02-15-2019, 04:09 AM | #2 |
Lateral grip estimator
957
Rep 1,390
On cars i've had in the past this has been the case from time to time.
My old E36 328i Sport definitely got 10% better economy on high octane fuel, whereas my F31 340i didn't seem to make any difference at all, to economy or performance. Might have to try the good stuff in my M40i now...
02-15-2019, 09:58 AM | #3 |
Rep 8,030
Drives: 2024 X5 M60i
I wish we got 93/94 octane around here. A vast majority of the stations around here in AZ only have 87/89/91.
02-15-2019, 10:55 AM | #4 |
Rep 6,121
Drives: 2022 Porsche Boxster GTS
The only way to truly prove this is in a controlled environment: lab test
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order) 2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD) 2018 BMW M2 Mineral Grey(SOLD) 2019 BMW X5 50i Carbon Black/Tartufo (SOLD) |
Max Well4734.50 |
02-15-2019, 10:21 PM | #5 |
Jim
270
Rep 156
You 'might' get slightly better performance with higher octane, but if you vehicle isn't designed and tuned for it, you running a hotter burning fuel and spending lots more for it.
02-15-2019, 10:37 PM | #6 |
Rep 81
This is not how octane numbers work... the higher the number, the slower the fuel burns.
02-16-2019, 07:49 AM | #9 |
Rep 967
I believe modern engines adjust constantly, to be as efficient as possible.
When I did quite detailed real life measurements before, it was hardly worth it. It cost 5% more, and was 5% more efficient. On the plus side you actually had a tiny bit more power when needing it. (In a SAAB Turbo V6)
G01 X3 30d 2018-09 - Sophistograu Brillanteffekt Metallic/ Leder Vernasca Mokka Dekorsteppung
02-16-2019, 08:36 AM | #10 |
Jim
270
Rep 156
02-16-2019, 09:17 AM | #11 |
Rep 1,727
First thing first, low octane fuel like Diesel actually have higher energy density than petrol. So the gas mileage of diesel is almost always higher (with the correct engine of course) since they have more energy to give per unit volume of fuel. So this one single factor is opposite to the hypothesis of high octane fuel gets better mileage.
Higher octane is more resistant to knocking, and in theory has a slightly higher efficiency in burning (but not more energy to give, see above). A few more factors to consider: Does the engine design for it? in our engines with high compression ratio, it's best to pair it with high octane gas (petrol) so the burning is smoother and no timing issues. Fuel mix additive - do they add alcohol / ethanol to the fuel? These fuel additives typically have much lower energy content vs gasoline itself. so for our experiment to work, we cannot compare premium high octane gas with no such additive vs 87 octane adulterated with additive. |
02-19-2019, 02:58 PM | #12 |
Rep 20
I can confirm i get better MPG with 94 Octane VS 91 its crazy the difference.
This is what i did. Local Member and I both have exact same M40I same generation and production period. Same rims and rubber. KM on both vehicles within 250KM of each other. Both vihicles weighed with driver, I was 65LBS heavier. Hence he addedd 65LBS to his ride. He has always filled up with 91 for the last 7 tanks i have only used 94 We both filled right to brim side by side at Chevron in Tsawwassen not a drop could be squeezed in the tank in both cars. We both drove out side by around the mall back area loop with ZERO Traffic around us and zero stops. Comfort mode both cars speeds between 60 KM per hour and 100 KM per hour. Side by side same speed using cruise control to accelerate at same pace at same time. Both of us drove 203.5 KM that included back to the gas station side by side. When we both filled up again right to top. His car using the 91 Octane had to put in 19.1 litre of fuel My car using the 94 Octane i had to put in 17.2 Litre of Fuel Almost a full two litre difference. Cost for 91 octane here is 1.43 per litre Cost for 94 octane is 1.47 per litre Now after we were done. Both of at a red light side by both in sport mode we both floored it off the light when it went green. I swear we both launched the same time after about 4 or 5 block straight away i was a full 4 or 5 feet ahead and looking like i was pulling further ahead. Take it for what you want i think i did a pretty controlled environment best i could the difference is very noticeable. For those who dont know in Canada you get 94 Octane from Chevron In the US unfortunately you guys dont get 94 Octane. Unless you ask Trump then its huge and you guys have the best gasoline ever LOL sorry had to do that. 93 is the top you guys get and thats only in the following states that i know of. Georgia Massachusettes Maine ONLY at Shell North Carolina Pennsylvania Rhode Island Texas Tennessee Mosty of the above states its Shell who sells 93 primarily |
MechX3M40i1006.00 Max Well4734.50 |
02-19-2019, 03:06 PM | #13 | |
Rep 1,727
If you guys feel like adding to the study, next time swap the octanes of gasoline and see if the performance results will reverse. |
02-19-2019, 03:20 PM | #14 |
Rep 188
We have 98 RON here in UK - it’s Shell VPower. I’ve used this on all my previous petrol cars. It definitely feels like it produces more power - not sure how much affect on mpg it has. It is also advertised as having additives that help clean the engine.
We also have 99 RON but it’s Tesco supermarket fuel - I generally avoid supermarket fuel. There been reported issues in the past. I believe the lowest octane petrol we have in UK is 93 RON. Last edited by MattXYZ; 02-19-2019 at 03:23 PM.. Reason: Typo and added a sentence |
02-19-2019, 03:21 PM | #15 |
Rep 46
Drives: 2019 X3 s30i
In Florida we have 87/89/93. Very few stations have 87/89/91/93, mostly Sunoco. I didn't do an in depth analysis as glowbalgroup, but I did seem to get a bit better range on 93. Not sure if its worth the $0.50 or more per gallon bump in price for 93 though.
02-19-2019, 03:51 PM | #16 | |
Rep 238
Drives: 2021 530d xDrive Touring
The Germans get 102 Octane from Aral. Gave my M135i a couple of tanks of that when driving through. I think the US have a different measurement to Europe. RON in Europe v RON+MON avg in US I believe. Means the lower US numbers are actually in line with Europe. So US 93 is about 98 in Europe. I'm sure this very knowledgable forum will correct me if I'm off the mark though.
2021 BMW 530d Touring: Sanremo Green / Cognac
PREVIOUS 2019 BMW X3 30d MSport: Black Sapphire / Cognac 2015 BMW M135i (F20) Instagram SanRemoGreen_5Touring |
02-19-2019, 04:02 PM | #17 | |
Rep 2,531
Some other variables to keep in mind, though, as this MPG stuff gets really complex. In an earlier thread I tried to see if wheel weights and tires make a difference, not so much from a pure fuel efficiency standpoint, but rather an aerodynamic and rotating mass standpoint. But it became clear as my 'study' went along that temperature and related DA issues as well as tire pressure are key determinants in end results, and would make it virtually impossible for me to identify relationships with reasonable certainty. For example, if we don't know the exact tire pressures of both of your vehicles it is hard to equate the values you both derived, although you did a great job controlling the other major ones. As can be seen in the charts in that thread, my MPG in our 2018 G01 X3 M40i, following the exact same routes on multiple trips at same HWY speeds of 79 mph on cruise control without aggressive maneuvering, varied from 23.8 to 29.0 MPG. And that is with the 'same' 93 octane gas (ie., the same stations for the different legs, obviously not the same gas load compositions). https://x3.xbimmers.com/forums/showt...1440682&page=1 Well done, however, and look forward to more data! |
muzzalad268.50 MechX3M40i1006.00 |
02-20-2019, 08:59 PM | #19 |
Rep 20
The reason i guess i get better gas milegae on 94 Octane at Chevron is wait for it....................The 94 at Chevron HAS ZERO Ethanol
Read this amazing article https://axleaddict.com/misc/Pros-and...Ethanol-in-Gas |
02-20-2019, 09:32 PM | #20 |
Rep 251
Another canadian here. Petro is my convenient gas station of choice, they offer 87/89/91/94. 94 is only like .05 more than 91 so I've tried it a number of times when I felt rich. This was earlier on when I was monitoring and measuring my gas mileage each fill up. I didn't notice any specific improvements of 94 over 91.
The only consistent thing I've discovered is that my gas mileage went down as the vehicle got more KM and presumably I began to drive more spirited. One thing I will comment is the trip computer gas mileage and my manually calculated mileage have always been 100% correct. This is positive news to me as I generally hear people suggest they're very inaccurate. I stopped measuring after 7000 ish KM as I trusted the trip computer and i just got a little lazy. Plus it's slightly more depressing to see gas mileage continually going down. I have no doubt snow and turning off DSC is contributing to lesser gas mileage at the moment (officially hit 11.1 l/100km the other day). |
