01-19-2019, 08:18 PM | #1 |
Rep 32
X3 M40i Turbo Lagging
I am just wondering if anyone else has experiences turbo lag when giving full throttle (regardless of mode although better in sport plus).
I have for the last few weeks noticed that when i give full throttle, it takes a few noticeable seconds to really go. |
01-20-2019, 02:08 AM | #4 |
Rep 325
I don't think it's turbo lag. I think it's the gear box. Everyone is praising the ZF gearbox but I actually am not thrilled with it. I think it's bmw that was forced to program it to be in the highest gear possible for emission purposes. When you want immediate power then it needs to shift down one or two gears and then you get the push. I find the car much more punchy if you use the paddle shifters or have the gear lever in sport mode. Then there is no lag at all.
01-20-2019, 02:39 AM | #5 |
Rep 72
Can be a few factors, car load (carrying many people or heavy cargo?), outside temperature, aircond mode and driving conditions (speed and gear you're on)
Best thing to do is send it hard in sports plus mode from stand still and if it's lagging then something is wrong, but if it's portraying lagging feel when you're driving at normal speed and suddenly need to accelerate then, the above factors may play a part |
Rik762131.00 |
01-20-2019, 07:46 AM | #6 | |
Rep 3,073
Drives: 2023 iX M60 Oxide
Chief Orman671.00 |
01-20-2019, 10:06 AM | #7 | ||
Rep 1,727
01-20-2019, 10:56 AM | #8 | |
Rep 15,858
An example, we are driving in steady relaxed conditions and we want to make a rapid overtaking manoeuvre. We may not get the fastest response as the gearbox has adapted to the most economical program. Simply moving the shifter across to M/S and back again, can break that adaptation. (Will drop a gear in the process). We now floor the accelerator and instantly the gearbox 'block changes', no hesitation at all. Can be quite brutal. The shifter manoeuvre illustrates how we can break the current adaptation, see if it changes the gearbox response time. The OP with 'seconds' before action, that is not normal. Worth trying the shifter manoeuvre say from Drive, ahead of acceleration, see if it changes the feeling of lag. |
01-20-2019, 11:03 AM | #9 | ||
Rep 1,727
Fuller1216.50 |
01-20-2019, 11:13 AM | #10 | |
Rep 15,858
Been doing this with ZF autos since 2002, for 5, 6 & 8-speed. Each generation has improved its adaptive transmission management. The 8-speed is such a brilliant 'box, learn to get the best from its features and it functions superbly. |
01-20-2019, 12:54 PM | #12 |
Rep 426
Don't have the M40, bu t I've seen where I got immediate power in comfort mode and in sport mode and other times slight delay. Gearbox shifting causing delay makes more sense now.
01-20-2019, 12:57 PM | #13 | |
Rep 1,727
Shifter M/S is additive to the Sport mode, so if you want the ultimate sporty experience, combine M/S to Sport+. But be prepared for a harsh ride. |
weez271.50 |
01-20-2019, 07:10 PM | #16 | |
Rep 3,937
01-20-2019, 10:43 PM | #17 |
Rep 254
I’d argue I notice this most when at a roll of a yield sign. Sometimes you punch it to get into traffic and it just doesn’t respond as quickly as you’d hope. I’m also assuming it’s the gear box shifting down.
I’ve never much played with the paddles. 8 gears or whatever throws me for a look compared to s normal 5 speed. |
abcsoup188.50 |
01-21-2019, 08:22 AM | #18 | |
Rep 300
01-21-2019, 09:41 AM | #19 |
Rep 467
Experimenting yesterday, I think the problem is that the default start gear is 2nd gear. You can override this by putting the gear lever in m/s or manually downshifting to 1st.
01-21-2019, 10:01 AM | #20 |
BMW Client Advisor
3459
Rep 2,504
Drives: 2020 M340i
As everyone has said, it is the gearing not the turbo.
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
01-22-2019, 01:31 AM | #21 | |
Rep 254
Ah well, this annoyance beside, still love the vehicle. |
01-22-2019, 08:21 AM | #22 | ||
Rep 1,727
Also, what gear was the car on when you turned to M/S? Did the car eventually downshift To a lower gear (what gear?) for you when you accelerated away from Yield sign, despite the 'hesitation'? If it bothers you too much, there may be a workaround - while in normal automatic with shifter in 'D', pull and hold the left shift paddle on your steering wheel to drop to first gear quickly prior to you attempting the acceleration at Yield sign. This turns the transmission into temporary manual mode though, but it will return back to normal 'D' after a while, or you can manually pull and hold the right shift paddle to quickly return back to 'D'. |
