02-15-2020, 07:40 PM | #1 |
Rep 429
OEM 21" runflats - how bad are they in snow?
Hi folks! About to take ownership of a 2018 M40i with 13K miles on the clock. Dealer installed new runflats on the 21" rims. Car is in Dallas but I'm shipping it to me up in Wisconsin where it snows! Now I don't anticipate driving in snow if I can help it as I have another car I can take out and get dirty, salty, etc. But if I'm out in the M40 in snow, how terrible will traction really be if I take it easy? I'm used to winter driving and my car is a FWD older Camry. Is it going to be worse than that?
On another note, other than having winter tires mounted on the original rims, is there an all-season option to consider even if I go with a slightly different and more common aspect tire? Thanks! |
02-16-2020, 01:41 AM | #2 |
Lateral grip estimator
957
Rep 1,390
Yes, it'll be worse than your Camry.
On the flat. With any kind of incline it'll be much worse than the Camry. And if you can get it moving you won't get it to stop in a hurry!
02-16-2020, 02:21 AM | #3 |
Idiot-in-chief
31
Rep 218
Assuming you have a garage etc. to store them in, why not just buy a second set of rims (perhaps 19" for the increased tyre profile), fit them with winter rubber and swap wheels in the autumn/spring?
X3 F25 LCI 30d M Sport
Alpina Roadster S |
02-16-2020, 05:23 AM | #4 | |
Rep 429
I'd rather get winter tires in 21 mounted if I drive it in snow. The on/off charges would have to be really high to justify the outlay for a second set of rims. |
02-16-2020, 05:54 AM | #5 |
Rep 912
Welcome to my world and also recently retired (early) .....I do my own changeovers
Picking up an M40i with 21” tomorrow, then driving home 600km on hopefully cleared roads with the stock tires. Yesterday grabbed RTX Scimitar rims 19” for 140 Canadian each and ordered clearance winter tires for 700 CAD (Contis).. I’m sold on the benefits...and like the flexibility even if I don’t put a lot of miles on my X6M in winter up to now. Last edited by Bilbofraggins; 02-16-2020 at 10:36 AM.. |
02-16-2020, 08:56 AM | #6 | |
Rep 429
I'm hoping there's additional tire selection soon, if not in the original 245/275 aspect but even 255/285. I'm not opposed to a second set on smaller rims for winter but that kind of defeats the purpose of having the nice 21s for half the year. I personally think the larger wheel makes a huge difference in how the car looks and for those reasons, I'd rather stick with it. Heck, I'd even consider a mild all-season if there were a good one out there in that size. They will still be wide, but might have a better bite. If there's 8-12" forecast, I'm staying put. The next day, roads here are clear. |
02-16-2020, 09:01 AM | #7 |
Internet Weasel
769
Rep 763
Drives: 2023 X3 M40i
Very few options in the 21" size and none of them snows. Don't drive the car in the snow if you can avoid it.
chicagofan0019143.00 |
02-16-2020, 09:01 AM | #8 |
Stay Tuned!
297
Rep 390
I've lived in the snow country for years.
Get a winter beater. Don't drive the bmw in the winter. The salt in the snow will carve the front of your car. The salt will eat up every surface of the car. Regardless of whether you think they plow within a day, Assume they do not and there will be several days when you need to drive through 2 feet of snow. I have taught winter driving to 16yr olds (SCCA). Newton's law applies only when you have winter tires. Any other (ie your 21s that are hard as a rock because they are runflats) tires have little to no traction. The Blizzaks are soft in lower temps so that they can do what tires, not wagon wheels, are supposed to do. If you have winter (ie Blizzaks) tires your car is unstoppable. Watch the tire rack videos for proof where they drive em on an ice rink. The thing about Newton is....your car will go straight...always. It is only when you turn the wheel that you have problems. I.e. slow down well before turns. Use the engine, not the brake to slow most of the time. That said, I live in Colorado now. I have a set of winter tires for both of my cars (M40i and SQ5). I also bought winter tires for my Moms focus. The positive is that I have bought rims for these cars (used) for $100, $375, $1500, and $2000. Yes, I have six sets of rims and tires because I bought them when they were dirt cheap on Craigslist. The $1500 and $2000 were new rims and tires (the $1500 ones were from a 7-series and worth $6k). The positive is that there are a BUTTLOAD of cars that use the 5x112 bolt pattern. The newer BMW, Audi, and Mercedes do. If you are going to drive the bmw, get the Blizzaks. Thank me later. If I were in the area, I would take you out and show you! Paul |
nyalpine907433.00 |
02-16-2020, 09:58 AM | #9 | |
Rep 912
Rain39.00 |
02-16-2020, 10:02 AM | #10 |
Rep 912
The tires....on here are a Belgian brand called Minerva Ice-Plus S220....they lasted into the 5th winter before hitting 4/32nds...I just replaced them with same, I like them that much...690 CAD delivered....They have the rim protectors and are the correct speed load/ and XL rating...20" X5 Y spokes....with 10mm spacers on the rear....would still be slightly (-) offset from stock, but I prefer that...in winter...
02-16-2020, 10:18 AM | #11 |
Rep 429
Thanks, something to consider. My car won't be here for another 1-2 weeks so we're talking March. By that time, chance of snow is slight so I've got time to look. Maybe I'll keep an eye out for used wheels in a 19" or 20".
02-16-2020, 10:23 AM | #12 | |
Rep 912
http://www.rtxwheels.com/en/wheels/rtxwheels-scimitar https://www.1010tires.com/store/shop...155892&lang=en https://www.tiresandco.ca/car-tires/...-105-v-xl.html This is the time to pick-up winters... Last edited by Bilbofraggins; 02-16-2020 at 03:40 PM.. |
02-16-2020, 11:31 AM | #13 |
Rep 912
02-16-2020, 12:52 PM | #14 |
Rep 251
Question seems well answered but I’ll chime in to reinforce that at least the 21” altenzas (spelling?) that came on my vehicle are not good in snow/ice. I changed my from winters to the 21” stock last summer a few days before we got a snowfall. I make the same 90 degree turn followed by a short on-ramp lane to get up to highway speeds every day. Winters never noticed an issue, in fact nearly hard for the to get the x3 to break loose. That day with summers was like I was on ice. Car effortlessly fishtailed near sideways and then back n forth a few times. At first I thought it was just slick but after thinking more it was clearly a difference of the stock vs winter tires.
Maybe I rely too much on winter tires in the past few but I certainly wouldn’t trust the stock 21” altenzas In an Alberta winter. |
Bilbofraggins284.00 |
02-16-2020, 03:38 PM | #15 | |
Rep 912
02-16-2020, 05:22 PM | #16 |
Rep 251
Not only are the 21” stock Pirelli’s horrific in snow I’m sure, they are terrible in any inclement weather including rain. I nearly hydroplaned off the highway in them. I was astonished. The same type of rain and location that my Audi with Michelin PS4S would just plow through at a much higher speed while the vehicle weighs a thousand lbs less. I have a tough time believing the BMW AWD is that bad. I’ve hated the Pirelli’s I’ve had on every car. I’ve owned. The Audi handling became night and day. There are snow options for the 21”, but no all season, even when going to 255/285. They are all summer tires. I’m going to at least try the Bridgestone RFT next time. I would like to move to PS4S but I don’t like the idea of no spare and not runflats in a vehicle my wife drives primarily.
02-16-2020, 06:10 PM | #17 | |
Rep 429
02-16-2020, 07:27 PM | #18 |
Rep 245
Not true.... these are available now:
https://www.tirerack.com/tires/tires...i&autoModClar= Almost went with the 20s due to no winter tire choices, but these look like a good option so went for the 21's instead... |
dmicah769.00 |
02-16-2020, 08:43 PM | #19 | |
Rep 429
PostModernHero143.50 |
02-16-2020, 11:31 PM | #22 |
Rep 599
I have owned bmw X5s with 20s before my X3 and they had all season tires. While not the best they still performed good enough for me to want to take my car out in the snow and have some fun.
I thought the X3 would be no different. It was a horrible experience and I refuse to leave the house if it snows. I couldnt even make it up my driveway without sliding and this was with half inch of snow. Terrifying actually. |
