11-10-2022, 07:30 AM | #1 |
Rep 21
PDC Control Unit F25 2011
Hello,
I've searched the board and not been able to find a comprehensive answer. Where is the PDC Control Unit located on the car? Thanks |
11-10-2022, 10:17 AM | #2 |
Rep 7,512
Park Distance Control (i.e.: park distance control) assists the driver when he is parking and manoeuvring in tight spaces.
Rear electronic module Rear Electronic Module (REM) The Rear Electronic Module (REM) represents a new generation superseding existing control units and their functions. There are different versions for the respective vehicle equipment configurations and vehicle type. For example, there is a Rear Electronic Module (REM) for the convertible. The new Rear Electronic Module (REM) provides functions from the previous control units footwell module (FRM), junction box electronics (JBE) and Park Distance Control (PDC). The aim is to reduce the number of control units and to improve component networking. At the same time, the optimisation of the wiring harness reduces the physical bus capacity. -Explanation- 1. 54-pin plug connection 2. 26‐pin plug connection 3. 26‐pin plug connection 4. Fuse block 5. Voltage supply
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-10-2022 at 10:23 AM.. |
11-10-2022, 10:27 AM | #3 |
Rep 21
Thanks. So the car garage have said the PDC is faulty (as all of the sensors are showing as faulty). So if this is the case, is my only option to replace the REM? and where is the REM located?
11-10-2022, 10:57 AM | #4 |
Rep 660
F25 vehicles do not have a REM control unit. The above info is incorrect. I am not positive but I believe on an F25 the PDC module is integrated into the Junction Box Electronics (JBE) which is located behind the glovebox.
11-10-2022, 03:33 PM | #5 | |
Rep 7,512
A search in the TIS using a specific model (F25 X5 35i)..and looking specifically for the JBE...the info below comes up: the JBE is A34 in the last pic which shows where the JBE is located
11-10-2022, 03:35 PM | #6 |
Rep 7,512
If the sensors are showing a fault...how do we jump from the sensors being the problem to the control module being the problem? Has it been verified that each sensor in you system is functional? Do you have any chaffed wiring that could be causing sensor faults?
11-10-2022, 06:28 PM | #7 | |
Rep 21
11-14-2022, 03:29 PM | #8 |
The deuce gets loose
290
Rep 499
11-15-2022, 12:27 PM | #9 | |
Rep 21
11-24-2022, 10:16 AM | #10 |
Rep 21
So i've just been checking and the PDC system and windshield washer system both share a fuse (number 8). Could it be that the fuse has gone and is causing the PDC system to not work and also the windscreen washer fluid sensor?
10-22-2023, 03:34 AM | #12 |
Rep 17
Hello, I have just purchased a BMW F25 but unfortunately I do not have the rear PDC. I would like to fit it
After some research I saw that there was no REM module, but the PDC was managed by the module JBE. On my JBE module plug 4(picture) must manage the PDC but I have a plastic cover to do this retrofit. I have to change the JBE module? But in my tis with my wine I see that there is a rem 66336867863 but I can't find it in my car module I no longer understand anything and I should I add new harness And do you know what parts I need to buy? Here are the latest numbers for my wine: L605140. Thank you |
