04-03-2024, 05:45 PM | #1 |
Rep 30
Drives: 2019 X3 M40i
2019 X3 M40i battery replacement
My BMW shop quotes me $750 dollars to replace the battery. Is this how much it costs? This is the first time I am replacing the battery
04-03-2024, 07:17 PM | #2 |
Rep 7,529
Yes, if you don’t have any tools & confidence to pick up the battery from their parts dept and install and register the battery yourself.
When I replaced the battery in my F06 650ix GC back in Jan/2023…the 105AH battery cost $227 with my BMW CCA discount and core charge return. Every other battery cost more out the door. And the BMW battery from my local dealer’s parts department came with a little baggy adhered to the side that had a replacement little black elbow (used to hook up the car’s vent tube to the vent hole in the batter…and also came with an additional plug to insert into the other vent hole on the other side that prevents off gases from escaping into the enclosed battery compartment).
ContactPatch2172.00 |
04-03-2024, 07:57 PM | #3 | |
Rep 280
Drives: 2019 X3 xDrive30i, 2021 X3 M40
"Dealership vs Independent Shop – At a BMW dealership, battery replacement typically costs $300-$400+ for parts, labor, registration and programming. Independent shops will often charge $100-$200 less for the same job." https://bmwinsights.com/bmw-battery-replacement-cost/
Present: 2019 X3 xDrive30i, Mineral White/ Mocha Vernasca / 21" 701M and 20" Savini Black wheels / RaceChip
Present: 2021 X3 M40i, Alpine White / Oyster Vernasca / 20" 699M Former: 2006 Z4, 1981 320i, 1973 2002, Jag XKE, SS396 Chevelle, 440 Dodge RT, 40+ others |
04-04-2024, 08:34 PM | #4 |
Rep 193
I was quoted about $800 at the dealer, after they confirmed that the battery sells around $270.
Absolutely a rip off. Only thing you need to spend sometime or a bit money on is reprogram and register the battery after replacement, which you can usually do with a quality ENET scanner that costs $100 and useful for numerous purposes in the future. |
04-05-2024, 12:56 AM | #5 |
Senior Chief (Ret.)
72
Rep 185
Drives: '90 M3, '05 ZHP, '24 X4 M401
Wondering if replacement of battery with non-BMW batteries void any of the warranties?
1990 M3
2005 ZHP 2024 X4 X40i SCPO SW USN (ret) BMW CCA 192742, NRA Life Member, F&A M |
04-25-2024, 07:05 PM | #7 |
Rep 897
What? That's insane. Do this yourself and save a ton.
I just ordered a Group 49 H8 battery (our size) off of Amazon for $144 delivered. Was here in 3 days. Should take all of 20 minutes to install Saturday morning including coding it with Bimmerlink (free). If I needed a coding dongle it would have been another $60. Edit - I had to use Bimmerlink to register the new battery and Bimmercode to code to new amp level... so costs perhaps a bit higher if you dont already have Bimmercode and a dongle. Last edited by Murf; 04-27-2024 at 04:37 PM.. |
