08-06-2021, 01:47 PM | #1 |
Rep 25
Installed the MSS urban spring kit and thought I'd give some thoughts.
First about the car, it's a 2018 x3 m40i without dynamic suspension. I have the springs adjusted all the way low and have driven on them about 2 weeks now. On smoother roads and over small bumps the car rides relatively the same. You can definitely feel imperfections in the road but nothing more than with oem springs. Over larger bumps you can feel the reduced travel and there is definitely some added harshness/bounciness. For spirited driving it feels good with the lowered center of gravity but wouldn't say it's any stiffer than before. Steering feels better as well and seems more responsive than before. Overall, it rides great and if you've driven a lowered car before it's very similar. Link to install for anyone that wants to DIY: https://x3.xbimmers.com/forums/showthread.php?t=1791099 |
X3MTB58.50 cto31.00 bmwmdistrict908.00 sinbad4782.50 hooligan_G016430.00 Chief Orman671.00 lakerzfan_24695.00 DoubleZeroNineOneEight109.00 |
08-08-2021, 10:35 AM | #4 |
Rep 1,044
Looks amazing!
Rob | instagram
2020 F97 X3 ///M Donington Grey 2018 G01 X3 xDrive30i Alpine White Previous: 2016 F82 ///M4 Black Sapphire Metallic | My Build Thread |
tapx32.50 |
05-03-2022, 11:23 AM | #6 | |
Rep 197
05-17-2022, 01:04 PM | #7 | |
Rep 25
If you do go max low I would recommend leaving maybe 1 turn from the bottom in case you want to adjust it in the future. When I went to go adjust it the two collars were basically locked together and need a lot of persuasion to break loose from each other. For the install the rear is pretty straight forward after removing some of the interior to reach the top hats. The front is also pretty straight forward until you go to remove the strut assembly. The clamp on the bottom of the strut is very tight and needs quite a bit of force. After you get that loose as you move the strut out be VERY careful that the joint in the half shaft/axle doesn't come loose as you wrestle out the strut. If you can I would recommend undoing the axle from the knuckle to give yourself more space to pull out the strut. Hopefully this response came in before you got started! Good luck! |
05-17-2022, 01:44 PM | #8 | |
Rep 197
05-18-2022, 09:08 AM | #9 | |
Rep 25
The x4 looks great! |
P3NS237.50 |
05-18-2022, 11:49 AM | #10 |
Rep 1,093
Drives: 2021 X3 M40i
Somewhat off topic but what wheels are those? Thanks.
05-18-2022, 11:51 AM | #11 | |
Rep 197
I would like to state that the modifications that I made were not as per MSS instruction. So in doing so, anyone doing this is solely responsible for the outcome. However, imo I think MSS should make what I did and include it in the kit. |
07-17-2022, 09:42 AM | #15 | |
Rep 1,524
Drives: 2022 X3 M40d LCI
07-18-2022, 08:52 AM | #16 |
Rep 197
Thanks. I love them. Still rides comfortable enough for a daily, improved handling, and a major improvement aesthetically with the lowering. I recommend them but you need to make sure you get the right kit (edc shocks or standard shocks) that is a big issue when it comes to install.
hooligan_G016430.00 Keefy1616.50 |
03-20-2024, 03:42 AM | #17 | |
Rep 4,522
As you removed MSS assister springs in the rear, did you trim/fit smaller rear bump stops at all ?
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
03-20-2024, 08:16 AM | #18 | |
Cowboy Astronaut Millionaire
2314
Rep 2,886
But the dude hasnt logged in in almost 1 year I dont think youre getting a response.
