02-05-2020, 06:22 AM | #1 |
Rep 2,219
Bimmercode ASD Disable - Not Sure if it Worked
As the title states, I disabled ASD through Bimmercode.
However, I am finding that it seems it is still present. I haven’t gotten to drive the car that much but on my short trip to the train station I feel as if the ASD sound is there. The button is lit and when I turn it off it seems to make a difference. I am not sure at this point if it is just the louder sound from the exhaust when cold as I usually wait until stopped to turn it off. I know I can pull a fuse or use a bypass module but I am looking to avoid that if I can. Can anyone with Bimmercode who disabled ASD confirm it is working and advise as to the behavior of the light on the button (on or off) when disabled? |
02-05-2020, 08:04 AM | #2 |
205
Rep 668
The button will still work with ASD off. It also asks car to close exhaust flap when possible with green light off. With ASD off you should be hearing more noise from the exhaust rather than the ‘engine’.
Put it in sport+ and accelerate hard. If it sounds really loud and dramatic inside the car, ASD is still on. If you just hear a rip from the exhaust and subtle engine creeping through the sound proofing, ASD is off. Ps. I pulled a fuse. |
02-05-2020, 08:42 AM | #3 | |
Rep 2,495
The light for the exhaust button will now (once ASD disabled) will control exhaust valves in Sport and Sport+ only.
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
02-05-2020, 09:02 PM | #5 |
Rep 6,860
It should be VERY obvious when ASD is disabled. It's a very distinct artificial and loud sound (sounds mostly the same in all M models with ASD). Put it in sport+ and floor it and the cabin should be relatively silent with ASD disabled compared to when it is on.
02-06-2020, 06:26 AM | #6 | |
Rep 2,219
When I first got the car I felt “that sounds strange” and learned about it and how to turn it off. What throws me is the inconsistency of the exhaust. When cold and in park it is very loud then quiets down. Conversely, my V8 truck with headers is very consistent. I’m still in break in so I haven’t been flooring it but I’ll try a bit more gas. It may just be easier to pull the fuse at this point though. |
01-18-2023, 05:19 PM | #7 |
Rep 113
Little confused with how ASD works. When I have it turned off in Bimmercode, the car is quieter. There are no shift noises and there is are faint burbles from the back. The sound increases with the exhaust button on. I thought this was all real.
Then I went into expert mode and played with selectively turning off upshift, downshift and burbles off with the main ASD toggle still on. This was much quieter and there was zero burbles regardless drive mode. Either turning off ASD doesn't fully turn it off or turning off burbles also changes engine and exhaust programing (unlikely). Anyone have a theory on what's happening?
2023 BMW X3 M Competition, 2017 Golf TSI
-Traded-in- 2019 Audi RS3 , 2018 VW Golf R, 2013 Audi S6, 2011 VW Golf TDI, 2011 Audi S4, 2010 Audi Q5, 2001 VW Golf GLS, 2006 Audi A3 2.0T , 2004 Audi A4 1.8T, 2000 Audi A4 1.8T , 1999 VW Golf GL |
dmanb2b2123.00 |
01-18-2023, 08:49 PM | #8 |
Rep 238
Im not an ASD expert, or even intermediate, but the burbles are coming from your exhaust. There are different tunes you can do to accentuate them as well, but I don’t know enough to go into the mechanism as to how they work. Get a midpipe and they’re significantly more pronounced. Sounds great when slowing down in traffic with the windows down.
Golf_GL90.50 |
01-21-2023, 09:36 PM | #9 | |
Rep 395
Drives: 2022 X4MC - Marina Bay Blue
'22 ///X4M Competition - fully loaded Marina Bay Blue.
Lowered on MSS springs. 20" x 10 ET20 Vertini RFS1.2 wheels wrapped in Firestone Indy 500 Firehawk 275/40 tires (square setup). Hers: '15 X4 2.8i - Glacier Silver - loaded M-Sport |
Edgar_FriendlyX3M601.50 |
01-22-2023, 10:54 AM | #10 | |
Rep 1,695
In my experience the button on the center console only enables burbles in sprt/sport+ modes, it doesnt do the valves either. So in ASD it gives you the fart sounds as well. |
01-22-2023, 04:44 PM | #11 |
Rep 482
Drives: 2020 BMW X3M
The center console button does open the exhaust flaps. You can hear the actuator open and close when you push it. There is also a noticable difference in exhaust tone.
DBU232.50 |
01-25-2023, 06:09 PM | #12 | |
Rep 2,219
Could be that the engine was cold, but I noticed it and turned it off often on my way to the train station because I wanted it quieter. |
