XBimmers | BMW X3 Forum BMW X3 and X4 Forums | F25 (2011 - 2017) | F26 (2014 - Current) Second Generation BMW X3 (F25) General Forum Oil and coolant temperature f25
      01-17-2022, 03:59 PM   #1
dejan064007
Drives: BMW X3 F25
Which is normal oil and coolant temperature for 2.0 motor n47? 2 hours drive on outside temperature about 0C oil temperature is in range 75 to 90 C, and 75-85 coolant temperature. Is that normal or need to be higher ? Some people say it should be fixed on 100C oil temperature, is that true?
      01-17-2022, 04:16 PM   #2
HighlandPete
Drives: BMW F11 535i Touring
Temperatures are low. Coolant thermostat is rated at 88C opening temperature, so ECT should be above that figure. Oil typically around 100C.
Only thing to keep in mind, very low load engine loads at freezing temperatures may not acheive optimum engine temperatures. Have you any figures for slightly higher ambient temperatures?
      01-17-2022, 04:31 PM   #3
dejan064007
Drives: BMW X3 F25
Previously I did not pay attention to the temperature until it was -13 outside, the oil temperature did not exceed 75c, although the car was on the open road with 2000rpm
      01-17-2022, 04:36 PM   #4
HighlandPete
Has your model any grille shutters?
      01-17-2022, 04:47 PM   #5
dejan064007
Drives: BMW X3 F25
I don't know. I think to i don't have but I am not 100% sure. Can I check it with ista+ or bimmerlink/code?
      01-17-2022, 05:12 PM   #6
pungo
pungo's Avatar
Drives: Z4MC, X3 35i, 525i
The F25 models don't have grille shutters
Copyright ©2000 - 2022, vBulletin Solutions Inc.
