      08-07-2021, 04:57 PM   #1
BobBeau
BobBeau's Avatar
Drives: X5 50i
BM3 anyone?
I had a BM3 stage 1 OTS tune on my X5 50i. I can't say enough good things about them. The difference in power was incredible. Anyone here have a BM3 or DME tune on their M40i? If so, how do you like it?
If you'd rather not comment here, please send me a PM. Thank you!
      08-07-2021, 07:51 PM   #2
freshxdough
BMW Elite Master Tech | HV Gen 5 | HV Specialist
freshxdough's Avatar
3546
Drives: 2024 iX 50 | 2020 X3 M40i
BM3 stage 2 on a 2020. Still sending it.
bcwalks2279.00
      08-07-2021, 11:13 PM   #3
1speedbike
1speedbike's Avatar
736
Drives: 2022 X4 M40i, 2008 135i
I've tuned my 135i, but don't plan on messing with my future X4 in that manner. That said, my buddy who works at BMW NA has mentioned that a simple plug-in JB+ for the B58 even at default 50% setting doesn't throw codes and transforms even the heavy SUVs into rockets on the butt dyno.
2022 X4 M40i - 2008 135i - 2015 F700GS
On Order - 2024 i4 M50
Scruffy's gonna die the way he lived... Mmhm.
      08-08-2021, 01:53 AM   #4
freshxdough
3546
The JB+ is a simple plug in piggyback that tricks the boost pressure sensor to increase more boost and power. A full JB4 or any flash tune will be far better and smoother power, with options for maps and customized settings.
If you're gonna tune it, might as well go for the full flash tune instead of just the appetizer lol.
Regardless, and I'm sure you're already aware, any tune can void your power train warranty. Any flash tune is detectable with ISTA at the dealership. End of story.
      08-08-2021, 03:08 PM   #5
BobBeau
BobBeau's Avatar
Drives: X5 50i
Did you have just the stage 1 at some point or did you go straight to the stage 2? I'm guessing you need a DP for the stage 2 tune, right?
      08-08-2021, 03:13 PM   #6
BobBeau
BobBeau's Avatar
Drives: X5 50i
What dreshxdough said. If I do it, it's going to be an ECU tune. I've no experience with the jb+ but have heard from people who've done both that the difference between a piggyback and a true tune is night and day.
      08-08-2021, 03:14 PM   #7
freshxdough
3546
Didn't bother with stage 1
      08-08-2021, 11:44 PM   #8
Sorry About That
Drives: 2020 X4 M40i
@freshxdough, did you have your DME bench unlocked locally in OC? I have the 20/07 software update that includes Android Auto and understand that the DME is locked and cannot be flashed by BM3 through the OBD2 port. Any advice on a work around or local reputable tuner here in OC that can bench unlock?
      08-08-2021, 11:46 PM   #9
freshxdough
3546
Mission Performance in Ontario can bench unlock it. That's who I went to.
      08-09-2021, 02:09 PM   #10
BobBeau
BobBeau's Avatar
Drives: X5 50i
BM3 cannot unlock the DME with the newer model BMWs via the ethernet cable?
      08-09-2021, 02:18 PM   #11
freshxdough
3546
No. I believe all B58TU need to have bench unlock before flash tuning. 06/21 and newer DME can not even be bench unlocked yet due to DME locks. Companies are currently working on it.
      01-09-2023, 04:40 PM   #12
cartergopher
Drives: 2015 F30
Does anybody know if the B58TU has been unlocked by pro tuning freaks to flash via ENET cable?
      01-09-2023, 05:18 PM   #13
blue135
Drives: 2008 135i Convertible
Only person I have heard to have unlocked the DME is in Finland, having left Russia.
      01-09-2023, 06:28 PM   #14
freshxdough
3546
Nobody besides Femto advertises an unlock for new DMEs
      01-10-2023, 07:11 AM   #15
wlfpck
Drives: 2020 BMW x3m40i
This is pretty much a pretty detailed explanation:
2020 X3M40i
      01-10-2023, 07:58 PM   #16
macoutu
Drives: 2018 X3 M40i
2018 X3 M40 stage 2 with VRSF downpipe. Love the power, the sound and fooling around with the options in the map. A real weekend tuner I tells ya!
      01-11-2023, 12:39 PM   #17
fsugatorbait2
Drives: BMW X3 M40
I've had BM3's tune on my '19 X3 since it came out. Installed with about 10k miles on the car and I've had it problem free the past 3.5 years and I'm just about to roll 70k miles. Started ST1, then onto ST2, and now on ST2+ with the TU fuel pump.
Alias1431798.00
      01-11-2023, 02:14 PM   #18
Alias1431
Alias1431's Avatar
Drives: 2019 BMW X3 M40i
You also do xHP?
