11-14-2021, 09:43 PM | #2 |
Rep 992
Drives: 2022 X4 M Competition F98 LCI
Per the deletion and order threads, the 2022 MY G01/02 and F97/98 have 32Z - Deletion of Digital Key, which removes the NFC reader in the centre console and door handle, as well as disabling the Digital Key functionality. This is applicable worldwide for this particular model.
There has not been any further update currently, whether BMW will remove the deletion in future builds currently. This does not affect the iX3 (Europe and Asia only) however. This is also the only model not built in South Carolina. |
denniss397.00 |
11-15-2021, 10:28 AM | #3 | |
Rep 4,439
Drives: 2022 F97 X3M Comp LCI
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
11-15-2021, 04:57 PM | #4 |
Rep 1,755
11-15-2021, 05:14 PM | #5 | |
Rep 992
I have bought the wireless charger and NFC pad, just need the replacement cupholder and wiring (if the 6 pin connector is not there). I didnt get the replacement driver's side door handle with NFC yet however, since I'm not sure if its missing a wire or not on ours with 32Z (they added an additional wire for the NFC on the door handle)
Do keep in mind the one caveat we may have, and that would be activating digital keys. While we can get NFC cards potentially, they would likely have to be paired with the car having a valid ConnectedDrive connection to "validate" the NFC chip prior to use. So while we can install the hardware in our cars, the authentication process may not work as a result of the ConnectedDrive servers not seeing the vehicle capable of it. Therefore unless we know someone on the server side who can "remove" the deletion on their side, we may be stuck. |
11-16-2021, 09:35 PM | #6 | |
Rep 1,755
11-16-2021, 10:04 PM | #7 | |
Rep 992
https://x3.xbimmers.com/forums/showthread.php?t=1599217 However as mentioned, it will not be as simple as only hardware for the NFC Pad and Door Handle, and then removing 32Z - Deletion of Digital Key and coding in the modules in conjunction with Comfort Access. The Digital Key likely requires authentication from the ConnectedDrive server to do an initial activation for both the NFC card and iPhone/Android to authenticate the NFC chip to paired for one car only (NFC Card) or multiple cars (iPhone/Android.) I doubt BMW will allow an activation of an NFC Card without a ConnectedDrive server authentication prior, for security and exploit purposes. However if we're able to get their servers to "allow" the activation of Digital Key again, whether it'd be automatic or whether we need to speak with someone at ConnectedDrive that has the authority to reactivate the functionality for vehicles deactivated with them. |
01-25-2022, 10:26 AM | #8 | |
Rep 4,439
01-25-2022, 03:39 PM | #9 |
Rep 1,755
Hit a wall with the software, I have no way of "turning it on" in the BMW software. Was hoping someone would pick this up who is a little more attuned to diving into the cars systems. Everything hooks up fine, but car doesn't recognize or do anything once it is. Remote start is as good as it gets right...
01-26-2022, 03:21 PM | #10 | |
Rep 992
Also when you did the door handle replacement, did you need to fit a new harness in as well or did it just connect no problem with the extra pin? I'm also assuming for the NFC / Charging tray, you had to wire it in yourself? I'll probably attempt this in March, after I get the dash replaced under warranty (QC issue) |
01-26-2022, 06:43 PM | #11 | |
Rep 1,755
My guess is it is server side locked out though, most of bmws functions seem to be more cloud attached. |
Tim@codemybimmer579.00 |
01-27-2022, 09:48 AM | #12 |
Rep 1,457
Drives: 2024 BMW M4 Manual
Will this allow you to not have to carry the FOB? I can open and start my car remotely via the app so I’m thinking it must be to replace the fob?
02-01-2022, 03:58 PM | #14 |
Rep 74
Just came across this post in the X3 forum and looks like Digital Key is now available. Assuming we can get the HW sorted out, I am wondering whether BMW will offer to 'enable' this function with a SW update/$ubscription.
https://x3.xbimmers.com/forums/showthread.php?t=1895984 |
02-02-2022, 09:01 AM | #15 | |
Rep 4,439
03-22-2022, 02:24 AM | #16 |
Rep 22
Any news here?
I ordered the NFC/WC pad, wire loom and the new cupholder. Does someone know the part number for the door handle? Are they complete or just a part of it need to be exchanged? I guess they are not painted right? Only left driver or all of them need replacement? Thank you |
03-22-2022, 06:53 AM | #17 | |
Rep 4,439
ive contacted a few people who i regard as "masters" when it comes to coding and they say it simply isn't possible. i've given up all hope for a digital key retrofit on this platform.
thestimp1033.00 |
03-22-2022, 08:32 AM | #18 |
Rep 1,755
03-22-2022, 12:22 PM | #19 |
Rep 22
I know about MY22. Mine is a 22.
What is the reason that it should not be possible? I can't think that Connected Drive has to do something with it. Within the app i am also now able to open or close the doors. Or is there something additional that NFC has to do with? The NFC technology is from my point of view a simple "Near-Field" thing which shouldn't have to do something with connected drive?! |
03-22-2022, 12:42 PM | #20 | |
Rep 4,439
03-22-2022, 02:31 PM | #21 | |
Rep 992
Unless we know someone who works in the backend who's able to change the option code for our VINs to remove 32Z - Digital Key deletion and allow the provision for the digital key as a result, there's no way for us to get Digital Key to work. This is mainly due to ConnectedDrive acting as the authentication server to ensure, whether thru a NFC card or phone, that it's authorized to be used as a key for a particular VIN. So it acts like a credit card in that sense. Without communication to an authentication server, there's no way for the car to "pair" the key to the car even if it's fitted with the hardware. |
thestimp1033.00 |
03-22-2022, 04:12 PM | #22 |
Rep 22
OK understood.
But.. in the past all changes to the VO (when coded my F07) have been adopted into the BMW Servers if coded in VCM/MSM. I saw this with a friend who works as Master Technician at my dealer. The BMW Servers did contain the SoftClose- and SurroundView-Retrofits and they were able to update the car without errors. So would it not be possible if updated in VCM/MSM? And that the BMW Servers would adopt it? |
