05-18-2022, 01:35 PM | #1 |
Rep 2,868
Headlight question
On my M40i on my headlights, I have "BMW Adaptive LED" .. and I have adaptive lights (obviously) and I have auto Hi beams.
I have a loaner x3 30i - same exact year as my m40i - on my loaner, it just says "BMW LED" ... but the loaner DOES HAVE adaptive lights that swivel, but does not have auto hi beams. Is the high beam the only different? why does one include the word "adaptive" and the other doesn't, when both headlights do actual have adaptive? EDIT: this is on the exterior on the headlight in the side Just curious one why has adaptive in the label on the light, and the other one doesn’t… even though both cars do have the adaptive feature.
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 Last edited by AllBlackBimmer; 05-18-2022 at 09:55 PM.. |
05-18-2022, 01:42 PM | #2 | |
Rep 277
Are you saying there is an adaptive setting with led on the stalk ? and, either way are you just talking of the turning corner lights or the true adaptive where they split or move to the side adapting to traffic ? my wife hates adaptive as the lights dance around too much for her |
05-18-2022, 02:24 PM | #3 |
Rep 410
Just dont use automatic mode, then no dance anymore?
05-18-2022, 06:13 PM | #4 |
Rep 1,442
So I am about to get my headlights coded for true adaptive by codemybimmer.ca. Does the true European adaptive headlight functionality obviate the need for auto high beam switching/anti-dazzle on US cars?
05-18-2022, 09:53 PM | #5 |
Rep 1,201
Drives: 2022 BMW X5 45e M-Sport
I've had my X3 coded by them as well. You still need to turn on the Anti-Dazzle every time you drive by pressing the top outside button on the turn signal stalk. Otherwise it's just the normal high beam. Besides being able to visually see it's on, the auto light on your dash will turn from green to blue when Anti-Dazzle is working.
Chief Orman671.00 |
05-18-2022, 10:53 PM | #6 | |
New member
318
Rep 553
See, for example, this explanation: |
05-19-2022, 12:34 AM | #7 |
Rep 277
05-19-2022, 07:04 AM | #8 | |
Rep 2,868
Exactly what i was looking for. I thought "Adapative" meant swivel when turning - that is not the case (well, it is on my old e90) but "Adapative" on my m40i refers to my auto-high beam function which is much more advanced than just a simple "on/off" function, which is what i thought it was. Thanks for the great info, learned a little something today!
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 |
Chief Orman671.00 |
05-19-2022, 10:21 PM | #9 |
New member
318
Rep 553
But note that the adaptive feature of the BMW Adaptive LEDs is not active from the factory on a US car because, until recently, it was not legal in the United States. In other words, high beams are either on or off, just like with non-adaptive LEDs. However, you can activate the feature by coding on adaptive LEDs.
Chief Orman671.00 |
05-20-2022, 05:55 AM | #10 | |
Rep 2,868
US has ridiculous light laws. So... with that being said, what exactly do my adaptive LED lights do on my US car? The hi beams just turn on and off like you said? Isn't the the exact same feature as the BMW LED (non adaptive) ... if so, what is even the point of them putting them on US cars
05-20-2022, 10:27 AM | #11 | |
Rep 131
Someone mentioned the wife found adaptive lighting annoying. I can see this happening in city traffic, especially with the US reduced version of adaptive LED’s. But in open roads, it is a really useful safety feature to have. As mentioned, X3M40i’s in the U.S. can also have the full version adaptive headlamps, but it needs to be coded to be enabled on. Last edited by Chris Pringle; 05-20-2022 at 10:36 AM.. |
05-20-2022, 05:51 PM | #12 |
New member
318
Rep 553
Tough to say. The obvious answer is more profit for BMW. Personally, I also think that the adaptive lights look better, especially the daytime running lights. It is also possible that the swiveling mechanism is more advanced on the adaptive headlights, but I don't know that for sure. If you search the web, there are discussion threads where people claim that the adaptive headlights are a bit brighter.
Chief Orman671.00 |
05-20-2022, 10:49 PM | #13 | |
Rep 1,442
05-22-2022, 03:00 AM | #14 |
Rep 101
Mine is only marked as 'BMW LED' on the units, but they do have high beam assistant, corner lights and the brilliant adaptive matrix LED system that can independently control the full beam across both headlights to create sections of darkness to avoid dazzling (although not foolproof, and the delay to dipping doesn't work well on the UK twisty country roads!).
05-22-2022, 09:57 AM | #15 |
New member
318
Rep 553
Are you sure that you have the anti-dazzle feature with just regular non-adaptive LED lights? If you look at the headlight straight on, you can see the individual light emitting diodes reflected in each mirror segment (you may need to look a bit from a distance). The adaptive LED lights have three diodes in the outer light and four diodes in the inner light. How many do your lights have?
05-22-2022, 01:55 PM | #16 | |
Rep 55
05-23-2022, 08:35 AM | #17 |
New member
318
Rep 553
Interesting. Can you snap a few photos for us to see the light emitting diode layout in the LCI lights? The photos I've posted above are for a pre-LCI Adaptive LED lights on the X3.
05-23-2022, 01:10 PM | #18 |
Rep 236
Here's some information on this topic since it was recently finally legalized but with some caveats.
https://www.nhtsa.gov/press-releases...0of%20schedule. https://www.nytimes.com/2022/02/18/b...eadlights.html |
05-23-2022, 02:45 PM | #19 | |
Rep 55
Where should I look to count diodes? Tried from different angles but can't find a clear perspective. The lenses are textured and hard to see through. |
05-23-2022, 10:13 PM | #20 |
New member
318
Rep 553
I see. This is a completely different headlight design than on the pre-LCI models. I suspect the diodes are hiding behind the large lens and there is no longer an easy way to count them without taking apart the headlight.
09-01-2022, 03:00 PM | #21 |
ghey
483
Rep 2,041
Resurrecting an old thread.
I just picked up an X3 for my mother which has "adaptive LED headlights" Here is my knowledge of BMW headlights from previous cars: -First, we all know that anti-dazzle is decoded for US-bound cars. That limits the advanced functionality, but other components of adaptive remain active. -With that, my G30 had the iconic LED headlights. These were quad-LEDs that would swivel with steering input and auto adjust up/down. -My G05 has the base LED headlights. These are dual-LEDs (inner projectors are dummy), but they still swivel with steering input and auto adjust up/down -The X3 has quad-LEDs similar to the G30, but in my driving around, I see no movement of the lighting system at all. They are set to automatic on the knob (HBA is off because that has never impacted swivel control previously). So to OPs original question, what is adaptive about these ones, knowing what is normally decoded for the US, and knowing that other series models have swiveling/adjusting headlights when they are adaptive? Relevant equipment: S552 Adaptive LED Headlight S5AC High-Beam Assistant S5AP Decoding Anti-Glare High-Beam Assistant
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
09-01-2022, 03:13 PM | #22 | |
Rep 101
As far as I can tell, with the HBA turned off there's nothing adaptive about the lights. I did read that some BMW headlights would change the beam pattern based on the speed, for example on the motorway the range is increased, and in town the beam is shorter but wider, but for the X3 I've not noticed anything like that. The only adaptive part on mine seems to be the corner lights, which are quite subtle. |
