05-04-2023, 09:19 PM | #1 |
Rep 13
OBD II dashcam parking mode
I have been reading about various dashcams and I stumbled upon the Mini 2 from Garmin. As an accessory, they offer an OBD II cable (link below), which provides constant power. it seems to me, that it's a great alternative to the invasive hardwiring. I understand this might drain the car battery if kept for an extended period of time, but this specific cable has an embedded timer 10 minutes, 24 hours and eventually always on. Additionally it monitors the battery voltage level and would cut off power if it drops below 12 V. Given this would function as expected, does anybody think it's a bad idea to draw power from OBD II, for parking mode, in general ? would that cause any problem to the car electronics or to a diagnostic scanner capabilities ?
https://www.garmin.com/en-CA/p/735279 |
05-04-2023, 10:09 PM | #2 |
Rep 874
I don't doubt the garmin quality but it's a little on the expensive side. I got mine for under $20 from amazon with the same cut-off feature - although it's voltage-dependent only, no other option. Still working great since I bought it last year.
IMHO, it's not a good idea to draw power off of the battery for long period, esp if you're parking the vehicle outside most of the time. Our batteries are not getting charged that much within the duration of average commute time/distance. |
kimokono5.00 ContactPatch2139.00 |
05-04-2023, 10:12 PM | #3 | |
Rep 1,332
Curious how you will run the cable from the dash cam to the OBD port? Using Add-A-Circuit or a fuse tap (same thing) is very quick to wire in the passenger side footwell. You tap into Fuse 46 with a 20A rated Add-A-Circuit, the wire to the dash cam is routed behind the door molding and down the A Pillar, then behind the headliner to the mirror area. You cannot even see the wire, might take 30 minutes to install. |
05-04-2023, 10:28 PM | #4 | |
Rep 13
05-05-2023, 07:45 AM | #5 | |
Rep 1,173
2020 X3 M40i
2015 328i - Sold @ 104,000 miles |
kimokono5.00 |
05-05-2023, 07:58 AM | #6 | |
Rep 4,292
https://insight.daumphotography.com/...meras-install/ Not sure how BMW get around this with the AXE 3.0 parking mode. |
kimokono5.00 |
03-15-2024, 03:38 PM | #7 | |
Rep 1,044
But...the Thinkware is a bit funky regarding its parking mode. It's designed to go into parking mode when the ignition power is cut. I don't know if a standard hard-wire retains power until the car enters deep sleep, but the OBD II connector apparently does. This has the effect of keeping continuous recording going until the device senses that the car has cut power. Not a biggie...but for future reference. BTW, the dash cam itself is quite nice, if expensive. What's terrible is Thinkware support and service. For example, the Q1000 has an integrated GPS. However, the only way to access that info is to use their software, which their website says is unsupported. The Q1000 manual actually details these utilities as the only way to access the information.
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29 MY19 X3 M40i: Produced: 2018-08-15; Delivered 2018-08-22 |
