11-20-2022, 08:12 PM | #1 |
Rep 348
Yellow CS DRL’s installed…but not without issues
So after a couple days of working between my kids wake windows and I got some yellow DRL’s installed. Fun part about an X3 LCI? You need to completely remove the headlights to do the install. If I knew, I probably wouldn’t have gone all in. But being halfway done, I proceeded to pull the bumper and pull the lights. Everything was looking great until I used the turn signals for the first time. Boom, low beam failure. Then I tried the high beams, failure there as well and the low beams then turned off.
So, what’s next? The manufacturer is working to determine what the difference is between the OEM and aftermarket circuit board. I’m not sure how many more times I’m willing to try this, but allegedly I’m likely getting new boards possibly. So, looks are 12/10 for sure, but pulling lights and bumper on a $69k car? Not the most fun, especially when you gotta do it more than once. View post on imgur.com
‘22 X3 M40i LCI
11-20-2022, 08:33 PM | #3 |
Rep 348
11-20-2022, 09:45 PM | #4 |
Rep 2,115
After i saw this video on F car, i decided against the same on G. Wish would have been simpler as in the days of E cars angel eyes.
ocdx30.00 gofastbmw5100.00 |
11-21-2022, 09:56 AM | #5 | |
Rep 70
11-21-2022, 10:16 AM | #6 | |
Rep 348
12-10-2022, 05:02 PM | #7 | |
Rep 130
The DRL seems to stay on though but in a low powered state where it is not as bright as the left side. I take it there is just some issue with the icedrivers and when you re-installed the OEM DRLs the low/high beam works again? |
12-10-2022, 05:18 PM | #8 | |
Rep 348
12-10-2022, 06:32 PM | #9 | |
Rep 130
Interestingly for pre lci we only have 1 board for each side that lights up both drl bars yet we both have the same issue. Now I just need to find a shop that won’t charge me outrageously for labor. I had many shops decline to do any aftermarket work and the one I ended up using for original install charged me $600 (4hrs at $150/hr) because it took “longer than expected”. |
12-11-2022, 11:53 AM | #10 |
Rep 53
Godspeed to you!
I remember back in 2009 I spent 18 months troubleshooting my FA5 with quad retrofits. It was painful but worth having the power of 4 suns lighting the roads ahead. These look absolutely baller and on an X3 you’ll be quite unique! Hang in there! |
12-11-2022, 12:35 PM | #11 |
Confused
123
Rep 103
Drives: 2019 X3 M40i
Supa-Clean Thanks for being the test subject, these seemed really cool but a pain to diy.
Curious, was the Board layout/pinout relatively similar to the OEM ones when you pulled them out? I tried peeking at the oem part but not too many detailed ones online to compare to your pictures of the aftermarket ones. I don't know if the boards have slightly different components that would be enough to throw it off. For there to be low/high beam errors I'm not sure why the DRLs would affect that. I wonder if it's related to the LCI vs pre-LCI lights being different in behavior. If the seller doesn't have any input I would order them to try on a pre-lci to see if I ghet similar issues. You ordered Yellow or RGB?
@G01_M40i | 2019 X3 M40i - Vossen HF-5 | MHD Stage 1 | xHP Stage 3 | MST Intake | (not fast enough)
12-11-2022, 03:01 PM | #12 | |
Rep 130
The boards are similar but they are not the exact same. I have no clue why it throws off lowbeams but I my wild guess would be bmw's systems detecting a non-OEM LED board and turning off the headlight to make you take it in for inspection and replacement with oem board. I got only yellow b/c I didn't want the extra wires for the RGB controller |
js_orifici122.50 |
12-11-2022, 06:55 PM | #13 | |
Rep 348
12-11-2022, 07:44 PM | #14 | |
Rep 130
I saw on the M4 CSL the DRLs are white when low beams are not on and turn yellow when low beams are on... best of both worlds. |
12-11-2022, 08:17 PM | #15 | |
Confused
123
Rep 103
I wonder if this is related to the anti-dazzle decoding the US cars are forced to get optioned. I know that correlates more to the high beam behavior, but that's the only thing I can think of that would affect the lights that's different from non-us cars
12-11-2022, 10:14 PM | #16 |
Rep 336
This makes me nervous haha but my IND motorsport+ yellow modules should be here soon, hopefully the install goes off without a issue.
lakerzfan_24695.00 |
12-12-2022, 12:39 PM | #17 |
Rep 130
12-12-2022, 12:47 PM | #18 |
Rep 1,567
Drives: 2022 X3 M40d LCI
@spaceman12 ,RGSport also does them, give Ben a message on here. r33_RGSport
12-12-2022, 12:52 PM | #19 |
Rep 348
Seems like all of these people have the same suppliers. Would love to see proof of anyone in the US with working yellow DRLs on an LCI. People say the sell them, but no proof of anything actually working as intended.
12-12-2022, 08:20 PM | #20 |
Rep 24
I saw a video of TJHunt's YouTube Channel were he installed the circuit to turn both headlights DRL yellow, and he succeded. I dont have the link, but it was on a BMW G82. I'm not sure if it's the same thing.
12-13-2022, 12:06 PM | #21 | |
Rep 8,104
Drives: 2024 X5 M60i
Looks like a totally different setup for the X3s though.
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
wdeerfield2757.00 |
12-13-2022, 05:49 PM | #22 |
Rep 348
chicagofan0019299.00 |
