      02-13-2020, 06:26 PM   #1
GT500R
Drives: BMW X3M
Wheel hop?
Anyone else notice in 4WD Sport and accelerating in 1st or 2nd gear the rear starts to hop?
Usually when it is damp out this happens... in Sport+ suspension.
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance
10.84@127.43 / +1912 DA NH Dragway |
10.6@130 Dragy / +820 DA The Streets |
NOW: Tesla Model Y Performance
      02-13-2020, 06:45 PM   #2
two1bar
Drives: 2023 M3 Comp xDrive
Yes same issue here. The OEM Conti tires are horrible in colder temps.
      02-13-2020, 06:59 PM   #3
GT500R
Drives: BMW X3M
I have PZero Nero stock... hmmm
      02-13-2020, 07:55 PM   #4
ThumperMCS
Drives: X3M Comp, MINI Cooper JCW GP
Have PS4S's....zero wheel hop, never even had them break loose, even with launch control
2020 BMW X3M Competition
2019 MINI Cooper S
2006 MINI Cooper JCW GP--GP1599
      02-14-2020, 08:34 AM   #5
jlee
jlee's Avatar
Drives: M2CS+GTS Targa+RRS SVR
Yup the summer tires are tough in the winter
      02-14-2020, 08:48 AM   #6
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
Not really, however when pulling out of a junction with about 1/2 a turn of lock on it chops like crazy if you push on the throttle too quickly, as if the transmission is binding trying to push straight ahead against the front wheels, it's quite a nasty feeling.
730d/Z4C
      02-14-2020, 08:55 AM   #7
mf44
mf44's Avatar
490
Drives: '24 iX 50
If you are in the northeast, ambient temperature can play a role, too. Summer tires are going to exhibit this behavior when the temps drop. The solution is swapping to high performance winter tire when it gets colder.
      02-14-2020, 10:28 AM   #8
GT500R
Drives: BMW X3M
Agree! Will be doing this next winter. I think these Max Performance Summer Tire I have on now should be good for the track 😈
      02-14-2020, 10:29 AM   #9
GT500R
Drives: BMW X3M
Yup I experience that too... don’t like it
      02-14-2020, 11:54 AM   #10
RoyB
Drives: 2021 M340i x
I get something similair when backing out of my driveway in the AMs. It's almost as though everything is frozen and it's breaking free.
      02-14-2020, 12:30 PM   #11
spta97
Drives: BMW 2020 X3MC
This happened to me with the summer tires at anything below 50 degrees (once I would turn the wheel and move forward after backing out).
It no longer happens with my Pirelli Scorpions.
I think it’s a traction issue with the summer compound as stated above.
      02-15-2020, 01:35 PM   #12
Richierich32
Richierich32's Avatar
Drives: X3 M40d in White
Soon as mine arrives I'm thinking of putting 265 and 285 ps4's on!!
      02-18-2020, 08:52 AM   #13
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
Today it was awful, just over half a turn of lock at a junction whilst pulling away it felt like the rear drive shafts were loose, chop/clunk/stagger/chop awful....
730d/Z4C
      02-18-2020, 11:57 AM   #14
spta97
What was the temp? Do you notice it less when the tires warm up as measured by the TPMS?
Sounds like winter tires may be your solution as my issue completely disappeared after I installed them.
      02-19-2020, 03:33 PM   #15
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
At the moment the weather here is about 40-60f, but the car has traction under load from low speed so it's not the tyres per se, it's the step off where it has issues and even worse when you step off with lock applied, it was doing it again today pretty awfully and is really starting to annoy me, going to take it in.
730d/Z4C
      02-19-2020, 05:17 PM   #16
spta97
Forgive my ignorance, but can you explain what you mean by “step off” and “lock applied”?
Strait line traction wasn’t an issue for me with the summer tires. Rather, the issue was with the front wheels turned (and the rear wheels would skip/chop).
Best way I can describe it was like having a 4x4 on dry pavement which did not allow the rear wheels to slip (perhaps this is what you meant by locked (aka center diff locker).
Part of me thinks it’s a similar issue happening where some parts of the rear wheels grip and others parts slip due to the summer compound being cold. This would explain the choppy feeling of traction/no traction upon rotation.
Curious what the dealer says. I was freaked out at first by it but it was only a couple of days before I put on the winters and it hasn’t happened since so in my case it appears to be the tires.
I can tell you I won’t be putting the summers back on until the lows are in the 60s.
Please post back what the dealer says.
As an FYI, I did read another post where someone had a similar issue and most people said it was normal for it to happen from time to time due to the AWD.
      02-19-2020, 07:39 PM   #17
dazzapb
Drives: 2019 X3M Comp
Pretty sure it's the tyres too.
At a junction I also notice the rears spin and grip repeat with not much throttle. I put it down to lower temps (40-50f) and damp roads. With some spring heat in the tarmac I imagine it will improve
I have MPS4S
      02-20-2020, 04:04 AM   #18
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
"step off" is a term used to describe a vehicles transition from stationary to moving, "Lock" is a term used to describe turning the steering wheel.
730d/Z4C
      02-20-2020, 05:12 AM   #19
daltonvaas
daltonvaas's Avatar
Drives: 840i GC (on order)
I get this too, glad i'm not the only person that's experienced it. It was actually embarrassing once as someone question if the car was 4wd even
      02-20-2020, 05:20 PM   #20
spta97
Ah - thanks!
I assume this is either UK speak or I’m behind on car lingo. In my day we used to say “step on it” meaning mash the gas peddle.
Yes, acceleration (even minimal) with the wheel turned is where I had the issue before switching to winters.
      02-22-2020, 03:06 PM   #21
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
Ah - thanks!
Not really, so you've never heard the term "opposite lock" in regard to counter steering in an over steer situation?
Yes "stepping on it" is in the same vein as regards the term "step off" i.e. the application of throttle to move the car from a stationary position.
730d/Z4C
