10-12-2020, 10:59 AM | #1 |
Rep 602
Wireless charging ordering question
I just noticed that when you order Wireless Charging option (6NW), it adds Enhanced USB and Bluetooth (ZEB) to the order. I've read that the charging capabilities are not great. If I don't order wireless charging, does that mean I won't be able to stream from my phone via bluetooth? What is the advantage of having this option? or disadvantage?
10-12-2020, 11:21 AM | #2 |
Rep 128
You will be able to stream, but you will not have the ability to connect two phones simultaneously and you will not have office features (texting, etc.). Some people manage to code these options in. However, you will also lack the "booster" that allows the phone to use the shark antennae.
10-12-2020, 11:59 AM | #3 | ||
Rep 42
10-12-2020, 12:19 PM | #4 | |
Rep 128
I also forgot that the option also gives a second microphone for voice commands. |
10-12-2020, 12:46 PM | #5 |
Rep 4,124
I passed on this option and don't regret it. Car has bluetooth and wireless connectivity so easily stream music straight from my phone, album art and all. No cellphone connection issues either and frankly I can't recall the last time I went somewhere isolated enough to have a poor signal that might make the booster worth it. Never say never but stay pretty much in an urban environment...
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
10-12-2020, 12:49 PM | #6 |
Rep 1,967
10-12-2020, 12:59 PM | #7 |
Rep 128
My understanding is that it has to be registered and I didn't get any registration information with my car (it doesn't have the charger).
10-12-2020, 01:32 PM | #8 |
Rep 1,110
This is an item that is BMW does not describe enough. Wireless charging brings you an extra usb port in the arm rest compartment, a second mic above the passenger, ability to pair a second phone simultaneously. Also I think it adds the "office" features that include SMS messaging.. I can't remember if that (SMS) is standard now because it used to not be.
As far as the booster in the shark fin is concerned, I thought that was old school when you had the smartphone adaptor in the armrest compartment - and that went the way of the dodo. I don't recall it being part of 6NW/ZEB at least for the last few years. Was it something I just never noticed? |
10-12-2020, 02:42 PM | #9 | |
Rep 128
https://x3.xbimmers.com/forums/showp...57&postcount=3 I had forgotten about the extra USB, that's true. The charge capacity might also be different. |
JSY584.00 |
10-12-2020, 05:48 PM | #10 | |
Rep 602
Even though the charger might not be the best, it is kind of nice not to have to take out a cable. Someone mentioned wireless in the car. Is that a way to stream music and get a better sound? |
10-12-2020, 06:07 PM | #11 | |
Rep 74
Drives: 2021 X3 xDrive 30i
10-12-2020, 06:17 PM | #12 |
Rep 4,124
It is there even if you did not get the wireless charging option. I have my phone set up to connect via the wifi though I am still experimenting as sometimes it seems to connect via BT first.
2021 X3 M40i
10-12-2020, 07:46 PM | #13 |
Rep 137
The "booster" is basically an extension/amplifier for the phone antenna. If you have the antenna amplifier, it is located in the hatch area on the drivers side...where the first aid kit would be located if it was installed. Pull the small access panel cover off. Looking into the access port, the phone amplifier is located about 2 o'clock mounted to the inside of the fender...it is not the module lower down about 7 o'clock. Mine was made in Portugal. There is a brand, model, and serial number which will be needed to register the module with your cell provider.
I really see no difference in phone signal strength when the phone is on the charger or just sitting in the car not charging. |
