10-07-2020, 09:37 AM | #1 |
Rep 15
Any issues with wheel spacers?
I’m about to install Vossen wheels that will require 10mm wheel spacers. I’ve been told that as long as they are hub centric, made of 6061 aluminum and installed properly there are minimal risks. I plan on switching back and forth between my stock 21” and the Vossens and I’m hoping that it should be a fairly seamless experience. Has anyone had any issues with wheel spacers? All the research I’ve done online has resulted in mixed results. With 50% saying properly installed spacers are no big deal and others that say spacers are never a good idea.
10-07-2020, 10:35 AM | #2 | |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
10-07-2020, 11:16 AM | #4 | |
Rep 4,607
noushy1657.00 |
10-07-2020, 11:27 AM | #5 | ||
Cowboy Astronaut Millionaire
2313
Rep 2,885
The issue you may have seen around the interwebs. Is in the older days where people put literally 1" wide spacers on their cars. Whaaat!? As well as there were just universal 4 5 lug sets and thats all you had available. Now you literally have a pretty much custom made set for your specific vehicle model. 0 concerns at all.
AlexFL7836.00 |
10-07-2020, 03:51 PM | #6 |
eM Power Me
749
Rep 698
Drives: '23 AW i4 eDrive40 M Sport
As everyone above me stated, no issues with quality ones that are properly installed. Make sure they are hub centric and that you get the appropriate increased length of the bolts based on the thickness of the spacer you are using.
The below link goes to a couple quick pics of my H&R spacers install to give you a general idea. https://x3.xbimmers.com/forums/showp...7&postcount=32 As those were used when on my stock 21"s and my current Volk Racing wheels dont need them, they will be going on my wife's X2 shortly.
Will -
'23 Alpine White G26 ///i4 eDrive40 M Sport '23 Brooklyn Grey G20 ///330e M Sport '20 Alpine White F97 ///X3MC '20 Alpine White F39 ///X2 M Sport X |
10-07-2020, 09:01 PM | #7 |
Rep 18,707
I've been using and selling wheel spacer for the longest time.
Both on my street car and track car. I only trust and use H&R brand since it is 100% made in Germany. But question for you, why you are still using spacer if you are getting Vossen? If it HybridForged or the Forged series, it would be cut to the spec that you want it so it will clear the brake caliper without the need of spacers. I have sold many Vossen and no spacers ever needed. Unless if it is the VFS series where in some cases do need spacer.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
AlexFL7836.00 |
10-07-2020, 10:44 PM | #8 | |
Rep 15
r33_RGSport12960.00 |
10-08-2020, 07:40 AM | #9 | ||
Rep 18,707
20x9 comes in +25 and +32. And if they order you the +25, then you don't need spacer.
10-08-2020, 08:59 AM | #10 |
Rep 15
Are you sure on that? I was just was chatting with the folks at Vossen online and I asked if there was anyway to clear my front brakes and they said on stock fitments it would require spacers. I’m going to guess that is the same info they told my installer and why they are echoing the same info.
10-08-2020, 09:02 AM | #11 | |
Rep 18,707
I have sold 20" at stock setup for local guy. Besides stock 20" size is 20x9 +28. So if you go with 20x9 +25, it will add 3mm more gap against the caliper. You need to talk to me next time. Haha.
10-08-2020, 09:27 AM | #12 |
Rep 15
Thanks for all the info from you and everyone else on this forum it’s been really helpful. I’m trying to get confirmation on offsets on the fronts from my installer. I’m going with the 21”by9” I’m assuming the same stock offsets are available?
10-08-2020, 09:31 AM | #13 | |
Rep 18,707
That do need spacer if I remember correctly.
10-08-2020, 10:21 AM | #14 | |
Rep 15
Thanks again for the information it was really helpful and now I know next time. I’ll make sure to post photos once I get them installed. |
10-13-2020, 03:35 PM | #15 |
Rep 1,151
Drives: F90 M5 Comp (Evolve Tune)
i would say avoid H&R, they have had issues from supplier im told over here, i was told after i had 10mm rear ones fitted and then felt vibration, i had wheels removed and both lips have snapped off on each side, so wheel had no ledge to sit on to make perfect centre, was shocked, as i said the supplier then said ....oh we have had 3 other cases of H&R ones snapping like that, so im not the only one. I thought great, thank god i had only driven twice and not hard since fitting. I have binned them and wont use again, bimecc spacers much better quality or ones i have fitted now by Evolve tuning here in uk are by TPI, streets ahead in quality i have had zero issues with them.
10-13-2020, 09:31 PM | #16 | |
Rep 18,707
What is the part number? Because I know that H&R doesn't have 10mm for F97/F98 X3M/X4M platform.
AlexFL7836.00 |
10-13-2020, 09:41 PM | #17 |
Rep 4,607
r33_RGSport12960.00 hellcat2m4224.00 |
10-20-2020, 08:08 AM | #19 | |
Rep 18,707
Congrats.
10-20-2020, 08:10 AM | #20 | |
Rep 18,707
I need an answer so others won't make the same mistake like you or Evolve.
10-20-2020, 09:52 AM | #21 | |
Rep 1,151
10-20-2020, 10:00 AM | #22 |
Rep 18,707
Once you tell me, I can tell you exactly what is happening. Seen that happening because of customer or installer didn't read the detail instruction.
