 PM | #15 | |
Rep 3,648
You could do some lowering springs, maybe just something conservative. I did the Eibach pro kit and it reduced some of the bounciness/sloppyness that comes with the stock ride/standard suspension. |
Germanauto9708.50 P111573.50 |
11-15-2021, 02:04 PM | #16 | |
Rep 2,754
and e70 x5m also had this differential but for f16 this differential became optional, only if owner will order it specially, it will be installed on f16 you can check it's by decoding options list by VIN
11-15-2021, 02:14 PM | #17 | |
Rep 64
11-15-2021, 03:12 PM | #18 |
Rep 6,086
G05 X5 is trash as well.
E70 was a solid feeling tank. A product of a bygone era of BMW which will never return.
Former
-2008 E90 328 black/brown -2012 Lexus IS250 black/black |
11-15-2021, 03:45 PM | #19 | |
Rep 894
My e82 ate through rear tires...one set a year. My F32 doesn't have that problem but also doesn't feel as connected with the road.
11-16-2021, 04:08 AM | #21 |
Rep 2,754
you need option 2VP
or package which contains 2VP https://f15.bimmerpost.com/forums/sh....php?t=1417520
Bmwlover x24.50 |
11-17-2021, 09:24 AM | #22 |
Rep 11,136
Agree. The E70 was a tank. The F15 lost quite a bit of that. Drove the G05 for a few weeks over the summer and it disappeared altogether. It's a comfortable SUV with plenty of creature comforts. But there is nothing sporty about it anymore.
Germanauto9708.50 |
