XBimmers | BMW X3 Forum BMW X3 and X4 Forums | F25 (2011 - 2017) | F26 (2014 - Current) Second Generation BMW X3 (F25) General Forum RPM revs by itself and drops. Once In a while. Anyone else?
      01-08-2022, 02:37 PM   #1
slowblackx3f25
xdriv33
slowblackx3f25's Avatar
Drives: 17' BMW x3 F25 xDrive28i xLine
2017 BMW x3  [0.00]
I drive a BMW 2017 x3 with 137,777KM on the dash and once in a while the RPM rev needle will rev by itself at a red light or while in heavy traffic (only happens in gear D) and it'll drop after to 900rpm.
It will do it once in a while.
I tried liquimoly injector cleaner and it didn't help as much.
Anyone have this problem and what did you do to fix it?
No CEL's so I really don't know where to check.
I will speak to my BMW specialized shop about this.
I actually did and they said it can be injectors and they said to use the injector cleaner first.
That clearly didn't work.
      01-09-2022, 09:01 AM   #2
WrEkkED
Drives: BMW X3 28D, X5 35i
What engine do you have?
What injector cleaner did you use an how?
An in tank injector cleaner is more maintenance than anything. They don't do a great job at cleaning big build ups but rather get rid of deposits over time and keep from building new ones. To clean them without removing the injectors you need to run the car off of the cleaner by putting it in line by removing the fuel lines from the filter. Seafoam and redline does a great job at this and power service if you have a diesel. The liquimolly stuff isn't great.
      01-09-2022, 10:05 AM   #3
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
My x3 has the N20 engine.
I used liqui-moly injector cleaner liquid by dumping the entire bottle in the gas tank (while my fuel level was under 70L)
Yes. I understand this isn't a very thorough way of cleaning the injectors.
I might need to get carbon cleaning done soon and new injectors?
      01-09-2022, 11:12 AM   #4
WrEkkED
Liquimoly fuel system cleaner is the one you want to use. Only use it once, wait 1200 miles and then you can use injectron and add again every 1200 miles or so.
Did bmw hook the car up to ista to actually verify the injectors are going bad?
      01-10-2022, 04:40 PM   #5
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
Okay. I'll try that one.
I didn't get it scanned yet. I was told that it MAY be dirty injectors.
I kinda want the CEL to appear so it's easier to tell what it is.
I would rather have it appear after my dad returns from his vacation… that way he won't blame me for CEL or any other issues.
And so he can bring it in for service and not me because I have my own car (mk6 GTI) to deal with lol.
But I help my dad out with his x3 because it's a lot smoother to drive and way more luxury!
Heated steering wheel, heads up display (HUD), xdrive, etc
      01-12-2022, 09:12 AM   #6
WrEkkED
Haha tell me about it. I got my X3 to replace my mk4 tdi. I have broken almost everything on that car, still have it though.
If you hook the car up the computer (ista) you can see the injection values of each injector. That will let you know pretty quickly if its the injectors. They could also check the timing at the same time to rule out other possible issues. There are so many things that could cause the rpm to drop such as a failing alternator, a failing AC compressor putting extra load on the car.
      01-13-2022, 06:18 PM   #7
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
Nice. Got to keep the car you started with. The x3's are nice. I would get diesel if I can do it all over again.
I hear the Diesel engines are a lot stronger.
I'm keeping my mk6 forever. Especially because it's a 6speed GTI and I've done wayyy too many engine mods to it. Check out my Instagram account: @supreme_gti
I plan to do mods on my x3 as well. After it's paid off.
Priorities first.
I'll get my x3 scanned first and go from there.
It's nearly impossible to diagnose over the phone or over forums.
It's a good start but the real fix is at the shop.
Thank you all for your input! Drive safe and drive smart.
      01-14-2022, 04:48 PM   #8
ClampThurst
Drives: 2018 M4-Silverstone, 2017 X3
I've had this on my X3 2017(73,000 miles) N55 motor as well(even posted on here about it and noone had any good input on it). It used to do it a bunch and one day I disconnected the batter power for one minute and it went away but is now back after a few months. I am getting an "under voltage in vehicle" computer code (4809AB) not sure why, might be a drop in voltage while starting. Also getting a "ZGM central fault memory full-no control unit fault"(801C20) Not sure if these are related to the idle problem. Mine ranges from 700-1000 RPM at street light after stopping. Have you noticed if it does it in manual gear select mode??? Mine did not, the RPM variations only occurred when coming to a stop in automatic transmission mode only. It occurs with Climate control on and off.
      01-15-2022, 08:46 AM   #9
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
No I haven't checked while in manual gear box mode. I'm always in automatic gearbox mode.
I'll check if it does it in manual gear box mode.
The RPM's will only jump up and down at a full stop, or while in heavy traffic. It doesn't happen often though…
I was driving the x3 last night and it was fine. RPM stable at every red light/full stop in traffic.
Once I let go of the brake pedal, RPM comes back to normal reallll quick.
It accelerates fine and puts down power all the way through each gear/RPM band without any hesitation.
So I doubt it's fuel injectors.
Sometimes no one will answer and we got to figure it out by ourselves
Copyright ©2000 - 2022, vBulletin Solutions Inc.
