04-13-2024, 08:22 AM | #1 |
Rep 36
I have everything installed but I am absolutely stumped as to how to get through the firewall.
On all the install videos and guides there is a free space with a rubber grommet to the right of the brake booster, I don’t have that. The only thing I have is on the right hand side there is a black cable going through but it doesn’t feel like there is enough space to get the JB4 OBD connector through there. Any advice? |
04-13-2024, 10:21 AM | #2 |
formerly rdougherty85
507
Rep 459
If you push on that circled area from inside the car, that should be it. Also, if you already have the OBD connected to the JB4, you'll have to disconnect it and feed the wire (not the plug, won't fit) through that hole.
X3rd Time Is a Charm2821.50 MFschwifty63.00 |
04-16-2024, 12:12 PM | #3 |
'24 X3 M40i
Rep 20
Is your model 2024? I have the same year and had the same issue. The hole in the firewall is simply missing. I ended up tucking around the fender/door.
Cabin side firewall Engine side firewall. You can see a scratch where I tried to push using my wire fish rod. |
04-16-2024, 12:17 PM | #4 | |
Rep 36
I tucked mine through the door jam and in the cabin. |
eljalapeno1.50 |
