03-14-2020, 10:45 PM | #1 |
Rep 5,448
Any one DIY engine oil change?
I may change in between factory required changes. Which seem to be every 9000 miles
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
03-14-2020, 11:19 PM | #2 |
Rep 26
My friend whos been a senior BMW technician since 2009 said this is the first motor hes seen require a 1 hour oil change. At least what dealer charges. Something about the way the motor is mounted
03-15-2020, 04:07 PM | #3 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3509
Rep 4,206
To do an oil change on the S58 in the F97/F98 the repair instructions require that you remove the strut brace and the complete air box to access the oil filter. This is why the labor time for an oil change is higher on this vehicle.
03-16-2020, 11:08 PM | #4 |
Rep 5,448
Are those instruction on line?
03-16-2020, 11:10 PM | #5 | |
3509
Rep 4,206
03-17-2020, 12:08 AM | #6 | |
Rep 18,708
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
03-17-2020, 08:22 AM | #8 |
Rep 33
Current--2016 F31, 2007 997.1 Targa 4S, 1990 Landcruiser LJ71 JDM
Past--2007 E91, 2008 E60 550M |
03-17-2020, 08:51 AM | #10 | ||
Rep 33
03-17-2020, 10:20 AM | #11 |
Rep 2,956
I just got mine done last week as we get free maintenance for the first four years but I shudder to think about what dealers will charge for this.
03-17-2020, 07:02 PM | #12 | |
Rep 3,924
03-19-2020, 02:25 AM | #14 |
Rep 5,448
yes I have done that too
03-19-2020, 02:29 AM | #15 | |
Rep 5,448
03-23-2020, 02:07 AM | #17 |
Rep 5,448
So it seems pretty easy to change the oil although no one has posted any procedures about that. Seems the oil filter is another problem although if you have factory service you can change the oil in between
03-23-2020, 03:20 PM | #18 |
Rep 2,221
Wow that is one hell of a procedure.
It seems like it would be a good idea to measure the oil coming out in one of those pails with increments on the side so you can put that exact amount back in. |
03-29-2020, 02:36 PM | #19 |
Rep 67
DIY oil change just completed. It's straight forward and doesn't require removal of the airbox unless you have large forearms. I was able to change the filter with the airbox in place. Make sure you loosen the oil filter housing completely and allow the oil to drain out for a few minutes before removing the housing/filter assembly to avoid making a mess. The oil drain plug is probably one of the most easily accessible I've ever come across.
03-29-2020, 03:48 PM | #20 | |
Rep 33
03-29-2020, 04:17 PM | #21 | |
Rep 2,221
03-29-2020, 07:25 PM | #22 | |
Rep 67
It's similar to most vehicles oil change procedure. Filter is element style. |
