05-18-2022, 06:03 AM | #1 |
Rep 1,442
Running E85 Fuel in CA
This may not be news to many of you, but I messaged Fabian at MHD and he said it was possible to run E85 with no other modifications than their stage 1 set to E85. Has anyone done this and experiences a noticeable performance improvement?
05-18-2022, 07:17 AM | #2 |
Rep 133
Do you have a gen 1 or 2 b58? What sort of performance do you want? They are just tuning around your stock fuel pump limitations, as ethanol requires moving more volume of fuel for the same power output.
dinan5m34263.50 Chief Orman671.00 |
05-18-2022, 11:22 AM | #3 | |
Rep 2,067
Try to stay on flat surface as much as possible during data logging. Maybe try the E30 map first? |
Chief Orman671.00 |
05-18-2022, 12:00 PM | #4 | |
Rep 1,442
Edit Applications: 2017–2019 G01 X3 M40i[17] I assume that is gen 1 but strangely unsure |
05-18-2022, 12:07 PM | #5 | |
Rep 2,067
If you really want to be sure, then open up the engine cover and look at the orientation on the HPFP wire. |
Chief Orman671.00 |
05-18-2022, 12:24 PM | #6 | ||
Rep 1,442
Thinking I have gen 1 with 355 HP |
05-18-2022, 02:02 PM | #7 | |
Rep 133
https://igniteracingfuel.com/dealers-1 |
Chief Orman671.00 |
05-18-2022, 02:13 PM | #8 |
formerly rdougherty85
502
Rep 455
Are you doing it for saving some cash at the pump, or performance?
If for saving a few bucks, might be worth it. As mentioned, your engine will burn through a tank of E85 faster than 91/93, so it's a bit of a trade-off. If for performance, I would say, don't. It seems the general consensus that past a certain mixture of E, it is not beneficial to performance. Somewhere between E30-E50 seems to be sort of a sweet spot. And if MHD says they can do it, then I believe they can do it. I think your B58 still had the lower volume fuel pump that doesn't supply as much as the B58TU (MY20+) fuel pump does. That probably isn't even a factor at stock or mildly upgraded/tuned. |
Chief Orman671.00 |
05-18-2022, 03:39 PM | #9 | |
Rep 1,442
05-19-2022, 10:59 PM | #10 | ||
Rep 1,442
dinan5m34263.50 |
05-20-2022, 08:38 AM | #12 |
Rep 133
Stage 2 will give you room for a bigger turbo later. Good idea to go with their flex fuel kit also. You are so lucky to have access to pump E85, but I have read that not all pump E85 is 85% ethanol and this way you can ballpark a mix yourself at the gas station for around E50 and the tune will always self adjust.
Chief Orman671.00 |
05-20-2022, 08:59 AM | #13 | |
Rep 1,442
05-20-2022, 09:06 AM | #14 |
Rep 133
Chief Orman671.00 |
05-20-2022, 10:38 PM | #15 | |
Rep 1,442
05-21-2022, 12:20 AM | #16 | ||
Cowboy Astronaut Millionaire
2314
Rep 2,885
Is not keeping up. Full throttle 3rd gear or higher your car feels like you hit a brick wall and you get a drivetrain malfunction. No guessing there.
Chief Orman671.00 |
05-21-2022, 01:08 AM | #17 | |
Rep 133
Chief Orman671.00 |
05-21-2022, 09:08 PM | #18 |
Rep 2,067
Good god, when will Dorch have this back in stock !!!
It's been showing out of stick the moment it went on sale, day 0. I don't think there will ever be a PnP like F-chassis gen1 b58 for G01 to install at the low pressure fuel pump... So something next best thing like this from Dorsch would be the way to go, i would think. |
Chief Orman671.00 |
05-21-2022, 11:50 PM | #19 | |
Rep 133
05-23-2022, 12:05 AM | #20 | |
Rep 1,442
dinan5m34263.50 |
05-23-2022, 08:27 AM | #21 | |
Joint Chiefs of Staff
24199
Rep 190,807
Chief Orman671.00 |
05-23-2022, 01:34 PM | #22 | |
Rep 2,067
Looks like the use of BT ECA is still the way to go for me and manual blend calculations, for a while. |
Chief Orman671.00 |
