05-01-2022, 04:31 PM | #1 |
Rep 998
My KW V3 Coilover Impressions on X3M Competition
It's been roughly two weeks now since I installed KW V3 coilovers on my X3M. I wanted to give myself enough seat time to get used to the ride before giving any impressions on them.
A little background, I've had my fair share of lowered cars. On springs, height adjustable springs and JDM coilovers (BC, Tein, etc). The KW V3's are by far the best that I've experienced. My goal with the X3M was to lower it as much as I possibly could. This was my first SUV/SAV and I cannot stand how high they sit off the ground. The stock suspension is quite good in terms of comfort and handling but the wheel well gap bugs the hell out of me lol. So with the very limited options on this platform that landed me with the KW's. Ride Height: To achieve my ride height, I set the front struts to show roughly 0.75" worth of threads from max low and roughly 1.75" in the rear. The stance is nearly perfect. It looks aggressive as hell and currently does not rub at all. I may push my luck and see if I can go a touch lower, just to the very top of the tire. There is a ton of unnecessary and useless plastic that can be trimmed out of the fender-wells to ensure no rubbing so I may end up giving that a go. Damping Adjustments: The roads around me are incredibly shit so take this part into consideration in comparison to where you live. I can almost guarantee my damping adjustments wont apply to someone in FL with nice and smooth roads. The V3's have two way adjustments, Rebound and Bump. These took me a little while to dial in and if I'm being honest I still don't think I'll keep these where they are but they are like 85% of the way there. The best way I can describe it is; Bump/Compression- The amount of force applied to compress the strut. Rebound- The amount of force applied to extend the strut back out after compressing. "Clicks from open" means going to full stiff and dialing it back X number of clicks. KW Recommends: Front Axle- Rebound 9 clicks open / Bump 5 clicks open Rear Axle - Rebound 6 clicks open / Bump 5 clicks open For the time being I kept the same F:R ratio except went a little softer on each. I'm running: Front Axle- Rebound 12 clicks open / Bump 9 clicks open Rear Axle - Rebound 11 clicks open / Bump 7 clicks open These have felt really good for me in terms of comfort and maintaining tight handling. I did not want to sacrifice one or the other and I don't think this setup does. These will likely change as I'm always looking for improvements but it's a safe starting point for anyone interested. Comfort & Handling: In terms of comfort I think of two things; 1) How well does it do absorbing rough roads and 2) how well does it rebound from those bumps. If I had to quantify these two, I would say; - 1) it absorbs bumps just as good as the OE competition suspension, maybe 5-10% better, even at the ride height that I'm currently at. I'm sure it would be a little softer if you don't go this low. - 2) it rebounds 20-25% better than the OE competition suspension. I found the damping and rebound on the stock suspension can be very bouncy and rough at times. This is not like that. It is a very pronounced up, down and settle. I'm sure this can be improved even more with fine tuning the rebound adjustment further. I'm not an expert so I'm taking this solely based on what I've felt along the way. The handling on the OE competition suspension was already very good. It's hard to keep tight characteristics on this size of vehicle but BMW did a great job with that. However, it did get that much better. The car feels incredibly direct and connected. It's like a point and shoot type of feeling anytime I want to enjoy a spirited drive, regardless of the iDrive steering settings. The car feels like it's magnetized to the ground. The body roll is virtually non existent now and corners can be taking with confidence. I truly didn't expect this vehicle to turn out to be this good. Like I said this is my first SUV and my impressions of them have always been sub par in this category. Some of this has to do with the engineering behind the platform in general but KW nailed whatever they did. I've also experienced MSS springs and while they are quite good, don't get me wrong, they just aren't in this league. I think the damping control really set the KW apart. If all you want is comfort with a little lowering than MSS definitely makes sense but for those that want more and want to get the most of the suspension, handling and height; KW all the way. I'll circle back and reserve the next post for an update after say 3k-5k miles but thus far I am incredibly pleased. Enjoy a few photos!
20
mr.almeida58.50 thestimp966.00 Must_Go_FASTER493.00 Kevin_The_Clean13124.00 r33_RGSport12805.00 Vettethret661.50 hooligan_G016430.00 Radman_F97231.50 playswcars3612.50 Keefy1571.50 Max Well4692.00 RedX4MC153.50 ///minh564.00 tceasy0.00 Chubbiejones886.50 Archiller3.00 mcanzio75.50 E92M3GT101.00 BeaminF9775.00 Cmond136.00 |
05-01-2022, 06:26 PM | #3 |
Rep 4,182
badass M3 wagon bro
KWV3 are awesome. had it on my M4 'vert slammed and ride was sweet as hell. enjoy her safely
-JLT- |
05-02-2022, 01:38 AM | #4 |
Rep 3,810
BrockDM I always wished that BILSTEIN had made an EDC kit upgrade for our cars so that we could dial in the settings with the touch of a button, but with a vastly improved ride. Guessing these are the next best thing and pretty much in the same league in terms of fine tuning damper settings and have more precise control of how the car handles. Very nice...
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
BrockDM2036.00 |
05-02-2022, 09:11 AM | #5 | |||
Rep 998
For the longest time I always thought I would be silly for deleting EDC but after a few platforms of only doing springs to keep the control I quickly changed my mind. I found that 90% of the time I left the car in one suspension setting as it felt better than the rest. Dialing in the adjustments to fit that one all around need has left me completely satisfied. I know it seems like a need for most people but I don't miss it one bit.
05-02-2022, 09:33 AM | #6 |
Rep 161
So, maybe a dumb question here. Since the OEM suspension has electronically adjustable struts, what happens when you remove those? Does it throw a code?
05-02-2022, 09:45 AM | #7 |
Rep 1,683
Yes, you'll need what is called an EDC delete kit to make it go away. The KW V3 comes with one. Plugs into the sensors to trick the car.
05-02-2022, 10:36 AM | #8 |
Joint Chiefs of Staff
23798
Rep 190,172
Looks great, thank you for the review
BrockDM2036.00 |
05-02-2022, 01:45 PM | #9 |
Rep 257
I love mine as well. I need to figure out how to adjust them though, the shop set them but I haven't made any adjustments. Great write up, great looking rig
23 X4M Comp
21X10 21X11.5 Vossen HF5, 285/325 MPSS, H&R springs, 11mm Spacers, RK Tunes intake, Armorextend AE Design Carbon Fiber Front Lip, Rachip GTS Black with XLR, ALi Baba cat back, Carbon interior... |
05-02-2022, 01:55 PM | #10 | |
Rep 998
The bump adjustments are fun ha. No additional knob to add on like rebound, there is just a dial on the bottom of the strut. The fronts are pretty easy but the rear are blocked quite a bit and require you to squeeze your fingers in there.
05-02-2022, 02:13 PM | #11 | |
Rep 257
I had to raise the rear a little as I was rubbing over large bumps since I have such an aggressive offset. My rears are at 28 3/4 from the ground to the top of the wheel well, where did you end up?
23 X4M Comp
05-02-2022, 02:38 PM | #12 | |
Rep 998
Vettethret661.50 Max Well4692.00 |
05-03-2022, 09:04 PM | #13 |
Rep 6,916
Looks great! KW's are the best mod for our cars!
r33_RGSport12805.00 BrockDM2036.00 |
05-03-2022, 09:05 PM | #14 | ||
Rep 18,628
I haven't seen one that is otherwise. Hope that help.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com March SALES!! Evolution Racewerks - Until 04/01 | PM for DEALS MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
kzg19691283.00 |
05-04-2022, 09:25 AM | #15 | |
Rep 998
So based on "full open" being full stiff, my adjustments should in theory be: Front Axle- Rebound 13 clicks open / Bump 7 clicks open Rear Axle - Rebound 9 clicks open / Bump 7 clicks open Am I on the right track now? I can update my first post if so.
05-04-2022, 10:45 AM | #16 | |
Rep 18,628
There is a push rod or needle that is closing and opening the hole where oil flows between the shock valves. Clockwise or tighten it, will push the rod / needle to close that hole so oil doesn't go through the valving, mean full stiff. While counter clockwise or loosen it, will loosen the rod / needle to open up the hole so oil will flow through, mean softer dampening. Rebound or compression uses the same system, just different mechanism. And there is manufacturing tolerance where the rod / needle is not exactly the same length. So, when you start at full open and dial it down clockwise to close, the rod / needle on one shock to another may not close the hole at the same gap. That's why, the coilover manufacturers always recommend to start with full close or stiff, then count backward. All the coilovers that I've installed or used in many many years being in this industry (HKS, TEIN, JIC, JRZ, Ohlins, Bilstein, DC2, Megan, etc) all using the same method. So far I haven't seen one that is using different method. Hope I able to explain that clearly.
05-04-2022, 10:58 AM | #17 | |
Rep 998
I really appreciate you chiming in!
r33_RGSport12805.00 x3mmhh16.50 |
05-04-2022, 03:59 PM | #18 |
Rep 1,495
Drives: 2022 X3 M40d LCI
It’s insane how good that X3M looks lowered on KW v3’s. The matching white cross brace ties it all together.
BrockDM2036.00 Vettethret661.50 |
05-04-2022, 05:45 PM | #19 |
23798
Rep 190,172
+1, must get mod for this car in my opinion
05-04-2022, 06:47 PM | #20 |
Rep 3,783
Looks awesome and I'm jealous on how low they get. One point though, I'm starting to not like 15mm spacers on the front of lowered X3Ms, and that includes my own car. It just pushes the wheel out too far and it looks weird from a straight on view (lots of tire tread visible). I think a 10mm might look better as the tire will be slightly tucked in the fender. Anyone else agree or am I insane?
05-04-2022, 11:43 PM | #21 | |
Rep 3,810
05-05-2022, 09:09 AM | #22 |
Rep 998
I'm running 15mm all around. They are definitely on the aggressive side but I think it's perfect for my liking
Kevin_The_Clean13124.00 x3mmhh16.50 |
