      06-27-2019, 04:09 PM   #1
PARTS@STBMW
PARTS@STBMW's Avatar
2702
BMWPartsPros.com l BMW G01 OEM TRAILER HITCH SET
The USA Trailer tow hitch retrofit kit corresponds to the trailer hitch special equipment (SA 3AC), but cannot be electrically pivoted in the USA.The trailer tow hitch is designed for trailer loads of up to2,400 kg and a nose weight of up to 100 kg. Following successful installation, the retrofit kit must be added to the car order by coding.
*Electrical Add-On Kit is required with the Trailer Hitch Kit.
LINK:http://bit.ly/THBMWG01
      10-22-2019, 08:14 PM   #2
SJTrance
Drives: 2002 Ducati 900 Supersport
How easy is this to install into the X3?
      10-23-2019, 10:01 AM   #3
PARTS@STBMW
2702
Hello and thank you for contacting BMWPartsPros!
This kit takes roughly around three hours to install and pretty easy to do with the correct tools.
We recommend a BMW shop to install this kit for warranty reasons and safety.
-Britney
      02-21-2020, 07:51 PM   #4
PerthBMW
PerthBMW's Avatar
Australia
219
Drives: 2019 X3 M40i
Hi
I see you note that a Electrical Add-On Kit is required with the Trailer Hitch Kit.
How much does that cost and what else is needed to have an operational tow hitch that is wired and ready to go?
Thank you
      02-24-2020, 11:16 AM   #5
PARTS@STBMW
2702
Originally Posted by PerthBMW View Post
Hi
Thank you
It is all based off your VIN and can vary in price.
Thank you,
-Britney
      12-05-2022, 08:59 PM   #6
junex6
Drives: bmw x6
will this fit x3m
      12-06-2022, 12:58 PM   #7
PARTS@STBMW
2702
Originally Posted by junex6 View Post
will this fit x3m
Hello,
This trailer hitch kit unfortunately is not compatible with the X3 M Models since the M models are not equipped with the wiring harnesses from the factory.
Best option for your model will have to be aftermarket.
-Brit
      08-24-2023, 01:09 PM   #8
70SS396
70SS396's Avatar
12
Drives: BMW 2013 X5, 2022 X3 M40i
Would a brake controller be required along with all items mentioned to pull a trailer with electrical brakes and is there a part number to this controller
Originally week 25, moved up to week 22, 2022 X3 M40i,
BGM/Tacora Red, deposit 4/13, ordered received 4/27, schedule for prod. 5/11, enter prod. queue 5/13, enter assembly line 5/24, waiting for carrier 5/25, carrier dispatched 5/30, picked up @ dealership 5/31 proDate 5/25,
      08-24-2023, 04:08 PM   #9
PARTS@STBMW
2702
Yes their is a control unit required only with this trailer hitch kit for any trailer you are pulling and not sold separately without the entire kit.
-Brit
