      08-30-2013, 06:58 PM   #1
Jaymax85
Addicted to Speed.
Jaymax85's Avatar
Drives: m3 zcp, macan GTS, f15 x5
Calling all you dentists..
Due to some unfortunate trauma, I have a minor chip in my front tooth, id say about 1/10th of the incisor, the lateral tip.. is chipped. It is not displaced at all, but slightly loose to firm push, it is definitely not gonna fall out... From what I read, I just need to eat soft food for a couple of days and see a dentist to fix the chip... My assumption is it will tighten up on its own.
Are these assumptions correct? Input is much appreciated.
thanks
jawwad
2017 991.2s
2015 F15 35i
2017 Macan gts
      08-30-2013, 07:02 PM   #2
///M3NACE
///M3NACE's Avatar
168
Drives: E36 M3, E36 Vert , E90 N52
Your brown like me im sure they're plenty of dentist you know.
      08-30-2013, 07:04 PM   #3
Jaymax85
Addicted to Speed.
Jaymax85's Avatar
Ive seen ur car at foundation, thought u got an e92 m3.
2017 991.2s
2015 F15 35i
2017 Macan gts
      08-30-2013, 07:27 PM   #4
///M3NACE
///M3NACE's Avatar
168
No currently I have an e36 M3 vert and my e90 non m. Yeah im there sometimes.
      08-30-2013, 07:41 PM   #5
Boxtyp3
Boxtyp3's Avatar
Philippines
78
Drives: 2015 F32 MG
2015 F32 435  [0.00]
2002 E46 cp  [0.00]
2010 E82 135i  [0.00]
2013 E92 335i  [0.00]
You might wanna go to your dentist to have it splinted if it's loose while the alveolar bone reconstruct and stabilize the tooth. Discoloration might follow if the trauma is that bad and if that is the case, you probably need an RCT.
      08-30-2013, 07:43 PM   #6
upstatedoc
I'll get back to you
upstatedoc's Avatar
7562
Drives: blue streak
theres already a dentist thread in ot.
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/
Countermeasure enthusiast.
      08-30-2013, 07:56 PM   #7
Jaymax85
Addicted to Speed.
Jaymax85's Avatar
I called my buddy up who is a dentist and he recommended to just eat soft foods for a couple of days.. its really not that loose.. so im gonna follow that! thanks guys
2017 991.2s
2015 F15 35i
2017 Macan gts
      08-30-2013, 07:56 PM   #8
Jaymax85
Addicted to Speed.
Jaymax85's Avatar
I used to frequent there before i moved, had a modded 04 blue sti.
2017 991.2s
2015 F15 35i
2017 Macan gts
