03-13-2024, 05:01 PM | #1 |
Rep 1
22 X3 Wheels and Tires
I purchased a 22 X3 with the 275/35/21 / 245/40/21 set up about a month ago and I just got my first flat tire. I could not believe that it would cost about $1000 to replace both front tires. They probably had about 8K miles of life left so not in too distant future, this was going to come up. I read a few postings and I am still a little confused. I have a few questions.
1) Can I buy new 19 or 20 rims in order to have more tire options? 2) If I stay with the 21's rims, what are my setup options with All Season Tires? Just a month into ownership and it is truly depressing (LOL!!!!!!!!) with this tire nonsense. |
03-13-2024, 08:39 PM | #2 | |
Found the Search Button
1594
Rep 1,158
Drives: 2022 X3 30i xDrive
2022 X3 xDrive 30i M Sport, Brooklyn Grey / Cognac
Previous BMWs: 2018 330i (F30), 2014 i3 BEV, 2007 328i (E92), 2013 X5 35i (E70), 2014 i3 BEV, 2006 325i (E90) |
03-13-2024, 10:16 PM | #3 |
Rep 227
A BMW car and several BMW motorcycles
03-13-2024, 10:29 PM | #4 |
Captain (Retired)
3983
Rep 1,728
Drives: X4 M40i
My .02 is that you should look for a low mileage set from someone with vehicular ADD who has swapped out perfectly good wheels/tires for a snazzy aftermarket set up
You’ll pay a fraction of the cost of new Craigslist, FB Marketplace, forums, etc I believe that some Audis share our 5 x 112 spec w/ 66.56 hub so that’ll help to expand your options |
03-14-2024, 12:06 PM | #5 |
Captain (Retired)
3983
Rep 1,728
Drives: X4 M40i
03-14-2024, 04:39 PM | #6 |
1594
Rep 1,158
I just bought an almost new set of my same OE Pirellis for $500 + shipping. Out the door half the price of a new set. There are better deals to be had.
bouchy75.50 |
03-15-2024, 07:34 AM | #9 | |
Rep 405
The rears for the staggered 20s are actually cheaper than the front, even though they are larger (I guess because they are more common). You can get cheaper non-RFT, but I've actually had RFT save a couple rims and let me get to the tire shop (since I don't have any spares).
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake Sold - 2009 328i - Stock, 195,000 running strong. |
03-15-2024, 09:43 AM | #10 |
Rep 270
Drives: 2019 X3 xDrive30i, 2021 X3 M40
Your options for 21" all seasons are very limited. I took off my 21s with runflats (lasted 12k) and bought a 20" staggered wheel and all season tire package from Tirerack. Many more (and cheaper) options for tires and the ride is much better. Join the club!
Present: 2019 X3 xDrive30i, Mineral White/ Mocha Vernasca / 21" 701M and 20" Savini Black wheels / RaceChip
Present: 2021 X3 M40i, Alpine White / Oyster Vernasca / 20" 699M Former: 2006 Z4, 1981 320i, 1973 2002, Jag XKE, SS396 Chevelle, 440 Dodge RT, 40+ others |
03-15-2024, 09:50 AM | #11 | |
Rep 965
2. 21 inch All Season options are basically non-existent at this point (with stock sizes anyhow)… you can change sizes slightly and find some, but there aren’t many that truly work for this car. 3. Personally - if you really want to run ASs, I would switch to a 20 inch square setup… but that’s just me. 4. As others stated… look on the second hand market… I don’t mind the 21 inch summer runflats that come with the car, and I bought a FULL set of takeoffs from a member selling… bought and shipped for $1000 to my door… FOUR basically brand new tires. Swapped last season, and kept the other three for backup, in case, guess what?… A puncture that can’t be fixed! Now I have used tires that will most likely fall into the same tread depth of something I get a puncture in. So before I get a$$-punched on a new set of anything… I see if it can be patched… if not, is tread depth close enough to one of my saved tires where I can use that option… if not, THEN I’ll go buy something. |
03-15-2024, 09:33 PM | #12 |
Captain (Retired)
3983
Rep 1,728
Drives: X4 M40i
04-02-2024, 07:23 AM | #13 | |
Rep 46
I’ll be going with a square setup for practicality’s sake. (I think I can avoid shredding rear tires with my xDrive 4-banger ) Just need to decide on 19 or 20. 20 looks great but the roads where I drive can be pretty gnarly. |
04-02-2024, 07:54 AM | #14 |
Rep 44
My 21" Alenza rears were at the wear bars by 20k miles, fronts looked to have another 5k in them at most. Just bought a set of Primacy Tour a/s "stop-flat" $1500 installed. Pricey and I hope they last at least 30k and should be much less sketchy next winter! Dealer wanted $1000 just to replace the original rears...
Ride is less jittery over bumps so it is an improvement. |
04-05-2024, 03:33 PM | #15 |
Rep 46
Itchy trigger finger got the best of me. The wheels were supposedly backordered but TireRack shipped them almost immediately. Went with a square 19in Borbet Type W with CrossClimate 2s. Looks good for my taste. Will look better when I, you know, bolt them to the car instead of just stick one next to the front axle. Supposedly the BMW center caps fit for an OEM look.
Present: ‘24 X3 xDrive30i
Past: ‘17 M240i |
