06-10-2021, 07:47 PM | #1 |
Rep 123
Square setup - 20" wheels
I just ordered a 2021 X4 M40i with the 20" 699M staggered wheel.
After having read for hours on this forum, I would like to move to a squared setup. I have never had a car with a staggered setup and was curious if this wheel/tire combination would work on all four corners. Wheel Size: 20x9 Offset: +40 Centerbore: 66.56 Bolt Pattern: 5x112 Machined Black Outline OE Center Caps Interchange Tire size: 255/45R20 Thanks for any help. Last edited by newtoncd8; 06-10-2021 at 08:04 PM.. |
06-10-2021, 08:10 PM | #2 | |
Rep 66
06-10-2021, 08:40 PM | #3 |
Jumping Jack Flash
322
Rep 1,692
Drives: 2021 X3 M40i
I'm interested in opinions on this as well. I have a perfectly satisfactory square setup on my 2021 X3 M40i now, but my wheel size is 19". In the future I will likely buy some aftermarket 20" and put some non-run flat Michelins on them, and reserve my 19" for snows or modest all-terrain tires.
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al. |
06-10-2021, 10:44 PM | #5 |
Rep 69
https://x3.xbimmers.com/forums/showthread.php?t=1708286
Here is my 20" square setup. |
06-11-2021, 01:26 PM | #6 |
Rep 744
BMW sells a square 20" setup as winter tires.
You will get 8x20 wheels with offset 27 and 245/45 tires. So in general it's no problem and in regards to the xdrive even better than a staggered setup as you can rotate front and rears to keep all wheels evenly worn. |
06-11-2021, 02:57 PM | #7 | |
Rep 123
08-02-2021, 11:27 PM | #9 |
Rep 323
The stock 19" setup from the factory is square. Specs are 245/50ZR19 tires on 19x7.5 ET32 wheels.
Having seen M40is with that setup there's a lot of room between the tires and the fender. You could go much wider for the wheels and tires but would have to be a more aggressive (lower) offset. Clearance to the upper control arms is pretty tight on the stock wheels. Also the front wheels' clearance to the fender liners at full lock might be a concern if they're too wide. |
08-03-2021, 05:11 AM | #10 | |
Crusty Old Navy Chief
22558
Rep 1,696
https://www.willtheyfit.com/index.ph...8-5&offset2=30 |
08-03-2021, 12:06 PM | #11 |
Rep 323
08-03-2021, 02:05 PM | #12 | |
22558
Rep 1,696
I would do 20" and probably will trade my 21" for 20" Last edited by JJ 911SC; 08-03-2021 at 02:11 PM.. |
08-03-2021, 04:59 PM | #13 | |
Rep 323
