Login
XBimmers | BMW X3 Forum • Instrument cluster cracked |
01-17-2022, 05:49 PM | #1 |
Rep 18
I've got a minor crack in my instrument cluster and I'm not that bothered by it but wanted to do a little research into my options for repairing it. My first instinct is to pull the clear plastic cover from another cluster and replace it. But looking at pictures of the part, it appears to be bonded in place. Does anyone have experience removing the "glass" or is that pretty much a non-starter?
The other option I could see is instead of swapping the glass, just coding the replacement instrument cluster and installing that. But I'm not sure what is and isn't possible when it comes to the coding of parts like this, and also if I need to be more selective about the donor vehicle. Any thoughts are greatly appreciated! |
01-17-2022, 09:27 PM | #2 |
![]() ![]() ![]() 261
Rep 359
The cover will separate from the cluster itself, so you should be able to do what you originally planned. If you swap in a whole cluster you're going to have to virginize it, which is more trouble than just coding.
Here's the line where the front part, which includes the shroud and the clear plastic part, separates form the cluster body.
Current:
2017 F87 M2 6MT 2013 F25 X3 3.5i 2008 E90 M3 6MT |
3002 tii1674.50 jonmon66914.50 |
01-18-2022, 02:39 PM | #3 | |
Rep 18
https://www.lkqonline.com/2014-bmw-x...r-head-cluster Is there another source for parts these cars that is good to keep in mind? Usually I'd check pick n pull but I think F25 is a little too new to be in their yards |
01-19-2022, 02:54 AM | #4 | |
![]() 5
Rep 16
