11-06-2019, 06:45 AM | #1 |
Rep 2,073
Front tyres "skipping"
When I'm manoeuvring at very low speed on full or close to full lock I find the front tyres "skip" or jump a little as though the amount of lock is too much for them.
Is this typical? I hope it's not like the Merc GLC right-hand drive issue....
11-06-2019, 07:22 AM | #2 |
Rep 187
Drives: BMW X3M Comp
Happens with my X3MC... I assumed it was normal due to the weight of the car, only happens when I'm on an incline from standstill whilst turning
11-06-2019, 09:36 AM | #4 |
Rep 2,073
Thanks, that's sort of reassuring. At least it's not unusual.
11-06-2019, 09:45 AM | #5 |
Rep 62
I had a GLC 43AMG and it loved to Crab.... after a year or so, they replaced the tyres and it pretty much fixed it.. my X3M40i does not seem to show any of those characteristics... even on full lock..
Current - MY2020 X3 M40I - Sapphire Black with Oyster leather. M Sport and Tech Pack.
Previous - GLC 43 AMG |
11-06-2019, 11:22 AM | #6 |
Rep 2,323
Drives: 9Y0 Cayenne S
Crabbing is related to drivetrain differential locking strategy and steering Ackerman geometry. Two different mechanical phenomena with similar symptoms and both related to vehicle design.
11-06-2019, 11:47 AM | #7 | |
Rep 32,881
11-06-2019, 11:59 AM | #8 | |
Rep 2,073
The P Zeros on my F25 didn't do this.
11-06-2019, 12:14 PM | #9 | |
Rep 32,881
11-07-2019, 02:28 PM | #10 | |
Lateral grip estimator
959
Rep 1,390
Anyone want more details? Google "Ackerman geometry".
chassis6621.00 X3M40i_Nev444.00 |
11-07-2019, 02:33 PM | #11 | |
Rep 65
Can i ask at what outside temp this happens? Greetz, Jurgen |
11-07-2019, 02:35 PM | #12 |
Rep 2,073
11-07-2019, 03:03 PM | #13 | |
Rep 32,881
11-07-2019, 05:21 PM | #14 | |
Rep 15,858
You mentioned in an earlier post you notice crabbing a more with worn tires. Less tread flex, (different tires will respond with more or less skip anyway) to absorb the less than perfect geometry. Same as tires could make a difference on the Mercs. |
teaston10998.00 |
11-08-2019, 12:29 AM | #15 |
959
Rep 1,390
All my 911's have done this too - when doing full lock turns, there is always some skip. Combination of Ackerman and limited slip diff.
11-08-2019, 01:16 AM | #16 |
Rep 2,073
Does it chew up the tyres? Thinking about it my F25 did it on occasion. The G01 does it every time I reverse out of my drive. Twice...in reverse and then when driving off.
11-08-2019, 01:44 AM | #17 |
Rep 32,881
11-08-2019, 03:03 AM | #18 |
Rep 2,073
11-08-2019, 03:32 AM | #19 |
Rep 32,881
But it's the front wheels that skip, and the LSD is only on the rear isn't it?
11-08-2019, 11:44 AM | #21 | ||
Rep 15,858
According to BMW blurb on xDrive function, permanent all-wheel drive is cancelled in 3 control cases: This is one of them.... (the other situations are high speed and severe understeer). Quote:
teaston10998.00 |
11-08-2019, 12:59 PM | #22 | |
959
Rep 1,390
Net result is that it forces the car to understeer more than it would otherwise. Much more noticeable on lighter cars like the Atom, but even so it's still a factor in heavier cars. And much more noticeable in cars with Ackerman geometry at low speeds (having added limited slip diffs to various cars which came with open diffs!).
teaston10998.00 |
