      06-21-2022, 08:06 PM   #1
EPTF25
Drives: F25 msport
2015 X3 MSport
I am about to install H&R sport springs. I wanted to up the tire size to 245/45/20 front tires and 275/40/20 rear tires. Anyone on the lowering springs with those tires. If so any issues such as rubbing etc. Thanks
      06-22-2022, 01:31 PM   #2
Pkeefe11
Pat Keefe
Pkeefe11's Avatar
Drives: 2015 BMW X3 35i
I have a 2015 X3 non-Msport on stock suspension. I recently got new wheels and tires, went from 19s 245/45/19 all around to 20s 255/45/20. I am rubbing at full lock on only the fronts. Assuming if I was lower I would rub more. I would say go down maybe 245/35/20s in the front and 275/30/20s in the rear. Hope this helps! And definitely post some pictures.
Pat Keefe
      06-23-2022, 03:08 PM   #3
KC87ZB
KC87ZB's Avatar
293
Drives: 2023 M2
Also, make sure you are looking at offset and spacing. It's not just the tires it's also the wheels.
