      03-24-2020, 04:40 PM   #1
sinbad4
Drives: 2020 X3 M40i
Group Buy - BavSound
Is done.
• 2020 BMW X3 M40i Graphite : ZDA/ZDB/ZPX/718M/2VF/2T4/3KA/3AC/688/6NW/3AC
      03-24-2020, 06:30 PM   #2
MountaineerX3
I'm interested and will PM you. Is there any specific purchase requirement (i.e. entire system or just subs)?
Thanks for doing this!
      03-24-2020, 06:52 PM   #3
sinbad4
No. Either kit (sub kit or speaker kit). Orders have to be in by April 15.
      03-26-2020, 03:12 PM   #4
Tchgrif
Drives: X4 M40i
maybe put group pressure on them to up their game and get the revenant amp for our cars.
smanji132.50
      03-26-2020, 03:36 PM   #5
Alias1431
Alias1431's Avatar
Drives: 2019 BMW X3 M40i
Is that possible? I thought you could only do that with the non-HK system.
      03-26-2020, 03:54 PM   #6
sinbad4
Amps can be a tricky business. My 2008 M Roadster has "Carver" amp.. nice amp; but BMW tied it into CANBUS and they use it for some of the sound processing - normally done by the head unit. In short, I cannot replace the head unit without also replacing the amp.
      03-30-2020, 02:31 PM   #7
stepal
Drives: BMW X3
How does one get in on the group buy?
      03-30-2020, 07:58 PM   #8
Alias1431
Alias1431's Avatar
I believe it fell through.
      03-30-2020, 10:03 PM   #9
dmicah
Internet Weasel
dmicah's Avatar
Drives: 2023 X3 M40i
I think you just have to PM sinbad4. I haven't seen any indication that it fell through. The orders have to be placed by 4/15, as he has indicated in this thread.
      04-01-2020, 08:51 AM   #10
sinbad4
Group Buy ended early.
Those that got in early scored. My BavSound kits delivered Sunday. I installed same day. I am surprised by how much improved the sound is and am now a huge BavSound fan.
I regret more people weren't able to get in on the deal.
They do run specials from time to time. You can send email to Justin Rowley, justin@bavsound.com and see if their are any current or upcoming deals.
dmicah769.00
Alias1431795.00
      04-01-2020, 08:32 PM   #11
gugin
New member
Drives: 2019 X3 M40i
A few questions:
  1. Did you disconnect the battery before you began the speaker replacement?
  2. If not, did you just shut down the head unit by pressing the on/off button for a few seconds?
  3. Did you have to disconnect any wire harnesses going to the seats or can you access the underseat subs by moving the seats without the need to disconnect any wires?
      04-01-2020, 10:27 PM   #12
newsmarr
newsmarr's Avatar
25
Drives: 2019 x3 3.0I
2019 BMW  [0.00]
I have been browsing this forum for the last 6 months but recently joined and I am astounded at how little aftermarket companies chase after our business. However Justin@bavsound jumper through hoops with me even though I haven't bought anything...Yet
      04-02-2020, 03:58 AM   #13
Alias1431
Alias1431's Avatar
It's against forum rules to just straight up solicit outside their designated forum for that. Thankfully. I hate spam. If it's a good product we'll probably talk about it.
      04-02-2020, 06:21 AM   #14
Tchgrif
Drives: X4 M40i
Originally Posted by gugin View Post
A few questions:
no you do not need to disconnect the battery but obviously the car has not been started
if you never start the vehicle you do not need to turn it off
no you can just unbolt the front seats and lean them back into the rears
      04-02-2020, 09:27 AM   #15
sinbad4
A few questions:
I did not disconnect batter.
I did not shut down head unit.
I disconnected driver's seat, but the cable tie thing was sticky.. didn't really need to remove so I didn't. On the passenger side, I didn't disconnect cable at all.
As you probably guessed, but I did not; I ended up with Restraint Error afterwards which didn't want to go away by itself. I used BimmerCode to code a value in the safety module. After BimmerCode does any code changes, it clears all errors. It cleared my Restraint Error.
Including photo showing seat propped up still attached.
      04-02-2020, 12:24 PM   #16
383vett
383vett's Avatar
Looks like a nice mod. It must sound great.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131
2021 SQ5
      04-02-2020, 12:44 PM   #17
Alias1431
Alias1431's Avatar
How's it sound? Imaging? Bass?
      04-02-2020, 06:11 PM   #18
gugin
New member
I love how your seat is propped up using a hammer. Did you use the hammer for anything during the speaker replacement?
      04-02-2020, 11:52 PM   #19
sinbad4
Ha! *blush* Yes.
Subs are glued into the housing. Was a PITA to get out. Found heat helped. Heat gun along the front edge, then big screw driver hammered in and twisted. Funny enough, the hammer is the officially BavSound recommended tool - BavSound video take apart went easier than mine did:
      04-03-2020, 07:58 PM   #20
Jeepersjoey
Stay Tuned!
Drives: 2018 X3 m40i
I wish someone would remove all their speakers and then see which speakers actually transmit the engine sound to the cabin.
I bought the harness to bypass the noise and today while Idling I thought "there is no way that is NOT still being piped into the car!"
Anyone want to be the tester?
(a)Paul(d)
      04-03-2020, 08:56 PM   #21
gugin
New member
I am not sure I understand the point of the experiment you are suggesting. Are you suggesting that there are some additional speakers in the car that are entirely dedicated to playing the engine sound? That is, these speakers operate on a completely different "circuit" from the speakers connected to the audio amplifier and the ASD module. Like there is a microphone in the engine bay and small amplifier somewhere in the car powering a speaker under the dash? If you disconnected the ASD module with the bypass harness, why don't you believe that what you hear is simply 100% the noise of the engine itself? Maybe I misunderstand your question.
      04-03-2020, 10:23 PM   #22
sinbad4
(a)Paul(d)
Just use BimmerCode. Turning off ASD made easy... and lots of other goodies.
