06-13-2022, 10:47 PM | #1 |
Rep 68
Possible to run 19” Aftermarket Wheels?
As the title says,
Wondering if it’s possible to run 19” wheels. I want to get as thick of a sidewall as possible to increase some of the ride quality. I don’t mind the current setup, but it’s a little stiff for passengers. Curious if anyones had luck in testing out a 19” wheel setup I know the spare is a 19” but I’m assuming it specifically designed to clear the brake calipers. Thanks |
06-14-2022, 06:58 PM | #2 |
Rep 487
Drives: 2019 Audi RS5 Sportback
Considering some of the non-comp models come with a 20" wheel. A 19" could be a possibility, but... if you have stock 21's and go to a 19 your speedo will be off by a decent amount.
06-14-2022, 08:23 PM | #3 |
Rep 4,703
Tire size can mitigate that, need to keep the overall rolling diameter close to factory spec.
06-14-2022, 08:27 PM | #4 |
Rep 467
Could be possible considering the spare is 19"
2022 X3MC
2020 330iX Daily 2002 R34 Mspec Nur -in Canada 2014 S4 APR stg1 444hp retired 2010 335d; 2004 WRX wagon; 1994 300ZX -retired |
06-14-2022, 08:27 PM | #5 | |
Rep 4,703
https://x3.xbimmers.com/forums/showthread.php?t=1866172 |
06-15-2022, 09:32 AM | #6 | |
Rep 68
Yup, Saw that one as the only example so far. Mostly interested to try and test out a nice and compliant 50 sidewall tire like a pilot sport all season to get maximum comfort out of the thing. Everything is pretty awesome about the car aside from the embarrassing suspension setup that is oversprung and is fairly boom-y. Currently on PS4S and will probably keep it as a summer tire. Mostly debating going MSS with maybe a tire swap to all seasons (since I don’t get to do a whole lot of track or spirited driving) or if I just go all in on a set of wheels and tires to really gun for the ultimate ride comfort with MSS as well. Wondering if there’s any more examples of a non TE37 working. Apex Race Parts has a 19”x9.5 5x112 wheel that seems like it could work. And I’ve fit a 19” on my old F80 from them, so would assume that the X3M brakes were maybe only a smidge bigger, but the f80 could actually run 18” stock on their brake setup. So I would assume 19” aftermarket’s are doable, just want to know if anyones tried it. |
06-15-2022, 09:53 AM | #7 | |
Rep 998
IIRC the F80 has 380mm rotors up front while the X3M utilizes 395mm. The barrel design and barrel clearance is going to be the biggest factor. TE37's are known to have a very slim barrel to accommodate big brakes. BC Forged will likely work as well since they are custom cut. I'm going to say most wheels won't work but a few here and there could. I ran into this same situation with my B9 S4 after adding a Brembo BBK. After reaching out to nearly a dozen wheel manufactures I realized it really comes down to a specific wheel that could make or brake it. (ha) I landed on Neuspeed RSe102 as they were the only ones that fit my situation. They have a nearly perfect barrel design to maximize space. Best of luck and report back with your findings please! A 19" confirmed fitment thread would be a game changer.
06-15-2022, 09:58 AM | #8 |
Rep 68
Additionally, not sure if this is a datapoint at all, but the f90 m5 is able to run 19inch wheels from factory, and I think their front brake rotors are the same size as an X3M.
06-15-2022, 10:01 AM | #9 |
Rep 998
Correct, same size rotor. They use a different caliper though, a 6pot I believe. Which is good news because that is larger than the X3M but it could come down to the design too.
06-15-2022, 10:02 AM | #10 | |
Rep 68
I’m going to call the BMW parts dept about possibly using a F90 M5 705M style wheel. In theory this could work. M5 brakes and calipers are nearly the same size as the X3M as we can even do a caliper swap with them. And they run a 19” from the factory. |
06-15-2022, 10:04 AM | #11 | |
Rep 68
06-15-2022, 10:09 AM | #12 |
Rep 998
Nice one. When I looked I was wanted a performance tire (PS4S or drag radial) which is why I gave up.
I'm sure Apex could provide some specs on their 19x9.5 too and you could create a cardboard template to test clearance. I saw one of theirs is on sale for pretty cheap right now
06-15-2022, 12:35 PM | #13 |
Rep 1,052
Drives: 2022 X3MC; 2012 M3 Cabriolet
Watching this, too. Not to solve a ride-quality issue, but thinking that smaller size tires would be cheaper for burning-down on Track Days.
The price difference and availability of 18" vs 19" tires on my M3 E93 was significant...i.e used a Hankook 18" for $110 vs Cont Extr Contact 19" for $250.
2022 ///X3M Competition; São Paulo Yellow
2012 ///M3 Cabriolet; Le Mans Blue Metallic. >177k miles and still rocks! |
06-15-2022, 07:44 PM | #14 |
Rep 1,270
Drives: 2024 BMW M4 Base
I don’t mean any offense but why buy an X3 M if you want your passenger to have a more comfortable ride? The only thing I can think of is you passenger is your significant other who finds the ride harsh 😉
19’s make perfect sense for winter tires and if you know your going to be burning through tires. Maybe I’m lucky but my wife loves the ride quality. She hated in on the 21 M-Sport and she was OK with the M40i but like the ride on the X3 MC best. |
06-16-2022, 10:50 AM | #15 |
Rep 68
Yeah, my wife has now had many comparables of ride quality. B9 S4, f80 m3, RS3, and now the X3M.
Honestly, she’s a trooper. She gets car sick easily and we also tend to bring our dog in the car which are it’s own headaches (still worth it!!!). I would say that I find the ride fine. It’s for sure bouncy. No question. It is very easily unsettled by large road imperfections and we live right in the middle of downtown. I think getting 19’s would also be interesting for those curious about running lighter wheels. I’ll keep this updated with what I end up doing. |
