08-04-2020, 10:59 PM | #1 |
Car guy
1041
Rep 1,323
Any difference in ride quality between X3M and X3M Comp?
Can anyone tell me if there is a noticeable difference in ride quality between the X3M and X3M Comp (assuming they are both on 21's)? Also, is there a noticeable difference in ride between the 21's and 20's? Thanks in advance.
08-05-2020, 08:32 AM | #2 | |
Rep 71
I test drove a Comp but ended up with a non-Comp (both with 21s, although I did test drive one with 20s also). Biggest improvements in ride quality will be had from tires (and proper PSI settings on those tires!) and properly installed and adjusted MSS springs. |
08-05-2020, 10:13 AM | #3 |
Rep 3,817
I'm seeing a lot of people report that the Pilot Sport 4S ride a lot better than the Continentals. Unfortunately most come with the Conti's.
08-05-2020, 10:43 AM | #4 | |
Rep 5,874
As far as base vs comp suspension, I test drove a base with 21s and I don't think I could tell a difference but I wasn't chucking it around either. Comfort seemed similar. Supposedly it's just sway bar diameter increase in comp which to me changes the cornering and side to side bump sway comfort (or lack thereof). |
08-05-2020, 10:48 AM | #5 |
Rep 3,817
I think the difference would be felt on rough and choppy roads where the car gets skittish. Necessarily the Comp would have to have more aggressive tuning and that's where you'd notice it most.
08-05-2020, 10:58 AM | #6 | |
Car guy
1041
Rep 1,323
08-05-2020, 12:10 PM | #7 |
Rep 71
No, the 20s made very little difference. Honestly the best "bang for your buck" is just to lower the tire PSI a bit. I run 32 front, 35 rear. Made a big difference.
08-05-2020, 01:46 PM | #8 |
Car guy
1041
Rep 1,323
08-05-2020, 11:12 PM | #9 |
Rep 328
There's a difference for sure. Depends how much you care tho.
08-06-2020, 06:40 PM | #10 | |
Car guy
1041
Rep 1,323
Are there any other folks here that have the 21's and maybe a second set of winter wheels with 20's on them that can chime in? |
08-07-2020, 12:44 AM | #11 |
Rep 1,790
I can't speak with any experience with the X3M other than the fact my dealer gave me the following vehicle for a loaner while my X7 is being serviced. https://www.bmwnorthwest.com/new/BMW...966a44f4ed.htm.
Coming from my X7 to the X3M is like comparing apples with mushrooms. The X3M pretty much beat me to death driving the 105 mile trip from the dealer to home. Seattle streets made the ride almost unbearable. Even on I5 it rode like a go cart on everything but smooth asphalt. Concrete pavement was brutal as well. I'm guessing a lot of this has to do with the suspension and the tires. Plus, it's really not a fair comparison against an X7 which is way bigger and has air suspension. If you want a smooth luxurious ride and don't have the funds for an X7 don't bother test driving an X7 as it will be difficult to even consider an X3M after driving an X7. All that being said, if you want brute force in the power department no need to look further than the X3M. This baby hauls ASS! Instant and relentless power and punch. It was very deceiving driving the X3M. You think the thing is gutless in leisurely driving until you hit the gas pedal. Even from 80 MPH. It's a whole different driving experience compared to the X7. Since I do many road trips per year there is no way I could handle driving the X3M on an extended trip. It's just not that type of vehicle in my opinion. My 2006 Toyota Tundra 4WD rides better than the X3M. But for short trips and outright screaming fun on the fast track the X3M would be great. I was actually considering getting a X3 for my wife but now that I've driven one there's no way either one of us could handle the rough ride on anything but short trips. Just my 2 pennies worth with my limited experience driving the X3M. |
08-07-2020, 06:01 AM | #12 | |
Barge driver
8662
Rep 12,429
If ride comfort ala the 7 series or X7 is your want then any version of the X3M isn't going to give you that. For me the X3M doesn't have a harsh ride (it's just very stiff as a car all round) mine never bangs or crashes but what it does have is a low speed ride sub 30mph that is a bit comical especially over lumps and humps as it jiggles you about in the seat, I ran my G11 740 along side the X3M for the 1st 3-4 months and whilst the 740 was so much smoother I never walked out of the 7 and said I can't live with the M. Of course it really doesn't matter what anyone says as you need to go test drive one and make your own mind up as we all have a different POV on these things.
730d/Z4C
Max Well4787.00 Craig 1527232.50 |
08-07-2020, 06:17 AM | #13 |
Rep 3,817
More sidewall, tire construction and tire pressure are all things that can create a big difference in ride quality, but on the X3M they seem to be incremental improvements. This is because BMW went just a tad too firm on the actual suspension setup, so there's only so much you can do with that. That's probably why the MSS spring setup improves things so dramatically, because you're replacing suspension components.
08-07-2020, 08:55 AM | #14 |
Barge driver
8662
Rep 12,429
My 7 had less tyre wall running 20" than my X3M on 21" the tyre wall can only do so much and for me the meaty tyre walls (relatively) on the X3M do a good job but they can't overcome the stiffness of the car but that's what makes it fun to drive at higher speeds once it gets up on its toes.
730d/Z4C
08-07-2020, 09:42 AM | #15 |
Rep 64
I think the biggest issue is the X3M is over sprung in the rear. I think that BMW selected a spring rate that would handle a loaded cargo area. If you drive an X7/X5 with rear air suspension, it adjusts the spring rate based on the load. Mitch’s reference to a pickup is spot on. Pickups are notoriously over sprung in the rear so they can handle a heavy load. The X3M feels that same way. It is in the slow stuff (as Wills points out) that it feels jiggly. My Silverado pickup feels the same way. Putting the X3M in Sport Plus gets rid of that out of control feel, but it does change overall vehicle impact. I tend to keep it in Sport Plus because it just feels better to me.
AlexFL7838.00 |
08-07-2020, 10:36 AM | #16 | |
Rep 4,607
08-07-2020, 03:36 PM | #17 | |
Rep 5,874
AlexFL7838.00 |
08-07-2020, 04:28 PM | #18 |
Rep 3,817
We can't really have a meaningful or productive conversation when comparing the X3M to any X7 or any X5 beyond the X5M.
08-07-2020, 05:35 PM | #19 | ||
Rep 2,545
When I took my X3MC in for the CFRP diffuser install, I also needed an oil change and a minor software update, so they gave me the X7 40i as a Loaner. I had it for the day. A nicely appointed vehicle with lots of room and surely can get me from Point A to Point B, but I couldn't wait to get my X3MC back. I felt I was floating, and turns were ... My point is, both are great vehicles, but they fit us differently. There isn't a 'good one' or a 'bad one', just different ones. And fortunately all of us are different, which is probably why BMW and other Mnfrs have to make so many different models to capture our attention and payments. We left for a short 325 mile trip today, and I relish every chance I get to take trips now, something I honestly never did before. This X3MC, at least for us, has made the driving experience fun again. I'll try to download a few images from today's trip and post to the random photos thread when I get a chance. Apologies again, @TX3M, for going tangential on your question, but I felt the need to respond to his as it was literally the exact opposite impression for us. Let us know what you think after you have a chance to try both out. |
08-07-2020, 07:41 PM | #20 |
Rep 5,874
I'm heading out on a 700 mile round-trip long weekend getaway on Friday and super looking forward to it with no concerns over comfort. My passenger has never been in my car and drives a new Ford Ranger so will be interesting to get his perspective.
08-07-2020, 07:54 PM | #21 |
Rep 608
Yeah I drove to myrtle beach last weekend, about 500mi rt. No comfort issues at all (noncomp). Car wanted to cruise at 90+. Only time I've noticed anything is slower speeds with bigger road issues, you do get jostled a bit. That seems to be on both versions.
AlexFL7838.00 |
08-07-2020, 10:31 PM | #22 |
Rep 1,790
