10-06-2019, 12:38 PM | #1 |
Rep 340
Car sat for a week, started it up today, no problem, let it idle in driveway and all of these warnings came on. Drive down the road about a mile and all the stability and chassis warnings joined the party. Car went into limp mode.
BMW Roadside Assist sent a guy out and we charged battery. Reader said charge was good. Car still won't start. Seems like system needs to be rebooted. Any ideas how to do that?
Current: 2020 DGM X3MC | Black Merino/Black Alcantara/Mid Beige| Exec | LED | Moon roof | v1 | ASDelete
Previous: 2017 AW M3 | Full Cohiba | Comp | Exec | Lighting | MPE | v1 (RIP) Previous: 2014 JB 535d | Msport | Exec | Premium | Lighting | v1 Last edited by M3OW!; 10-07-2019 at 01:57 PM.. |
10-06-2019, 01:51 PM | #2 |
Rep 98
No clue what to do, but I've also had the chassis stabilization warning coming on a few times already for no apparent reason. They have all happened upon startup on level ground, normal operating conditions, etc.
I'm taking mine in for the run-in service on Wednesday this week and going to ask what's up. |
10-06-2019, 03:53 PM | #3 | |
Rep 340
Been waiting for BMW assist to come through for 5 hours. They are completely USELESS. Can't even send a truck with the equipment needed to get the car out of here.
Previous: 2017 AW M3 | Full Cohiba | Comp | Exec | Lighting | MPE | v1 (RIP) Previous: 2014 JB 535d | Msport | Exec | Premium | Lighting | v1 |
10-06-2019, 04:21 PM | #4 |
Rep 4,532
I would disconnect the battery for 10 minutes, then reconnect just to see if it will force a reboot.
10-06-2019, 09:37 PM | #6 |
Rep 340
Radar detector is hardwired that's the only thing I can point to.
10-07-2019, 11:57 AM | #7 |
Rep 340
App still won't attach pics SMH
10-07-2019, 03:15 PM | #9 |
Rep 4,532
Did it ever start ?
10-07-2019, 05:39 PM | #10 | |
Rep 5,102
Must be something else causing the drain.
10-07-2019, 09:56 PM | #11 | |
Rep 340
10-07-2019, 09:58 PM | #12 | ||
Rep 340
10-08-2019, 04:20 PM | #13 |
Rep 2,528
Sorry to hear of your troubles – any update?
Not sure whether your low battery caused all the 5 pages of error codes, or whether the battery is defective, but in the past I’ve had to replace 4 batteries on our previous F25s, one time the morning after a 600 mile trip. At that time I was still under the impression when the motor is running the battery is always being charged, but was told on long trips (especially if charging cell phone and using USB charging for laptop which we did) that it can drain the battery. A trickle charger was recommended and purchased. Since that time every three weeks or so I’ve hooked up our G01s (and now F97) and it takes about 16 -20 hours to fully recharge (the X3MC took 16 hours last night and I just did it 3 wks ago). I don’t know enough about Electronics to know the efficiency of vehicle self-charging and what conditions lower that, aside from the obvious of using the electronics, charging the phone, and using USB as power sources, but it does seem these high-tech vehicles have increased electrical needs. Knock on wood I haven’t had another battery issue since routinely using the trickle charger (don’t know if it has made the difference or whether just good luck). |
10-08-2019, 05:23 PM | #14 |
Rep 2,073
Low voltage with other BMWs kicks up loads of error codes as there's insufficient voltage for the ECUs so they pretty much all show failures.
10-08-2019, 09:17 PM | #16 | |
Rep 340
Car was at the dealer all day yesterday. I picked it up around 6PM drove it for an hour, parked it and it sat in the garage all day today. Started it up no problem this eve and went to run a few errands. No issues. My v1 is hardwired via SAVVY. Ran same set up in f80 and never had a problem.
10-08-2019, 09:44 PM | #17 | |
Rep 4,532
10-09-2019, 12:46 AM | #18 |
///Multiple
2992
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
For confirmation, on my 2016 M4 I've run my V1 via the SAVVY plugged into the OBDII port with no issues for over three years. My wife's 2018 M3 has run the same setup for over a year, no issues. The SAVVY shuts down either when the car is locked or, IIRC, in 10-15 minutes if not locked. The X3/X4/X3M/X4M may operate slightly differently, but most likely also shuts down completely when the door is locked.
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
M3OW!373.00 |
10-09-2019, 07:35 AM | #19 | |
Rep 340
Thanks brother, glad to know I'm not imagining things!
SD ///M42992.00 |
10-09-2019, 07:42 AM | #20 |
Rep 340
Dealer cleared all fault codes, generated printout of said fault codes, rebooted the car and juiced up the battery. Then, when reviewing the service invoice, tried to tell me that I left a "side light" on and that's why there was a problem.
I am 100% certain no lights were left on and the car started right up when I got home. The problem occurred after 5 min of idle and driving 2 miles down the road.
11-16-2019, 11:03 AM | #22 | |
Rep 340
I suspect I have a shitty battery...but dealer won't agree. What kind of feedback did you get?
